1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.69 [ OK ]
4 3.3.8 [ OK ]
5 3.4.108 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.84 [ OK ]
12 3.11.10 [ OK ]
13 3.12.44 [ OK ]
14 3.13.11 [ OK ]
15 3.14.48 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.18 [ OK ]
20 3.19.8 [ OK ]
21 4.0.8 [ OK ]
22 4.1.2 [ OK ]
23 4.2-rc1 [ OK ]
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc8 [ OK ]
manual changes done to:
patches/collateral-evolutions/media/0005-dma-no-sync/v4l2.patch
NFC_PN544_I2C uses devm_gpiod_get_index() now which is not available in
kernel < 3.17.
NFC_NXP_NCI_I2C uses the linux/gpio/consumer.h which is not available
in kernel version < 3.13
VIDEO_FB_IVTV uses arch_phys_wc_add(), arch_phys_wc_del() and
pat_enabled() now which are not available in older kernel versions.
The media framework now uses the frame vector code which is only
available from kernel 4.2 onwards. This backports the code.
The get_user_pages_locked() function is needed by the frame vector code
which will be added in the next patch. While adding that, this patch
also replaces the get_user_pages_unlocked() function with the original
version from the next kernel.
With kernel 3.12 a new locking was added to struct tty_struct. This
patch makes the code use the old locking.
The new locking was added in this commit:
commit 6a1c0680cf3ba94356ecd58833e1540c93472a57
Author: Peter Hurley <peter@hurleysoftware.com>
Date: Sat Jun 15 09:14:23 2013 -0400
tty: Convert termios_mutex to termios_rwsem
The led_trigger_remove() function is exported on older kernel versions,
but there is no pubic prototype for this function. Now the first driver
makes use of this function and this patch adds the prototype.
There is no LINUX_BACKPORT() guard here because we want it to point to
the original function which is exported normally.
It should be save to just copy it.
This was added in this upstream commit:
commit 9961127d4bce6325e9a0b0fb105e0c85a6c62cb7
Author: Vincent Cuissard <cuissard@marvell.com>
Date: Thu Jun 11 11:25:47 2015 +0200
NFC: nci: add generic uart support
This is not used by any code in backports and was also removed from the
mainline kernel.
In the mainline kernel the kernel module parameter locking is not
protected by a global lock any more, but each module has its own lock
now. This resulted in some changes in the api. This patch converts
calls to the new api to the old one.
This backports the changes done in this commit:
commit b51d23e4e9fea6f264d39535c2a62d1f51e7ccc3
Author: Dan Streetman <ddstreet@ieee.org>
Date: Wed Jun 17 06:18:52 2015 +0930
module: add per-module param_lock
The new nfcmrvl driver needs a new platform data header file.
st21nfcb.h was renamed in the upstream kernel, do the same for
backports. This rename was done in this commit:
commit ed06aeefdac348cfb91a3db5fe1067e3202afd70
Author: Christophe Ricard <christophe.ricard@gmail.com>
Date: Tue Jun 9 22:26:05 2015 +0200
nfc: st-nci: Rename st21nfcb to st-nci
The same include guard is also used in backport/backport-include
/asm-generic/barrier.h which prevents both files from being included at
the same time.
Reported-by: Martin Tippmann <martin.tippmann@gmail.com>
The file net/bluetooth/hci_ldisc.c contains references to tty->termios.
These changed from pointer to instance in 3.7.0. This patch backports
all references by introducing kernel version defines.
Signed-off-by: Florian Grandel <fgrandel@gmail.com>
Usage of the bt_tx_busylock variable was already patched but not the
declaration which caused a compile warning. This patch introduces a
define statement that also excludes the variable declaration.
The net/route.h header is missing when compiling against the android msm
kernel. Explicitly add it here to make the kernel compile.
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
Using expression is pretty flexible, in this case we
don't want that flexibility as it can override any
struct who also uses the same variable name. For a
specific example of the issue refer to the netdev-ops
demo git tree [0] which provide an example of the issue
with two SmPL rules.
We keep the expression on the last rule on NETLINK_CB(skb)
given that we know only an skb can possibly be used on it.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc8 [ OK ]
The failure on 4.1 is not related to this change,
its because we are using 4.1-rc1, it fails because of
the missing tty_set_termios() is not exported,
4.1-rc4 works.
[0] https://github.com/mcgrof/netdev-ops.git
Cc: cocci@systeme.lip6.fr
When building the kernel there are lots of warnings like this:
drivers/net/wireless/ath/ath10k/ce.c:404:21: warning: unused variable ‘ar_pci’ [-Wunused-variable]
struct ath10k_pci *ar_pci = ath10k_pci_priv(ar);
They are caused by an empty lockdep_assert_held() which does nothing
with this variable in kernel version < 3.9. This patch replaces this
macro with the version from a recent kernel and silence this warning.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc1 [ FAIL ]
Only kernel 4.1-rc1 will fail, because tty_set_termios() is not
exported, 4.1-rc4 works.
drivers/media/platform/vim2m.c
On kernel version < 3.4 we have to include linux/interrupt.h, because
it otherwise results in a long compile errors about missing HI_SOFTIRQ
for example.
The mt7601u driver makes use of __field_struct which was added in Linux
commit 4d4c9cc83. It is hard to backport this feature, so just remove
the code using it on kernel version < 3.16.
This is needed by the mt7601u driver.
The mt7601u driver makes use of some of these functions and they are
not available on kernel version < 3.19.
tty_set_termios() was not exported any more in kernel 4.0-rc1 (commit
632f32e21) and exported again in kernel 4.1-rc2 (commit b00f5c2dc).
This patch adds the backport for kernel 4.0.X, we can not detect kernel
4.1-rc1, which would also need this fix, so bluetooth will have a
compile error on kernel 4.1-rc1, kernel 4.1-rc2 and more recent
versions will work.
More v4l drivers are now accessing the vidioc_expbuf function pointer
in struct v4l2_ioctl_ops which we can not backport to kernel < 3.5.
This adds some more checks around the places.
We should convert this to an spatch.
Before we only copied the hdmi.h header file and not the driver. Now
some other drivers need the hdmi driver code, also copy it now too.
The driver VIDEO_ADP1653 now includes linux/gpio/consumer.h which is
not available in kernel versions < 3.13. This patch makes the driver
depend on kernel version >= 3.13.
The VIDEO_ADV7604 driver now makes use of
devm_gpiod_get_index_optional() which gets less parameters in older
kernel versions. This makes the driver depend on kernel >= 3.17. In
addition also the VIDEO_COBALT has to depend on this kernel version
because it selects VIDEO_ADV7604.
The drivers MEDIA_TUNER_FC2580 and MEDIA_TUNER_TUA9001 are using
devm_regmap_init_i2c() which is only believable on kernel >= 3.3, add a
dependency to the driver.
The drivers DVB_M88DS3103 and DVB_TS2020 are accessing some member in
struct regmap_config which is not available in kernel version < 3.8.
These drivers are getting selected by some other drivers, which are now
also depending on kernel >= 3.8, otherwise KConfig would ignore the
dependency on kernel >= 3.8
VIDEO_COBALT selects VIDEO_ADV7604, but VIDEO_ADV7604 should only be
build on kernel versions >= 3.13. On older kernel versions this causes
this warning which makes Kconfig ignore the dependency on kernel version
>= 3.13.
warning: (VIDEO_COBALT) selects VIDEO_ADV7604 which has unmet direct
dependencies (MEDIA_SUPPORT && !KERNEL_3_13 && m && <choice> &&
VIDEO_V4L2 && I2C && VIDEO_V4L2_SUBDEV_API && GPIOLIB)
mac80211 makes use of the new AEAD crypto api since commit 957e0fe629.
This patch provides a backport layer which converts the new API to the
old one used in older kernel versions. This backport is based on this
mainline commit: 996d98d85.
Cc: Johannes Berg <johannes.berg@intel.com>
This patch, adding a missing include to rhashtable.c, is not needed any
more, because it went into upstream in commit 6d7954130.
The uuid member was added to the struct mei_cl_device_id in this commit:
commit c93b76b34b4d8dbe8e3443eb27e49ac60034342b
Author: Tomas Winkler <tomas.winkler@intel.com>
Date: Thu May 7 15:54:02 2015 +0300
mei: bus: report also uuid in module alias
rt6_nexthop() got an additional parameter in commit 2647a9b0. Instead
of only backporting it for kernel < 3.10 do it now for kernel version <
4.2.
This additional include is needed to prevent this error with kernel 3.10:
In file included from /home/hauke/compat-wireless/tmp/backport-include/linux/wait.h:3:0,
from include/linux/mmzone.h:9,
from include/linux/gfp.h:4,
from include/linux/kmod.h:22,
from include/linux/module.h:13,
from /home/hauke/compat-wireless/tmp/backport-include/linux/module.h:3,
from /home/hauke/compat-wireless/tmp/drivers/nfc/mei_phy.c:21:
/home/hauke/compat-wireless/tmp/drivers/nfc/mei_phy.c: In function ‘mei_nfc_send’:
include/linux/wait.h:296:33: error: ‘TASK_INTERRUPTIBLE’ undeclared (first use in this function)
prepare_to_wait(&wq, &__wait, TASK_INTERRUPTIBLE); \
On kernel 3.0 we have to include linux/interrupt.h, because it
otherwise results in a long compile errors about missing HI_SOFTIRQ for
example. It looks like it was not possible to activate tracing without
this patch on these drivers at all.
Commit 8e879bf1f in backports converted some bluetooth patches into an
spatch. There was a problem in this conversion, the second argument is
not struct socket, but struct sock. This causes some warnings in the
kernel build.
Cc: Luis R. Rodriguez <mcgrof@do-not-panic.com>
This refresh patches again after application of all pending
patches.
mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --verbose \
--refresh /home/mcgrof/linux-next /home/mcgrof/build/backports-20150525
real 3m25.658s
user 27m6.472s
sys 3m38.704s
mcgrof@drvbp1 ~/build/backports-20150525 $ time \
/home/mcgrof/backports/devel/ckmake --allyesconfig
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc1 [ OK ]
real 53m59.426s
user 1440m34.548s
sys 219m41.952s
pycocci is now part of Coccinelle upstream. Coccinelle has a plan
to actually extend multithreaded support to enable us to not have
to script this out. Until then pyccoci is used and I'll sync both
solutions up as there is a bit of latency between a coccinelle release
and what we may need from pycocci.
Please send patches or report issues about pycocci to the coccinelle
mailing list.
This commit syncs pycocci with the upstream pycocci with just one
minor change introduced:
commit cf8ef1aee7d40cddfee0f8707b2f481eb8258b4d
Author: Luis R. Rodriguez <mcgrof@suse.com>
Date: Fri May 29 15:15:57 2015 -0700
pycocci: update Python script to print errors clearly
When you run into errors with the pycocci script errors
seem cryptic, fix this. While at it also spit out what the
script will run, as typically when debugging you just want
to runt he same commands on your own.
For instance, when run on a 32 core machine you'll now see:
mcgrof@drvbp1 ~/linux-next (git::master)$ time pycocci rename-dma.cocci ./
spatch --sp-file rename-dma.cocci --in-place --recursive-includes --relax-include-path --use-coccigrep --timeout 120 --dir ./ -max 32 -index 0
spatch --sp-file rename-dma.cocci --in-place --recursive-includes --relax-include-path --use-coccigrep --timeout 120 --dir ./ -max 32 -index 27
real 0m50.074s
user 14m50.168s
sys 2m8.260s
This replaces the 436 line of unified diff with 152
lines of grammar Coccinelle SmPL patch. SmPL patch
equivalence proof tests reveals only cosmetic changes
between using Coccinelle SmPL and unified diff as shown
below. The difference shown are the results of two
trees, one in which we applied the SmPL patch, and another
in which the old unified patch series were used. This
gives us an idea of what Coccinelle did differently.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc1 [ OK ]
mcgrof@ergon ~/backports (git::master)$ time \
./gentree.py --clean --prove-cocci \
patches/collateral-evolutions/network/0054-struct-proto_ops-sig.cocci \
/home/mcgrof/linux-next/ /home/mcgrof/build/backports-20150525
Copy original source files ...
Applying patches from patches to
/home/mcgrof/build/backports-20150525 ...
Proving Coccinelle SmPL patch: 0054-struct-proto_ops-sig.cocci
Aggregating patch for Coccinelle SmPL 0054-struct-proto_ops-sig proof: ieee802154.patch
Aggregating patch for Coccinelle SmPL 0054-struct-proto_ops-sig proof: nfc.patch
Aggregating patch for Coccinelle SmPL 0054-struct-proto_ops-sig proof: bluetooth.patch
Review the difference between what the tree looks like
by applying your SmPL patch, then reverting that and
only applying your the patches in the patch series.
Change directory to /home/mcgrof/build/backports-20150525 and run 'git diff'
diff stat of the changes:
net/bluetooth/hci_sock.c | 11 +++++------
1 file changed, 5 insertions(+), 6 deletions(-)
Done!
real 0m21.965s
user 0m45.947s
sys 0m4.072s
Now when I change directory to /home/mcgrof/build/backports-20150525 and
run 'git diff' I get:
diff --git a/net/bluetooth/hci_sock.c b/net/bluetooth/hci_sock.c
index 9326bc8..9ca0166 100644
--- a/net/bluetooth/hci_sock.c
+++ b/net/bluetooth/hci_sock.c
@@ -956,7 +956,8 @@ static int hci_sock_recvmsg(struct socket *sock,
struct msghdr *msg, size_t len,
#if LINUX_VERSION_CODE < KERNEL_VERSION(4,1,0)
static int backport_hci_sock_recvmsg(struct kiocb *iocb, struct socket
*sock,
- int flags){
+ int flags)
return hci_sock_recvmsg(sock, msg, len, flags);
#endif /* LINUX_VERSION_CODE < KERNEL_VERSION(4,1,0) */
@@ -1198,7 +1199,8 @@ drop:
static int backport_hci_sock_sendmsg(struct kiocb *iocb, struct socket
*sock,
- struct msghdr *msg, size_t len){
+ struct msghdr *msg, size_t len)
return hci_sock_sendmsg(sock, msg, len);
@@ -1360,12 +1362,9 @@ static const struct proto_ops hci_sock_ops = {
.getname = hci_sock_getname,
#if LINUX_VERSION_CODE >= KERNEL_VERSION(4,1,0)
.sendmsg = hci_sock_sendmsg,
-#else
- .sendmsg = backport_hci_sock_sendmsg,
-#endif /* LINUX_VERSION_CODE >= KERNEL_VERSION(4,1,0) */
-#if LINUX_VERSION_CODE >= KERNEL_VERSION(4,1,0)
.recvmsg = hci_sock_recvmsg,
#else
+ .sendmsg = backport_hci_sock_sendmsg,
.recvmsg = backport_hci_sock_recvmsg,
.ioctl = hci_sock_ioctl,
Acked-by: Julia Lawall <julia.lawall@lip6.fr>
This modifies we backport the struct proto_ops and struct proto
declarations from adding #idefs around the function prototype
arguments to just declaring our own new backport callback for
older kernels with the extra argument which calls the the
upstream function. This is done because we cannot write an
SmPL grammar patch to backport the collateral evolution as we
do it now. The backport strategy we provide now is equivalent
in terms of functionality but also a lot more clear, it also
leaves the upstream code unmodified as much as possible, this
should enable anyone reviewing the code to be able to more
easily determine exactly what is going on.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc1 [ OK ]
real 53m48.791s
user 1437m15.048s
sys 217m20.652s
Both bt_sock_recvmsg() and bt_sock_stream_recvmsg() are used
within bluetooth code but the backport actually required is only
for the struct proto_ops and struct proto sendmsg and recvmsg
callbacks. The bt_sock_recvmsg() and bt_sock_stream_recvmsg()
are not callbacks, they are exported but are used all within
the code we provide and carry.
This will help simplify the network/0054-struct-proto_ops-sig
collateral evolution port to Coccinelle SmPL.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.68 [ OK ]
4 3.3.8 [ OK ]
5 3.4.107 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.75 [ OK ]
12 3.11.10 [ OK ]
13 3.12.40 [ OK ]
14 3.13.11 [ OK ]
15 3.14.39 [ OK ]
16 3.15.10 [ OK ]
17 3.16.7 [ OK ]
18 3.17.8 [ OK ]
19 3.18.12 [ OK ]
20 3.19.5 [ OK ]
21 4.0.0 [ OK ]
22 4.1-rc1 [ OK ]
The brcmfmac driver now uses the ACPI_COMPANION() macro which was
introduced in v3.13 kernel. This provides a backport of that macro
for older kernels.
Signed-off-by: Arend van Spriel <arend@broadcom.com>
Signed-off-by: Jonathan Liu <net147@gmail.com>
Signed-off-by: Stefan Assmann <sassmann@kpanic.de>
