This driver correctly supports display flags and fixes the pixel
shift issue on displays with the data latching on the rising edge.
The DPU-enabled driver for LCDIF device (display_lcdif) doesn't
support display special flags. It prevents the VGA port on the
Colibri Evaluation board working correctly.
The driver mxsfb (adma_lcdif) works well with display flags,
so that it should be used as a default driver for LCD panels and
VGA monitors.
Note, the mxsfb driver DOESN'T support imx dpu unit.
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Cosmetic clean-up without any functional impact:
- white space clean-up
- adding missing new line
- add note about CSI Camera Module 5MP OV5640 only previously having
been orderable at Toradex
Add the overlay to support LCD-LVDS transceiver on Iris v2.0A.
Related-to: ELB-3876
