Cosmetic clean-up without any functional impact:
- white space clean-up
- re-order nodes/properties
- adding missing new lines
- remove obsolete includes
- remove spurious new lines
- change 7", 7inch, 10" and 10inch consistently to 7 inch resp. 10 inch
Add missing colibri-imx7-emmc compatible.
Use the same license as we use on regular linux-tree
Related-to: ELB-2958
The resistive 7" panel which should work by default on all colibri
modules has a resolution 800x480. Choose the proper settings for
this panel. Rename the overlay to reflect these changes.
Related-to: ELB-3395
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
