11 daysverdin-am62: dsi-to-lvds: add support for SLEEP_MOCItoradex_ti-linux-6.1.yStefan Eichenberger
Add support for the SLEEP_MOCI signal to the dsi-to-lvds overlays, this allows the driver to turn off the the SLEEP_MOCI in suspend. Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
11 daysverdin-am62: dsi-to-hdmi: add support for SEEP_MOCIStefan Eichenberger
Add support for the SEEP_MOCI signal to the dsi-to-hdmi overlay, this allows the driver to turn off SLEEP_MOCI in suspend. Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
2024-02-16verdin-am62: do not disable dsi_bridgeFrancesco Dolcini
DSI bridge is disabled by default on the main DT file, remove not needed disabling from non-DSI overlays. Signed-off-by: Francesco Dolcini <francesco.dolcini@toradex.com>
2024-01-24verdin-am62: riverdi: fix backlight pwm polarityMax Krummenacher
The Riverdi 10" Capacitive Touch display is brightest when the PWM duty cycle is at 100%, i.e. always 1. Thus keep the PWM polarity at normal. That way 0: backlight off, 1: backlight dark, 7: backlight bright. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-01-24verdin-am62: change riverdi 10.1 inch dsi panel timingsMax Krummenacher
With the current timings the series production display no longer sync on the provided signal. The display stays greyish. Riverdi proposed front/back-porch timing changes. With this the display work. Related-to: ELB-5389 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2024-01-09verdin-am62: add hmp overlayParth Pancholi
M4FSS and related mailbox changes are removed from main Verdin dtsi. Adding overlay to enable HMP (M4F) support in Linux. Related-to: ELB-5309 Signed-off-by: Parth Pancholi <parth.pancholi@toradex.com>
2023-12-24verdin-am62: fix native LVDS panel trailing spacesFrancesco Dolcini
Fix trailing spaces and not needed new lines. Signed-off-by: Francesco Dolcini <francesco.dolcini@toradex.com>
2023-12-07verdin-am62: Add mallow lvds overlayJoao Paulo Goncalves
Add overlay for lvds display for mallow v1.1 using native lvds interface of verdin am62. Related-to: ELB-5218 Signed-off-by: Joao Paulo Goncalves <joao.goncalves@toradex.com>
2023-10-02verdin-am62: ov5640: follow kernel update to 6.1Max Krummenacher
The base device tree keeps the CSI-2 IP and PHY in the SoC disabled now. Set their status to okay. Tested with fdt_overlays=verdin-am62_dsi-to-hdmi_overlay.dtbo verdin-am62_ov5640_overlay.dtbo Related-to: ELB-5413 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2023-09-21verdin-am62: fix mezzanine lvds overlaysMax Krummenacher
The kernel device tree changed to by default enabling the DPI to DSI bridge and sets up the port linking between the DSS and the bridge. If the bridge is missing, then the DSS is will fail in probe and its output towards the native LVDS pins will also not work. Fix this by disabling the bridge node. This prevents having an overlay for native LVDS and for DSI applied concurrently. With the DSI to HDMI adapter the touch controller and the HDMI bridge use the same I2C address resulting in a not working touch. Related-to: ELB-5372 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2023-09-21verdin-am62: drop having a compatible set in an include fileMax Krummenacher
Having a top level compatible should be limited to the top level device tree file. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2023-09-20verdin-am62: add Riverdi 10.1 inch dsi panel overlayEmanuele Ghidoli
Add overlay for Riverdi 10.1 inch capacitive touch panel connected via DSI. It can be directly connected to Mallow carrier board and, using Verdin DSI display adapter, it can be connected to Dev and Dahlia carrier boards. Related-to: ELB-5363 Signed-off-by: Emanuele Ghidoli <emanuele.ghidoli@toradex.com>
2023-09-13verdin-am62: clean-up dsi to hdmi overlayMarcel Ziswiler
- Get rid of spurious/unused labels. - Remove spurious newline. - Sort by labels. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2023-09-13verdin-am62: fix native lvds overlaysMarcel Ziswiler
Rather than referencing the root node and overriding its compatible, overlays should have their own root node with their compatible which may be checked for compatibility prior to being applied by a boot loader. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2023-05-02verdin-am62: add NAU8822 BTL overlaytoradex_ti-linux-5.10.y_bringupFrancesco Dolcini
Add NAU8822 BTL overlay. Signed-off-by: Francesco Dolcini <francesco.dolcini@toradex.com>
2023-05-02verdin-am62: add DSI to HDMI overlayFrancesco Dolcini
Add Verdin DSI to HDMI adapter overlay. Related-to: ELB-5026 Signed-off-by: Francesco Dolcini <francesco.dolcini@toradex.com>
2023-04-28verdin-am62: add dsi to 10inch lvds panel overlayMarcel Ziswiler
Add overlay for 10 inch capacitive touch panel connected via DSI to LVDS adapter. Related-to: ELB-5026 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2023-04-13verdin-am62: add ov5640 camera overlayMax Krummenacher
Use media-ctl to set the format of the source node and gst-launch-1.0 to start and consume the video stream. media-ctl --set-v4l2 '"ov5640 4-003c":0 [fmt:UYVY8_1X16/640x480@1/30]' gst-launch-1.0 v4l2src device=/dev/video0 num-buffers=30 ! \ video/x-raw,width=640,height=480, format=YUY2 ! waylandsink sync=false [B media-ctl --set-v4l2 '"ov5640 4-003c":0 [fmt:UYVY8_1X16/720x480@1/30]' gst-launch-1.0 v4l2src device=/dev/video0 num-buffers=30 ! \ video/x-raw,width=720,height=480, format=YUY2 ! waylandsink sync=false media-ctl --set-v4l2 '"ov5640 4-003c":0 [fmt:UYVY8_1X16/1280x720@1/30]' gst-launch-1.0 v4l2src device=/dev/video0 num-buffers=30 ! \ video/x-raw,width=1280,height=720, format=YUY2 ! waylandsink sync=false media-ctl --set-v4l2 '"ov5640 4-003c":0 [fmt:UYVY8_1X16/1920x1080@1/15]' gst-launch-1.0 v4l2src device=/dev/video0 num-buffers=30 ! \ video/x-raw,width=1920,height=1080, format=YUY2 ! waylandsink sync=false media-ctl --set-v4l2 '"ov5640 4-003c":0 [fmt:UYVY8_1X16/2592x1944@1/15]' gst-launch-1.0 v4l2src device=/dev/video0 num-buffers=30 ! \ video/x-raw,width=2592,height=1944, format=YUY2 ! waylandsink sync=false root@verdin-am62-14917625:~# media-ctl --set-v4l2 '"ov5640 4-003c":0 [fmt:UYVY8_1X16/640x480@1/30]' root@verdin-am62-14917625:~# gst-launch-1.0 v4l2src device=/dev/video0 num-buffers=30 ! \ video/x-raw,width=640,height=480, format=YUY2 ! waylandsink sync=false -v Setting pipeline to PAUSED ... Pipeline is live and does not need PREROLL ... Pipeline is PREROLLED ... Setting pipeline to PLAYING ... New clock: GstSystemClock /GstPipeline:pipeline0/GstV4l2Src:v4l2src0.GstPad:src: caps = video/x-raw, width=(int)640, height=(int)480, format=(string)YUY2, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)2:4:16:1 /GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, width=(int)640, height=(int)480, format=(string)YUY2, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)2:4:16:1 /GstPipeline:pipeline0/GstWaylandSink:waylandsink0.GstPad:sink: caps = video/x-raw, width=(int)640, height=(int)480, format=(string)YUY2, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)2:4:16:1 /GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, width=(int)640, height=(int)480, format=(string)YUY2, framerate=(fraction)120/1, interlace-mode=(string)progressive, colorimetry=(string)2:4:16:1 Redistribute latency... Got EOS from element "pipeline0". Execution ended after 0:00:01.011434424 Setting pipeline to NULL ... Freeing pipeline ... root@verdin-am62-14917625:~# Related-to: ELB-5082 Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2023-04-11verdin-am62: add native lvds overlaysMarcel Ziswiler
Add overlays for native LVDS being MSP. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2023-03-07verdin-am62: add spidev overlayFrancesco Dolcini
Add spidev overlay for Verdin AM62. Related-to: ELB-5085 Signed-off-by: Francesco Dolcini <francesco.dolcini@toradex.com>
2023-01-13verdin-imx8: add overlay to support nau8822 codec btlEmanuele Ghidoli
Add overlay to configure the two loudspeaker outputs as a single Bridge Tied Load output getting higher output power. Related-to: ELB-4489 Signed-off-by: Emanuele Ghidoli <emanuele.ghidoli@toradex.com>
2022-10-05colibri-imx7: workaround for atmel-mxt connectorPhilippe Schenker
Settings for adapter are wrongly redefined in imx7-colibri-eval-v3.dtsi which leads to this overlay currently not working. As a workaround, do redefine these settings again in this overlay. Related-to: ELB-4830 Signed-off-by: Philippe Schenker <philippe.schenker@toradex.com>
2022-10-04colibri-imx6: fix panel-cap-touch-10inch-lvds_overlayMarcel Ziswiler
The panel-cap-touch-10inch-lvds_overlay was inadvertently using the adapter rather than the connector for the atmel-mxt capacitive touch screen. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2022-10-03.gitignore: ignore build artifactsMarcel Ziswiler
Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> (cherry picked from commit 4b262f28720e12214c92d2c90c94f711ece31448) Add also to the master branch Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2022-10-03apalis-imx6: move to one overlay per accessoryMax Krummenacher
Move the existing overlays to dtsi files and include them into one accessory dts. Provide data-mapping timings appropriately for each machine instead of the hardcoding and use a single overlay per SoC to avoid code duplication. Set the bus-format via toradex specific data-mapping property in the machine specifig overlay. Make sure the panel-dpi compatible is set correctly in the display specific overlay. While at it use new lines consistently and set sensible width and height dimension for a fullHD analog RGB monitor. Signed-off-by: Max Krummenacher <max.krummenacher@toradex.com>
2022-10-03colibri-imx7: move to one overlay per accessoryAishwarya Kothari
Move the existing overlays to dtsi files and include them into one accessory dts. Provide data-mapping timings appropriately for each machine instead of the hardcoding and use a single overlay per SoC to avoid code duplication. Signed-off-by: Aishwarya Kothari <aishwarya.kothari@toradex.com>
2022-10-03colibri-imx6ull: move to one overlay per accessoryAishwarya Kothari
2022-10-03colibri-imx6: move to one overlay per accessoryAishwarya Kothari
2022-09-07apalis-imx6: add spidev overlayAishwarya Kothari
This overlay enables the spidev driver on the apalis imx6 spi interface. Related-to: ELB-4689 Signed-off-by: Aishwarya Kothari <aishwarya.kothari@toradex.com>
2022-09-07colibri-imx6: add spidev overlayAishwarya Kothari
This overlay enables spidev driver on the colibri imx6 spi interface. Related-to: ELB-4689 Signed-off-by: Aishwarya Kothari <aishwarya.kothari@toradex.com>
2022-09-07colibri-imx7: add spidev overlayAishwarya Kothari
This overlay enables the spidev driver on the colibri imx7 spi interface. Related-to: ELB-4689 Signed-off-by: Aishwarya Kothari <aishwarya.kothari@toradex.com>
2022-09-07colibri-imx6ull: add spidev overlayAishwarya Kothari
This overlay enables spidev driver on the colibri iMX6ULL spi interface. Related-to: ELB-4689 Signed-off-by: Aishwarya Kothari <aishwarya.kothari@toradex.com>
2022-08-30verdin-imx8mm: clean fix spidev overlayAishwarya Kothari
This commit corrects the indentation, adds a comment about the the compatible chipname used to bind the spidev driver and removes the redundant status variable. Fixes: d929016d ("verdin-imx8mm: add spidev overlay") Signed-off-by: Aishwarya Kothari <aishwarya.kothari@toradex.com>
2022-08-30verdin-imx8mp: clean fix spidev overlayAishwarya Kothari
This commit corrects the indentation, adds a comment about the the compatible chipname used to bind the spidev driver and removes the redundant status variable. Fixes: 9282bdc4 ("verdin-imx8mp: add spidev overlay") Related-to: ELB-4652 Signed-off-by: Aishwarya Kothari <aishwarya.kothari@toradex.com>
2022-08-26verdin-imx8mp: fix spidev overlayAishwarya Kothari
This commit suppresses compiler warnings about address-cells and size-cells properties missing in spidev block Fixes: 9282bdc4 ("verdin-imx8mp: add spidev overlay") Signed-off-by: Aishwarya Kothari <aishwarya.kothari@toradex.com>
2022-08-25verdin-imx8mm: fix spidev overlayAishwarya Kothari
This commit suppresses compiler warnings about address-cells and size-cells properties missing in spidev block Fixes: d929016d ("verdin-imx8mm: add spidev overlay") Signed-off-by: Aishwarya Kothari <aishwarya.kothari@toradex.com>
2022-08-23verdin-imx8mp: add spidev overlayAishwarya Kothari
This overlay enables spidev by default. Related-to: ELB-4652 Signed-off-by: Aishwarya Kothari <aishwarya.kothari@toradex.com>
2022-08-23verdin-imx8mm: add spidev overlayAishwarya Kothari
2022-05-05overlays: mxt-adapter: fix reset gpio polarityMarcel Ziswiler
Fix reset GPIO polarity in-line with the following upstream fix: https://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git/commit?id=feedaacdadfc332e1a6e436f3adfbc67e244db47 Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
2021-09-02imx6ull-emmc: add overlaysOleksii Bidnichenko
Add following overlays: - Parallel RGB support - Parallel RGB LVDS support - Atmel MXT TS for boards with Capacitive Touch Connector - Atmel MXT TS for Capacitive Touch Adapter - Toradex 7" resistive touchscreen ad7879 Related-to: ELB-4065 Related-to: ELB-4080 Signed-off-by: Oleksii Bidnichenko <oleksii.bidnichenko@toradex.com>
2021-06-21apalis-imx6: fix ov5640 overlaysOleksandr Suvorov
When the overlays was converting to the syntactic sugar, the ov5640 driver was sat to the wrong i2c channel. Fix it. Fixes: 9b0e73d2115d ("apalis-imx6: convert ov5640 v1.1b to syntactic sugar") Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2021-04-02overlays: apalis-imx6: fix adv7280 nodeSergio Prado
The correct name for the node is adv_7280, as declared in imx6qdl-apalis.dtsi. Related-to: TOR-1692 Signed-off-by: Sergio Prado <sergio.prado@toradex.com>
2021-04-01overlays: sort Makefile entries alphabeticallyOleksandr Suvorov
Sort overlays' entries in Makefile alphabetically. Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2021-04-01overlays: colibri-imx7: LCD-LVDS transceiverOleksandr Suvorov
Add the overlay to support the LCD-LVDS transceiver on Iris v2.0A in single-channel RGB24 mode. Related-to: ELB-3898 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2021-03-30overlays: colibri-imx6: add LVDS transceiverOleksandr Suvorov
Add the overlay to support LCD-LVDS transceiver on Iris v2.0A. Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2021-03-29overlays: colibri-imx7: fix compatible listOleksandr Suvorov
Add missing emmc version of the module into the compatible lists. Related-to: ELB-3849 Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
2021-02-23overlays: colibri-imx7: imx7-emmc support for touchscreenDenys Drozdov
colibri-imx7d-emmc target should be compatible to support capacitive touchscreen on imx7d-emmc Signed-off-by: Denys Drozdov <denys.drozdov@toradex.com>
2021-02-22overlays: colibri-imx7: add connector and adapter overlaysDenys Drozdov
Add overlays for: - Atmel MXT TS for boards with Capacitive Touch Connector - Atmel MXT TS for Capacitive Touch Adapter - Fusion F0710A TS for boards with Capacitive Touch Connector - Fusion F0710A TS for Capacitive Touch Adapter Signed-off-by: Denys Drozdov <denys.drozdov@toradex.com>
2021-02-19Add license checking in CIPhilippe Schenker
2021-02-19Add license to all overlaysPhilippe Schenker
Use the same license as we use on regular linux-tree Related-to: ELB-2958 Signed-off-by: Philippe Schenker's avatarPhilippe Schenker <philippe.schenker@toradex.com>
