This change is only needed for kernel 4.1 and later and not for 4.0.
This reverts commit 1adc4bb782a411b29f4f6ddc9b3ddbe081b7bacb.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Some bluetooth code makes use of wait_on_bit_timeout() now. This
function was introduced in commit 44fc0e5. It was only possible to
backport this to kernel >= 3.17. This function makes use of a new
member in struct wait_bit_key which was added with kernel 3.17.
In commit 817bd72 the dma_buf_export() function signature changed
from getting a long list of parameters to just getting a structure
with all the parameters in it. This patch adds a function which
translates from the new signature to the old function signature. This
function now also handles the different versions of dma_buf_export()
used in different kernel versions.
This has been in the kernel for a long time, but wasn't
used by anyone. Now it's used by rhashtable, so add it.
This was added to list_nulls.h fairly recently in commit f89bd6f87a53.
These were added upstream a long time ago in commit 685343fc3ba61,
but not needed until implemented in the wireless stack recently.
Last ath10k makes use of hash tables, which changed in the upstream
commit:
* commit 0bbacca7c3911451cea923b0ad6389d58e3d9ce9
* Author: Sasha Levin <sasha.levin@oracle.com>
* Date: Thu Feb 7 12:32:18 2013 +1100
* hlist: drop the node parameter from iterators
The list portion of this commit has already been backported, but the
hashtable part has not. So this change evens it up. It fixes a build
issue when selecting ath10k on a kernel before 3.9
Signed-off-by: Mathieu Olivari <mathieu@qca.qualcomm.com>
Adjust the kernel version parsing and list of backport files
generation for 4.x kernels.
Signed-off-by: Luciano Coelho <luciano.coelho@intel.com>
In mac80211-next a call to get_net_ns_by_fd() has been added in cfg80211
which resides in networking core. This function has been backported
such that it will always fail, ie. as it would when CONFIG_NET_NS
is not defined. The call was added by:
commit 4b681c82d2f9bef121c912ffcaac89a004af3f2c
Author: Vadim Kochan <vadim4j@gmail.com>
Date: Mon Jan 12 16:34:05 2015 +0200
nl80211: Allow set network namespace by fd
Signed-off-by: Arend van Spriel <arend@broadcom.com>
In kernel 3.0 the function prototype is only present when CONFIG_OF is
selected, if that is not selected the prototype is not there. This adds
an empty implementation for that case.
These macros are used by some Ethernet drivers now.
This function is needed by some media driver.
This was introduced on kernel version 3.1, so a kernel (3.0) without
it is still just within the support window. Define this constant if
it isn't defined.
[Move the code to backport/backport-include/linux/netdevice.h, it is
placed there in recent kernel version]
The tx_flags haven't been a union since 2.6.37, so since we
no longer support that kernel the '&' operation will now be
possible on all supported kernels. Use that fact to get rid
of the patch by defining SKBTX_WIFI_STATUS to 0 so the code
also disappears, but doesn't have to be patched.
While at it, clean up a double #if.
Changed the version number in the file header comment.
hwmon group registration functions have been added in 3.13 kernel.
Latest ath10k patches make use of this mechanism, therefore the
need for the backport.
[do not dereference hwdev before giving to dev_set_drvdata]
This file was newly added to the kernel. It was extracted from
linux/clocksource.h.
string.h is usually included from the asm/ folder in most configuration,
but on some older kernels and non-x86 architecture, this inclusion is
not necessarily happening. As we're using memcpy() in the code
below, we need to be safe and make sure string.h is indeed there.
This issue has been observed on a 3.4 vendor kernels, but may be
applicable to other configurations.
dma_rmb() is added twice, because most architectures do not include
asm-generic/barrier.h, but only asm/barrier.h. This should work with
all architectures.
dma_rmb() is used by the igb driver.
eth_skb_pad() is used by the igb driver.
skb_put_padto() is used by the igb driver.
napi_alloc_skb() is now used by some Ethernet drivers instead of
netdev_alloc_skb_ip_align(). It can not be placed into backport-
include/linux/skbuff.h because it accesses a member of struct
napi_struct which is not possible in skbuff.h, placing it into
netdevice.h worked in my tests.
When coredump was included in the kernel backports is build against
then it could be that the prototype are used, which caused a undefined
references linking problem. This patch fixes the problem by only using
this when the driver is actually compiled in.
This is needed by igb driver.
This new functions is used by ath9k.
This backport is only needed for kernel < 3.1.
Backporting drain_workqueue() is too hard so we just flush the
workqueue which should work in most cases. This could still cause
problems in some situation.
when we do not include the original version of dma-buf.h, some other
header files should be included because some media drivers are
expecting this now.
of_find_compatible_node() is not defined when CONFIG_OF is not set on
kernel < 3.3.
This was added in kernel 3.19.
for_each_compatible_node() is defined in a CONFIG_OF condition on older
kernel versions. Now some drivers are use it when CONFIG_OF is not set,
add it always when it is not already there.
netdev_rss_key_fill() uses net_get_random_once() and since
this depends on static keys and we've decided to only backport
that only down to 3.5 as that is when static key stuff settled we
only backport netdev_rss_key_fill() down to 3.5 as well. For details
on the net_get_random_once() / static key stuff refer to backports
commit 8cb8816d.
Backporting netdev_rss_key_fill requires us to throw in the
netdev_rss_key within our own backports module. We don't backport
the ability to query this *yet though*, but if we really wanted to
we can provide an interface for that:
For *packaging* [0] we have no other option but to currently provide
our own querying interface, that's silly though, in the future
if we extend sysctl interfaces to allow dynamic extensions we
could just peg what we need also within the backports module to
allow seemless integration. With shiny new *kernel integration*
support [1] though we can enable cherry picking the sysctl components,
and apply it to the older kernel -- however this would pose a change
in compartamentalized backporting strategy as currently used. It would
seem a allowing dynamic extensions to an existing sysctl interface
would be more efficient and would allow packaging to also take
advantage of this effort.
[0] https://backports.wiki.kernel.org/index.php/Documentation/packaging
[1] https://backports.wiki.kernel.org/index.php/Documentation/integration
commit 960fb622f85180f36d3aff82af53e2be3db2f888
Author: Eric Dumazet <edumazet@google.com>
Date: Sun Nov 16 06:23:05 2014 -0800
net: provide a per host RSS key generic infrastructure
RSS (Receive Side Scaling) typically uses Toeplitz hash and a 40 or 52 bytes
RSS key.
Some drivers use a constant (and well known key), some drivers use a random
key per port, making bonding setups hard to tune. Well known keys increase
attack surface, considering that number of queues is usually a power of two.
This patch provides infrastructure to help drivers doing the right thing.
netdev_rss_key_fill() should be used by drivers to initialize their RSS key,
even if they provide ethtool -X support to let user redefine the key later.
A new /proc/sys/net/core/netdev_rss_key file can be used to get the host
RSS key even for drivers not providing ethtool -x support, in case some
applications want to precisely setup flows to match some RX queues.
Tested:
myhost:~# cat /proc/sys/net/core/netdev_rss_key
11:63:99:bb:79:fb:a5:a7:07:45:b2:20:bf:02:42:2d:08:1a:dd:19:2b:6b:23:ac:56:28:9d:70:c3:ac:e8:16:4b:b7:c1:10:53:a4:78:41:36:40:74:b6:15:ca:27:44:aa:b3:4d:72
myhost:~# ethtool -x eth0
RX flow hash indirection table for eth0 with 8 RX ring(s):
0: 0 1 2 3 4 5 6 7
RSS hash key:
mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py \
/home/mcgrof/linux-next /home/mcgrof/build/backports-20141117
Copy original source files ...
Applying patches from patches to /home/mcgrof/build/backports-20141117
Modify Kconfig tree ...
Rewrite Makefiles and Kconfig files ...
Done!
real 1m28.499s
user 13m25.112s
sys 0m47.804s
mcgrof@drvbp1 ~/build/backports-20141117 $ time \
/home/mcgrof/backports/devel/ckmake --allyesconfig
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.62 [ OK ]
4 3.3.8 [ OK ]
5 3.4.104 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.58 [ OK ]
12 3.11.10 [ OK ]
13 3.12.31 [ OK ]
14 3.13.11 [ OK ]
15 3.14.22 [ OK ]
16 3.15.10 [ OK ]
17 3.16.6 [ OK ]
18 3.17.1 [ OK ]
19 3.18-rc1 [ OK ]
real 42m18.874s
user 1179m40.500s
sys 138m54.452s
Cc: Eric Dumazet <edumazet@google.com>
Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
When unloading mac80211 on the default kernel which is currently
shipped in Ubuntu 14.04 this commit causes a kernel error message. Now
we check if the list was deleted before and only do so if it was not
done before. Ubuntu probably backported this patch in their kernel.
commit 97666f936e0656a1b28c40cc33981a8db65e1a11
Author: Hauke Mehrtens <hauke@hauke-m.de>
Date: Sun Nov 16 14:23:24 2014 +0100
headers: delete the list in unregister_netdevice_many()
This file is now copied from the kernel and we do not have to ship an
own version. Coping this from the kernel is safe because it only
contains constants.
commit bda1096b3dfe00f19b30fc85f282b2a9ad2f67f0
Author: Felix Fietkau <nbd@openwrt.org>
Date: Sun Nov 16 14:39:58 2014 +0100
backports: add include/uapi/linux/pci_regs.h to copy-list
This is needed by bluetooth and ieee802154.
This is needed by mac80211_hwsim.
The code was copied from kernel 3.4.
This is needed by bluetooth.
this is needed by bluetooth.
unregister_netdevice_many() now deletes the list after running, in the
earlier days mac80211 and so on, did this on their own. We extended the
old unregister_netdevice_many() function for all kernel versions that
do not have a fixed unregister_netdevice_many().
This is used by the saa7134-alsa.c driver.
This is used in some places.
This is used by the igb driver.
This removes some used stuff from linux/skbuff.h.
The backported (<3.9) version of hlist_for_each_entry_rcu and
hlist_for_each_entry_safe uses the new macro hlist_entry_safe. It is called
with an ACCESS_ONCE parameter for the first parameter ptr. This disallows
merging of the two loads which the current version of the macro uses.
This is problematic because this macro must only generate one load. Otherwise
with two contexts (or CPUs) following could happen:
1. context 1 fetches the ptr to the last entry in hlist_entry_safe() and
accepts this non-NULL ptr
2. context 2 deletes the last entry and terminates the list with NULL
3. context 1 re-fetches the pointer, doesn't check for zero, calculates the
entry based on a NULL pointer
4. context 1 crashes because it tries to load/write data from/to the invalid
address
Instead use a single load to a temporary variable and do the NULL-check and
calculation based on that one. This is also the approach used in the current
Linux versions and was introduced by Paul E. McKenney.
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
I intend to use this for a new driver
This fix was originally provided by Johannes. This replaces
the linker adhoc fix to match more with what we do upstream
without requiring the use of HOSTLOADLIBES.
This enables support for using the backports project
to integrate device drivers from a future version of Linux
into an older version of Linux. What you end up seeing is
a backports submenu when configuring your kernel and the
ability to select specific device drivers from subsystems
supported through the Linux backports project.
At this time enabling one device driver from a future version
of Linux will require using only the latest version of the
subsystem modules and other subsystem drivers. For example
enabling cfg80211 and mac80211 from a future version of Linux
will require you to only use future version of the respective
device drivers. In order to enable the backported version of
802.11 drivers for example, you will have to enable first:
Networking support -->
Wireless -->
But under that menu disable all options, then jump to the backports
submenu to now enable:
Backports -->
cfg80211
mac80211
Wireless LAN --->
etc
You build these device drivers modular or built-in to the kernel.
Integration support requires only slight modifications to the original
kernel sources, one to the top level Kconfig to add our entry, and also
the top level Makefile to enable backports code to be part of the
built-in vmlinux.
Support for integration takes advantage over the existing infrastructure
added by Johannes to keep track of each indvidual change done by the
backports infrastructure if --gitdebug is used.
mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean \
/home/mcgrof/linux-next /home/mcgrof/build/backports-20141023
Applying patches from patches to /home/mcgrof/build/backports-20141023
Done!
real 1m27.942s
user 13m23.752s
sys 0m47.608s
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.62 [ OK ]
4 3.3.8 [ OK ]
5 3.4.104 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.58 [ OK ]
12 3.11.10 [ OK ]
13 3.12.31 [ OK ]
14 3.13.11 [ OK ]
15 3.14.22 [ OK ]
16 3.15.10 [ OK ]
17 3.16.6 [ OK ]
18 3.17.1 [ OK ]
19 3.18-rc1 [ OK ]
real 42m44.838s
user 1190m5.092s
sys 140m37.208s
