Just clean up the dependency list, skcipher is known to not
work, but we neither backport bluetooth now, nor does current
upstream bluetooth actually need skcipher.
We can't really backport those, but add them anyway for compilation,
perhaps somebody doesn't want to suspend/resume?
With commit 3d6ce86ee794 ("drivers: remove force dma flag from buses")
in kernel 4.18 of_dma_configure() got the extra parameter force_dma.
This is backported by setting the force_dma member which was added in
commit d89e2378a97f ("drivers: flag buses which demand DMA
configuration") in kernel 4.15.
In older kernel versions we just ignore this parameter as the
of_dma_configure() function internally takes care of setting this
correctly.
Since commit 7b07cbefb68d ("iommu: of: Handle IOMMU lookup failure with
deferred probing or error") in kernel 4.12 this function returns int and
not void any more.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
This reverts commit 1b4e6ad4d927c7998fa578f2d29e0c4ec01a9217.
Said commit broke b43 on older kernels (<3.16).
This is just a forward include, but earlier versions don't include
linux/types.h despite relying on it.
The getrawmonotonic64() function that is used by the
ktime_get_raw_ts64() backport was only introduced in 3.19. To fix
compilation with earlier kernels, do the convertion from
getrawmonotonic() manually if the kernel is < 3.19.
Additionally, add timespec_to_timespec64() that we need for this
conversion (and which was only introduced in 3.17).
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
I am not aware of any user of the NFC coded in backports, at least I
haven't seen any patches regarding this. Remove this code to reduce the
efforts needed in the backports project.
Use the versions shipped with the kernel instead.
bcma and ssb didn't change much in the last few years, most of the
changes were related to code only used on embedded devices. Removing
this reduces the number of parts we have to backport. b43, b43legacy and
brcmsmac work well with the in kernel version.
Replace the existing skb->xmit_more semantic patch rule with a more
generic one that uses a helper inline function.
The u64_stats_init() macro was turned into a static inline function in
v4.2 to prevent warnings that happen when its argument is not used
elsewhere.
Since we started hitting these warnings, undefine the macro and define
the static inline to prevent them.
With kernels < 3.17, we need to include hrtimer.h to get ktime_divns()
for the ktime_get_boottime_seconds() backport. But we can't just
include htrtimer.h in the backport timekeeping.h because we run into
some cyclical inclusions that cause problems. To solve that make
ktime_get_boottime_seconds() non-inline and add it to a new
backport-4.18.c file.
In kernels earlier than 3.18, the raw_spin_lock defininition when
CONFIG_DEBUG_LOCK_ALLOC is not enabled, was dropping one of the
parameters, which caused a few "unused variable" warnings at places
where this argument was only used in the call to
raw_spin_lock_nested(). Take the latest definition which evaluates
the argument to avoid compiler warnings.
We were including leds.h twice in backport-4.5.c and one of them was
very early, which caused inclusion conflicts at least with < 3.16
kernels.
This was introduced in 4.18 and is needed by rhashtable.h, that we
copy. So copy it as well.
This function was introduced in v4.6 and now the iwlwifi driver uses
it. Add the function for kernels older than v4.6.
Allow using wait_event_killable_timeout function in kernel
older then 4.13
Signed-off-by: Shahar S Matityahu <shahar.s.matityahu@intel.com>
At least in some older kernel versions (e.g. 3.10), the tcp.h header
file is not implicitly included from other headers if CONFIG_IPV6 is
not set, so we need to include it in backport-4.4.c. Also, there is
an IPv6 structure that is used, so we should ifdef it away when IPv6
is not enabled.
wireless-drivers-next.git commit cb18e2e9ec71 (brcmfmac: fix wrong
strnchr usage) used strreplace(), which is not available in kernel prior
to v4.2. Before this commit proprgates to linux-stable.git, add
strreplace() to avoid gentree failure.
Signed-off-by: Winnie Chang <winnie.chang@cypress.com>
Signed-off-by: Chi-Hsien Lin <chi-hsien.lin@cypress.com>
In newer kernels, calling cc-option will use KBUILD_CFLAGS,
which itself gets subdir-ccflags-y added to it. Thus, we get
it referencing itself, since nothing here is evaluated until
KBUILD_CFLAGS is used: KBUILD_CFLAGS contains subdir-ccflags-y,
that in turn contains cc-option call, containing KBUILD_CFLAGS.
To avoid that, use := assignment to subdir-ccflags-y, meaning
the cc-option call is done right away and we don't end up with
KBUILD_CFLAGS referencing itself.
Note that this is the first assignment to subdir-ccflags-y, so
the += was never necessary.
This fixes build of the driver on kernels 4.15 and higher.
ktime_get_raw_ts64() uses the old function which was renamed.
[fix typo in commit message]
These functions are currently used by the usbnet driver.
These functions were introduced in upstream commit 2695578b896ae ("net:
usbnet: fix potential deadlock on 32bit hosts")
This is used by the mac80211_hwsim driver. The code was copied from the
mainline kernel.
This was introduced in mainline kernel commit c3ab2b4ec8f7 ("net: ipv4:
Add extack messages for route add failures")
This adds the kvzalloc() function and allows it to remove the
lib-rhashtable.patch patch.
[fix commit message kzalloc -> kvzalloc]
This removes parts which were only used by subsystems which are not
included in backports any more, for example media, bluetooth and
Ethernet.
The patches which are removed in this commit are not applied to the
kernel tree anyway with the default configuration because non of the
files get copied. The freezer, media, regulator and sound parts were
only used by the already removed media drivers. The flow dissector file
is not copied any more.
crypto_memneq has been backported in 3.12.59 and 3.10.106, it
shouldn't be built for these kernels.
Signed-off-by: Alban Bedel <alban.bedel@avionic-design.de>
It is used by new mt76 changes
Signed-off-by: Felix Fietkau <nbd@nbd.name>
Function memcmp is implicit declaration on kernel 4.9.88 ARM platform.
backport-include/keys/asymmetric-type.h uses function memcmp but its
caller compat/verification/verify.c and all its related header files
do not include string.h. The header file is usually included from
arch/arm/include/asm, but in this configuration, it doesn't. We need
to be safe and insure string.h is there.
If compiling on 3.13, struct genl_family isn't actually
struct backport_genl_family, and then family->family
doesn't exist. In other cases, it's actually necessary
to update it, so add an #ifdef with the same logic as
the override from genl_family -> backport_genl_family.
Family ID from the original family struct will be used when building
genl messages (sent as nlmsg_type), so the new id should be updated in
the original (older kernel format) family struct too
Signed-off-by: Aaron Komisar <aaron.komisar@tandemg.com>
In kernel 4.15 the field sk_pacing_shift was introduced to allow
(wifi) drivers to change the behaviour of TSQ. In 4.16 a helper
function was added which mac80211 is using. So backport the helper
which is just a stub for kernels prior to 4.15.
Cc: Eric Dumazet <edumazet@google.com>
Signed-off-by: Arend van Spriel <arend.vanspriel@broadcom.com>
This macro definition was added in 4.17-rc1 and used by mac80211
so add it to backport.
This seems to be generated by newer kernels when building,
add it to the gitignore.
linux-stable 4fa8bc949de11c99ee2433c602d43f87c452f4f2 renamed
*-asn1.[ch] files to *.asn1.[ch]. Make the corresponding change
for backports.
This adds the staging Realtek drivers which are making use of cfg80211
and mac80211.
In Linux commit d19c3d91d1cf3 ("Revert "net: use lib/percpu_counter API
for fragmentation mem accounting"") the sub_frag_mem_limit() and
add_frag_mem_limit() functions were changed back to the old versions.
Commit 42ab19ee90292 ("net: Add extack to upper device linking") which
added an extra parameter to netdev_upper_dev_link() was added with
kernel 4.15 and was not backported to kernel 4.14, activate this
backport already for kernel 4.14.
Fixes: 8cdd85766293 ("backports: add netdev_upper_dev_link() extack argument")
This function was added in commit d6d29896c665d ("timekeeping: Provide
timespec64 based interfaces"). We can just use the 32 bit version
instated as the rest was already backported in backports commit
ea8b7cd797ca0c ("backports: deal with struct timespec64 changes)".
This function was added in commit dbe7aa622db96b ("timekeeping: Provide
y2038 safe accessor to the seconds portion of CLOCK_REALTIME") and is
used by multiple realtek drivers.
Older kernel versions do not have the include linux/nospec.h with the
function array_index_nospec, provide a dummy implementation for these
kernel versions and forward the call the the real version for capable
kernel versions.
DEFINE_DEBUGFS_ATTRIBUTE and debugfs_create_file_unsafe() were
introduced in mainline commit c6468808149 ("debugfs: add support for
self-protecting attribute file fops"), but on older kernel versions
where we do not have this extra security in debugfs we can use the older
functions instead.
This prevents some compile problems in rtlwifi.
Without this patch I am getting a compile error in
drivers/net/wireless/realtek/rtlwifi/rtl8821ae/table.c with multiple
kernel versions because BUILD_BUG_ON_ZERO is implicitly defined.
__poll_t was added for kernel 4.15 in commit 8ced390c2b ("define
__poll_t, annotate constants"), add it here for older kernel versions.
Multiple drivers are using this type.
The POLL constants are getting replaced with the EPOLL constants. In
this process commit e78cd95bebd9 ("preparation to switching ->poll() to
returning EPOLL...") added an additional include to linux/poll.h. Some
drivers make use of this indirect include now and fail to compile
without it.
Older kernel versions do not define all the EPON constants so add them
if they are not available.
DEFINE_TIMER only has 2 parameters since kernel commit 1d27e3e2252ba
("timer: Remove expires and data arguments from DEFINE_TIMER") which was
added with kernel 4.15. Add a version which translates between the new
and the old API.
Mistakenly, the percpu.h file was added to a new backport-include
directory at the root. It should be in the proper location at
backport/backport-include instead. Fix that.
Fixes: a4c44dbee35d ("backport: implement alloc_percpu_gfp() for < 3.18.")
The verification code has some large data variables that are allocated
in the stack. Increase the maximum stack frame size in the compiler
check slightly (from 1024 to 1280) to prevent harmless warnings.
