This reverts commit 1b4e6ad4d927c7998fa578f2d29e0c4ec01a9217.
Said commit broke b43 on older kernels (<3.16).
This is used by the rtl8723bs driver. The implementation is completely
in this header file, so it is save to copy it
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
I am not aware of any user of the NFC coded in backports, at least I
haven't seen any patches regarding this. Remove this code to reduce the
efforts needed in the backports project.
Use the versions shipped with the kernel instead.
bcma and ssb didn't change much in the last few years, most of the
changes were related to code only used on embedded devices. Removing
this reduces the number of parts we have to backport. b43, b43legacy and
brcmsmac work well with the in kernel version.
Signed-off-by: Felix Fietkau <nbd@nbd.name>
Overflow macros are useful for further backports
This adds the staging Realtek drivers which are making use of cfg80211
and mac80211.
Uh, this was awful. Because the crypto/ things are completely
impossible to backport, I've actually implemented this by using
mbedtls and embedding the relevant functions it has...
The mbedtls code is taken from mbedtls version 2.6.0 and only
minimally modified (mostly to remove <string.h> and similar).
Those uapi header files are always needed, so don't mark them as
being for wwan drivers.
This driver was compile tested on kernel 3.18 and 4.9.
>From below commit, st-nci.h has been removed
61a0410 NFC: st-nci: Get rid of platform data
And we don't need st-nci-spi.patch, either. The patch is included in
upstream kernel source.
Signed-off-by: AceLan Kao <acelan.kao@canonical.com>
>From below commit, the file has been removed
a520b49 wil6210: remove ioctl interface
These files got removed from upstream kernel so they result in
backport failure.
Signed-off-by: Arend van Spriel <arend.vanspriel@broadcom.com>
Instead of maintaining our own version of average.h,
just copy the upstream version while generating the
backport.
None of these are maintaining backports anymore, so remove them
for now. If anyone's interested, fixes and maintenance is very
much welcome.
We don't need to have a local copy of codel.h anymore, so it can be
removed and copied from the kernel sources. Additionally, it was
split into 3 different headers, so copy the other 2 as well.
Also copy the fq header files, which are used by newer wireless
subsystem versions, from the kernel sources.
Additionally, remove pkt_sched.h since it is not necessary anymore.
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
This header file is now used by some driver.
The brcmfmac-sdio.h was renamed to brcmfmac.h.
This also adds the hostap wifi driver to backports.
The media includes were reorganized, we have to include more files now.
This file was removed in upstream kernel commit 22bc8625 "[media]
rcar_vin: Remove obsolete platform data support"
The realtek drivers were reorganized and are now located under realtek
directory.
The following upstream commit added a new header files used by usbnet:
commit c40a2c8817e42273a4627c48c884b805475a733f
Author: Oliver Neukum <oneukum@suse.com>
Date: Mon Sep 7 16:05:38 2015 +0200
CDC: common parser for extra headers
The platform data file is called st-nci.h instead of st_nci.h.
Signed-off-by: Arend van Spriel <arend@broadcom.com>
The new nfcmrvl driver needs a new platform data header file.
st21nfcb.h was renamed in the upstream kernel, do the same for
backports. This rename was done in this commit:
commit ed06aeefdac348cfb91a3db5fe1067e3202afd70
Author: Christophe Ricard <christophe.ricard@gmail.com>
Date: Tue Jun 9 22:26:05 2015 +0200
nfc: st-nci: Rename st21nfcb to st-nci
Before we only copied the hdmi.h header file and not the driver. Now
some other drivers need the hdmi driver code, also copy it now too.
The nxp-nci NFC driver was added in Linux commit dece45855 and needs an
additional header file.
This file is needed by some media drivers.
It only contains inline functions and macros, so it is save to copy it.
This wifi driver was missing before.
This driver uses the cfg80211 so we should ship it.
This file was removed from the kernel in commit 32d17597.
This header is needed by some media drivers. It is safe to copy this
file, because it does not contains any header for an interface to other
kernel subsystems or drivers, but only consonants defined in the HDMI
standard.
The new file media-bus-format.h was derived from contents from
v4l2-mediabus.h, this change might be a bit harder to infer
exactly what to do but based on some contextual examination of
the file, if content integrity has not changed it should be
relatively easy to infer what to do with changes like this.
commit edcf58bc031e621f519c9dfce3c7e1ea6880c70a
Author: Boris BREZILLON <boris.brezillon@free-electrons.com>
Date: Mon Nov 10 14:28:26 2014 -0300
[media] Move mediabus format definition to a more standard place
Define MEDIA_BUS_FMT macros (re-using the values defined in the
v4l2_mbus_pixelcode enum) into a separate header file so that they can be
used from the DRM/KMS subsystem without any reference to the V4L2
subsystem.
Then set V4L2_MBUS_FMT definitions to the MEDIA_BUS_FMT values using the
V4L2_MBUS_FROM_MEDIA_BUS_FMT macro.
Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com>
Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
Acked-by: Hans Verkuil <hans.verkuil@cisco.com>
Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com>
Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com>
include/uapi/linux/Kbuild | 1 +
include/uapi/linux/media-bus-format.h | 125 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
include/uapi/linux/v4l2-mediabus.h | 184 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++-------------------------------------------------------------------------
3 files changed, 206 insertions(+), 104 deletions(-)
Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
Address the renaming. cfg802154.h was already added but we forgot
to remove wpan-phy.h. This is an example type of upstream that
we should easily be able to automatically backport through
inference. Logic:
for f in copy_list:
if f in git_delta_renamed:
adjust_copy_list(f)
We'd first have to build a series of types of changes from
the delta between the last linux-next tag we tracked and the
currenty evaluated one, the git_delta_renamed would contain
a list of renames that happened between the two tags.
commit 5ad60d36993596f7b3b958500f9c66c5338cd855
Author: Alexander Aring <alex.aring@gmail.com>
Date: Sat Oct 25 09:41:02 2014 +0200
ieee802154: move wpan-phy.h to cfg802154.h
The wpan-phy header contains the wpan_phy struct information. Later this
header will be have similar function like cfg80211 header. The cfg80211
header contains the wiphy struct which is identically the wpan_phy
struct inside 802.15.4 subsystem.
Signed-off-by: Alexander Aring <alex.aring@gmail.com>
Cc: Alan Ott <alan@signal11.us>
Signed-off-by: Marcel Holtmann <marcel@holtmann.org>
This is needed by bluetooth and ieee802154.
These files were moved in the mainline kernel, we have to adapt that.
Fixes a recent iwlwifi build error
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
This file is needed by the wil6210 driver now.
It looks like no one is using the regulator drivers and maintaining
them costs some time because they often break. When someone needs
a specific driver please send a patch adding this one specific driver,
maintaining a small subset is not a problem, but maintaining all is a
big task.
This is needed by drivers/nfc/st21nfcb/i2c.c
This adds the cc2520.h and disables the driver on kernel < 3.5.
This is provides in-kernel functionality, to include
it assuems we have provided a backport for this functionality
and that's not true.
This reverts commit 16472f0c6924f0fa54c68a024a55d89689b413a0.
