Use the same license as we use on regular linux-tree
Related-to: ELB-2958
Signed-off-by: Philippe Schenker's avatarPhilippe Schenker <philippe.schenker@toradex.com>
As it was decided, move all definitions back to the main devicetree.
Rename the overlay according to approved naming scheme.
Related-to: ELB-3240
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Convert an overlay file for CSI camera ov5640 V1.1B for Apalis iMX6 module
into Syntactic Sugar format, as this format is strongly recommended
in Embedded Linux Wiki [1].
[1] https://elinux.org/Device_Tree_Reference#Overlay_Source_Format
Related-to: ELB-2834
There are a lot warnings from dtc compiler about the absence of
necessary properties. [1]
Fix all of them by adding a "geometry" of nodes.
[1]
overlays/apalis-imx6_ov5640_overlay.dts:48.5-18: Warning (reg_format): /fragment@1/__overlay__/ov5640_mipi@3c:reg: property has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1)
overlays/apalis-imx6_ov5640_overlay.dts:78.5-15: Warning (reg_format): /fragment@2/__overlay__/port@0:reg: property has invalid length (4 bytes) (#address-cells == 2, #size-cells == 1)
apalis-imx6_ov5640_overlay.dtbo: Warning (pci_device_reg): Failed prerequisite 'reg_format'
apalis-imx6_ov5640_overlay.dtbo: Warning (pci_device_bus_num): Failed prerequisite 'reg_format'
apalis-imx6_ov5640_overlay.dtbo: Warning (simple_bus_reg): Failed prerequisite 'reg_format'
apalis-imx6_ov5640_overlay.dtbo: Warning (i2c_bus_reg): Failed prerequisite 'reg_format'
apalis-imx6_ov5640_overlay.dtbo: Warning (spi_bus_reg): Failed prerequisite 'reg_format'
overlays/apalis-imx6_ov5640_overlay.dts:46.19-68.6: Warning (avoid_default_addr_size): /fragment@1/__overlay__/ov5640_mipi@3c: Relying on default #address-cells value
overlays/apalis-imx6_ov5640_overlay.dts:46.19-68.6: Warning (avoid_default_addr_size): /fragment@1/__overlay__/ov5640_mipi@3c: Relying on default #size-cells value
overlays/apalis-imx6_ov5640_overlay.dts:77.11-85.6: Warning (avoid_default_addr_size): /fragment@2/__overlay__/port@0: Relying on default #address-cells value
overlays/apalis-imx6_ov5640_overlay.dts:77.11-85.6: Warning (avoid_default_addr_size): /fragment@2/__overlay__/port@0: Relying on default #size-cells value
apalis-imx6_ov5640_overlay.dtbo: Warning (avoid_unnecessary_addr_size): Failed prerequisite 'avoid_default_addr_size'
apalis-imx6_ov5640_overlay.dtbo: Warning (unique_unit_address): Failed prerequisite 'avoid_default_addr_size'
overlays/apalis-imx6_ov5640_overlay.dts:77.11-85.6: Warning (graph_port): /fragment@2/__overlay__/port@0: graph node '#address-cells' is -1, must be 1
overlays/apalis-imx6_ov5640_overlay.dts:77.11-85.6: Warning (graph_port): /fragment@2/__overlay__/port@0: graph node '#size-cells' is -1, must be 0
Related-to: ELB-1316
Add support of MIPI CSI-2 serial camera interface for Apalis iMX6 module.
