Add overlays for:
- Atmel MXT TS for boards with Capacitive Touch Connector
- Atmel MXT TS for Capacitive Touch Adapter
- Fusion F0710A TS for boards with Capacitive Touch Connector
- Fusion F0710A TS for Capacitive Touch Adapter
Signed-off-by: Denys Drozdov <denys.drozdov@toradex.com>
Add overlays for:
Related-to: ELB-3243
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
Add an overlay to support the standard VGA monitor.
Related-to: ELB-3246
Add an overlay to support FullHD monitor connected to
a VGA connector of Eval/Aster/Iris board.
The HDMI interface remains disabled in the main devicetree.
Add the overlay that turns it on, making able to use HDMI monitors.
The LVDS display connects via RGB->LVDS converter, so that we can use
the parallel-rgb overlay, setting up only timing and data modes.
The AD7879 resistive touchscreen device remains disabled in the main
devicetree. Add the overlay which turns it on for using with a
Resistive Touch Display 7".
Related-to: ELB-3395
The LCDIF interface and related devices remain disabled in the main
devicetree. Add an overlay to enable an LCDIF (Parallel RGB)
interface and all related subsystems.
The STMPE resistive touchscreen device remains disabled in the main devicetree.
Add the overlay to be able using it with Resistive Touch Display 7".
Add an overlay to enable all parallel RGG related subsystems.
As it was decided, move all definitions back to the main devicetree.
Rename the overlay according to approved naming scheme.
Related-to: ELB-3240
The VGA interface and related stuff remain disabled in the main
devicetree. Add the overlay that turns it on, enabling to use VGA
monitors.
The HDMI interface and related stuff remain disabled in the main
devicetree. Add the overlay that turns it on, enabling to use HDMI
monitors.
devicetree. Add the overlay that turns on this device, enabling to
use it with a Resistive Touch Display 7".
Add the initial version of Makefile using
the reference solution from the commit
10a077204e0c ("overlays: add makefile using regular kbuild infrastructure")
Realted-to: ELB-3239
