The port@1 nodes don't need a reg property, delete it.
Compare with:
Documentation/devicetree/bindings/display/bridge/sec_dsim.txt
If there is one the full functionality is still there, but
drivers/gpu/drm/drm_mipi_dsi.c:163 assumes this to be a
subnode describing a dsi device which needs to be registered.
It then fails with:
imx_sec_dsim_drv 32e10000.mipi_dsi: modalias failure on /soc@0/bus@32c00000 mipi_dsi@32e10000/port@1
Related-to: ELB-4278
Cosmetic clean-up without any functional impact:
- re-order overlays in Makefile alphabetically
- get rid of obsolete includes
- add note that CSI Camera Module 5MP OV5640 is no longer orderable at
Toradex
- re-order properties alphabetically
- re-order nodes alphabetically
- fix indentation and line-spacing
- use correct NXP SoC naming nomenclature
Use the same license as we use on regular linux-tree
Related-to: ELB-2958
The DSI to HDMI adapter V1.1 uses the PWM_3_DSI pin, thus disable
the pwm node.
Related-to: ELB-3488
Move all non conflicting properties into nodes of the main device tree and
just set the status to okay for those nodes.
Split the touch controller from the lvds controller's overlay into its own.
This unifies with the way it is done for the Verdin iMX8M Plus.
Update Verdin display adapter overlays lt8912 aka DSI to HDMI and
sn65dsi84 aka DSI to LVDS to take latest pin muxing changes into account.
This should make all versions up and including V1.0B (albeit with removed
IC4) operational.
Related-to: ELB-2691
Add device tree overlay for Verdin DSI to HDMI Adapter orderable at
Toradex.
