path: root/backport/defconfigs
2016-04-30defconfig: brcmsmac: remove selection of BCMA GPIOArend van Spriel
BCMA GPIO driver now relies on functionality that is available since v4.5. Just drop GPIO which disables brcmsmac led functionality so it can be backported to kernels prior to 4.5. Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-15defconfigs: update media defconfigHauke Mehrtens
2015-11-15defconfigs: update wifi defconfigsHauke Mehrtens
This adds the new driver CPTCFG_RTL8XXXU and removes the config option for CPTCFG_B43_PCMCIA. pcmcia support in b43 is now done in ssb. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-09-22defconfig: fix ieee802154 defconfigHauke Mehrtens
This removes the old driver IEEE802154_FAKEHARD and adds two new drivers. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-06-15backports: add mediatek mt7601u driverHauke Mehrtens
2015-04-06backports: add USB ZD1201 driverHauke Mehrtens
This wifi driver was missing before. This driver uses the cfg80211 so we should ship it. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-06backports: add Atmel at76c50x PCI and PCMCIA driverHauke Mehrtens
2015-04-06backports: add Cisco/Aironet (AIRO) driverHauke Mehrtens
2014-10-25defconfig: add some new wifi driversbackports-20141003Hauke Mehrtens
2014-10-25defconfig: update media defconfigHauke Mehrtens
2014-10-20defconfigs: enable PCIe support in brcmfmac defconfigArend van Spriel
In 3.17 kernel the brcmfmac supports PCIe host interface. So enable support when selecting defconfig-brcmfmac. Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-09-06backports: remove regulator driversHauke Mehrtens
It looks like no one is using the regulator drivers and maintaining them costs some time because they often break. When someone needs a specific driver please send a patch adding this one specific driver, maintaining a small subset is not a problem, but maintaining all is a big task. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-08backports: add RSI driverHauke Mehrtens
This adds Redpine Signals Inc 91x WLAN driver support Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: set defconfig media to mbackports-20140501Hauke Mehrtens
Set the default option to module. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-06-02backports: update default configsHauke Mehrtens
Remove some config options which were not available in the kernel any more and add some missing new options. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-05-01backports: remove IWLWIFI_P2P from iwlwifi defconfigJohannes Berg
This symbol is obsolete, it was removed upstream, so just remove it from the defconfig file as well. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-04-17backports: add hwsim defconfigJohannes Berg
This can be useful for pure testing scenarios. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-02-01backports: enable igb and add defconfigStefan Assmann
Add defconfig and necessary files to copy-list. Signed-off-by: Stefan Assmann <sassmann@kpanic.de> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-11-21backports: add defconfig for wcn36xxJason Mobarak
Signed-off-by: Jason Mobarak <jam@cozybit.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-28backports: Add a defconfig for ath9k debuggingSujith Manoharan
Signed-off-by: Sujith Manoharan <c_manoha@qca.qualcomm.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-27backports: add some new options to defconfigs/wifibackports-20131018Hauke Mehrtens
This adds ath10k, wcn36xx and rt3573 to the default wifi config. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-23backports: remove DRM driverHauke Mehrtens
Maintaining the DRM driver takes a lot of recourses as there they are depending on many API changes done to the core kernel code and currently we do not have that many recourses to follow them. On the other side one needs also new userspace drivers to make use of the new features added to the DRM kernel drivers and it is not easy to update the X drivers. Therefore we came to the conclusion to remove the drm drivers for now. There were also some problems with some DRM drivers, like the Intel i915 driver caused kernel panic on some systems and was probably only usable on some very recent kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-08-27backports: add defconfig for cw1200Hauke Mehrtens
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: add some new regulator drivers to default configHauke Mehrtens
2013-08-15backports: add defconfig for wwan device driversPatrick Ziegler
Signed-off-by: Patrick Ziegler <patrick.ziegler@fh-kl.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-07-11backports: add ath10k defconfigLuis R. Rodriguez
2013-06-19backports: add ieee802154Hauke Mehrtens
This adds the ieee802154 subsystem. == ckmake-report.log == 1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.79 [ OK ] 18 3.1.10 [ OK ] 19 3.10-rc1 [ OK ] 20 3.2.45 [ OK ] 21 3.3.8 [ OK ] 22 3.4.46 [ OK ] 23 3.5.7 [ OK ] 24 3.6.11 [ OK ] 25 3.7.10 [ OK ] 26 3.8.13 [ OK ] 27 3.9.3 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-06-13backprots: add default config with all wifi driversbackports-20130607Hauke Mehrtens
This default config contains all wifi drivers. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-13backports: add default config for alxHauke Mehrtens
2013-06-13backports: add defconfigs for Atheros wifi driversHauke Mehrtens
This adds default configs for Atheros wifi drivers. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-05-19backports: add CPTCFG_CFG80211_WEXTbackports-20130513Hauke Mehrtens
Without wext support we will get lots of complains about iwconfig not working. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-05-19backports: add defconfig for broadcom driversHauke Mehrtens
This adds a default config for the broadcom wifi drivers. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-05-19backports: defconfig for rtlwifi familyLarry Finger
Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-04-13backports: add media subsystem driversLuis R. Rodriguez
This adds backport support for all media subsystem drivers. This is enabled only for >= 3.2. Some media drivers rely on the new probe deferrral mechanism (-EPROBE_DEFER see commit d1c3414c), those are only enabled for kernels >= 3.4. Some media drivers only depend on the regulatory but since we only support backporting the regulatory on kernels >= 3.4 we only enable those media drivers for >= 3.4. This backports 433 media drivers. 1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.65 [ OK ] 18 3.1.10 [ OK ] 19 3.2.38 [ OK ] 20 3.3.8 [ OK ] 21 3.4.32 [ OK ] 22 3.5.7 [ OK ] 23 3.6.11 [ OK ] 24 3.7.9 [ OK ] 25 3.8.0 [ OK ] 26 3.9-rc1 [ OK ] real 39m35.615s user 1068m47.428s sys 155m55.657s Cc: linux-media@vger.kernel.org Cc: linux-kernel@vger.kernel.org Cc: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-13backports: add support for voltage / current regulator driversLuis R. Rodriguez
This backports the latest regulator drivers for kernels >= 3.4. We enable the regulator only on kernels >= 3.4 given that it relies on the new probe deferral mechanism which would otherwise mean having to support drivers that do not probe correctly. Note that 3.2 had a base regulator implementation but that was just stubs. I did look into a way to upgrade the core kernel regulator but given that it relies on late_initcall() and core_initcall() we can't update this part of the kernel. I even looked at using ksplice for this but it seems ksplice can't be used to update init sections on the vmlinux ELF. I also haven't much updates to these routines since 3.4 except for 86f5fcfc. 1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.65 [ OK ] 18 3.1.10 [ OK ] 19 3.2.38 [ OK ] 20 3.3.8 [ OK ] 21 3.4.32 [ OK ] 22 3.5.7 [ OK ] 23 3.6.11 [ OK ] 24 3.7.9 [ OK ] 25 3.8.0 [ OK ] 26 3.9-rc1 [ OK ] real 39m35.615s user 1068m47.428s sys 155m55.657s Cc: Liam Girdwood <lgirdwood@gmail.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: linux-kernel@vger.kernel.org Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-08build: add NFC defconfig fileThierry Escande
Signed-off-by: Thierry Escande <thierry.escande@linux.intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-06backports: really enable DRMJohannes Berg
This was previously not really enabled because it wasn't in the Makefile.kernel, add it there. Also add a defconfig file for all DRM drivers. This passes ckmake --defconfig drm: 1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.65 [ OK ] 18 3.1.10 [ OK ] 19 3.2.38 [ OK ] 20 3.3.8 [ OK ] 21 3.4.32 [ OK ] 22 3.5.7 [ OK ] 23 3.6.11 [ OK ] 24 3.7.9 [ OK ] 25 3.8.0 [ OK ] 26 3.9-rc1 [ OK ] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-04build: add defconfig filesJohannes Berg
This enables users to more easily select the driver that they need, and us to ship default configurations that we prefer for that driver. Add iwlwifi as the first example. Signed-off-by: Johannes Berg <johannes@sipsolutions.net>
