There is no /disp0 node in Apalis iMX6 at all.
Apalis iMX6 has an lcd_display node that describes a parallel RGB
interface and is enabled by default.
To make the overlay for a parallel RGB have sense, convert it to
disabling and use proper node name.
Convert an overlay file for enabling the Parallel RGB interface (eLCDIF)
on Colibri-iMX8QXP module into the Syntactic Sugar format. This format is
strongly recommended in Embedded Linux Wiki [1].
[1] https://elinux.org/Device_Tree_Reference#Overlay_Source_Format
Related-to: ELB-2834
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
