path: root/overlays/verdin-imx8mp_lt8912_overlay.dts
2021-12-21verdin: mipi-dsi: prevent error logMax Krummenacher
The port@1 nodes don't need a reg property, delete it. Compare with: Documentation/devicetree/bindings/display/bridge/sec_dsim.txt If there is one the full functionality is still there, but drivers/gpu/drm/drm_mipi_dsi.c:163 assumes this to be a subnode describing a dsi device which needs to be registered. It then fails with: imx_sec_dsim_drv 32e10000.mipi_dsi: modalias failure on /soc@0/bus@32c00000 mipi_dsi@32e10000/port@1 Related-to: ELB-4278 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2021-03-18overlays: cosmetic clean-upMarcel Ziswiler
Cosmetic clean-up without any functional impact: - re-order overlays in Makefile alphabetically - get rid of obsolete includes - add note that CSI Camera Module 5MP OV5640 is no longer orderable at Toradex - re-order properties alphabetically - re-order nodes alphabetically - fix indentation and line-spacing - use correct NXP SoC naming nomenclature Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2021-02-18Add license to all overlaysPhilippe Schenker
Use the same license as we use on regular linux-tree Related-to: ELB-2958 Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com>
2021-02-17verdin-imx8mp_lt8912_overlay: rework for v1.1 hwMax Krummenacher
The DSI to HDMI adapter V1.1 uses the PWM_3_DSI pin, thus disable the pwm node. Related-to: ELB-3488 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2020-11-30verdin-imx8mp_lt8912_overlay.dts: use clearer label namesMax Krummenacher
Use clearer label names for the labels connecting to the kernel device tree. Related to: ELB-3209 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2020-11-26overlays: verdin-imx8mp_lt8912_overlay: verdin dsi to hdmi adapterMax Krummenacher
Add device tree overlay for Verdin DSI to HDMI Adapter orderable at Toradex. Related to: ELB-3209 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
