Overflow macros are useful for further backports
Signed-off-by: Felix Fietkau <nbd@nbd.name>
Function memcmp is implicit declaration on kernel 4.9.88 ARM platform.
backport-include/keys/asymmetric-type.h uses function memcmp but its
caller compat/verification/verify.c and all its related header files
do not include string.h. The header file is usually included from
arch/arm/include/asm, but in this configuration, it doesn't. We need
to be safe and insure string.h is there.
Signed-off-by: Winnie Chang <winnie.chang@cypress.com>
If compiling on 3.13, struct genl_family isn't actually
struct backport_genl_family, and then family->family
doesn't exist. In other cases, it's actually necessary
to update it, so add an #ifdef with the same logic as
the override from genl_family -> backport_genl_family.
Family ID from the original family struct will be used when building
genl messages (sent as nlmsg_type), so the new id should be updated in
the original (older kernel format) family struct too
Signed-off-by: Aaron Komisar <aaron.komisar@tandemg.com>
The spatch tool made an incompatible change in the
attribute syntax, adjust to that and require the
new version.
In kernel 4.15 the field sk_pacing_shift was introduced to allow
(wifi) drivers to change the behaviour of TSQ. In 4.16 a helper
function was added which mac80211 is using. So backport the helper
which is just a stub for kernels prior to 4.15.
Cc: Eric Dumazet <edumazet@google.com>
Signed-off-by: Arend van Spriel <arend.vanspriel@broadcom.com>
This macro definition was added in 4.17-rc1 and used by mac80211
so add it to backport.
Few patches do not apply to source code in v4.17-rc1 so updating
those.
This seems to be generated by newer kernels when building,
add it to the gitignore.
linux-stable 4fa8bc949de11c99ee2433c602d43f87c452f4f2 renamed
*-asn1.[ch] files to *.asn1.[ch]. Make the corresponding change
for backports.
This adds the staging Realtek drivers which are making use of cfg80211
and mac80211.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
The mt76 driver uses the devm_led_classdev_register() function which
was added in kernel 4.1, do not build this driver on older kernel
versions.
It is probably not so hard to make this driver also work on older kernel
versions.
In Linux commit d19c3d91d1cf3 ("Revert "net: use lib/percpu_counter API
for fragmentation mem accounting"") the sub_frag_mem_limit() and
add_frag_mem_limit() functions were changed back to the old versions.
Commit 42ab19ee90292 ("net: Add extack to upper device linking") which
added an extra parameter to netdev_upper_dev_link() was added with
kernel 4.15 and was not backported to kernel 4.14, activate this
backport already for kernel 4.14.
Fixes: 8cdd85766293 ("backports: add netdev_upper_dev_link() extack argument")
This function was added in commit d6d29896c665d ("timekeeping: Provide
timespec64 based interfaces"). We can just use the 32 bit version
instated as the rest was already backported in backports commit
ea8b7cd797ca0c ("backports: deal with struct timespec64 changes)".
This function was added in commit dbe7aa622db96b ("timekeeping: Provide
y2038 safe accessor to the seconds portion of CLOCK_REALTIME") and is
used by multiple realtek drivers.
Older kernel versions do not have the include linux/nospec.h with the
function array_index_nospec, provide a dummy implementation for these
kernel versions and forward the call the the real version for capable
kernel versions.
DEFINE_DEBUGFS_ATTRIBUTE and debugfs_create_file_unsafe() were
introduced in mainline commit c6468808149 ("debugfs: add support for
self-protecting attribute file fops"), but on older kernel versions
where we do not have this extra security in debugfs we can use the older
functions instead.
This prevents some compile problems in rtlwifi.
Without this patch I am getting a compile error in
drivers/net/wireless/realtek/rtlwifi/rtl8821ae/table.c with multiple
kernel versions because BUILD_BUG_ON_ZERO is implicitly defined.
__poll_t was added for kernel 4.15 in commit 8ced390c2b ("define
__poll_t, annotate constants"), add it here for older kernel versions.
Multiple drivers are using this type.
The POLL constants are getting replaced with the EPOLL constants. In
this process commit e78cd95bebd9 ("preparation to switching ->poll() to
returning EPOLL...") added an additional include to linux/poll.h. Some
drivers make use of this indirect include now and fail to compile
without it.
Older kernel versions do not define all the EPON constants so add them
if they are not available.
Use the unsigned long parameters on kernel versions < 4.15 for the
DEFINE_TIMER callback. This was changed in Linux mainline commit
24ed960abf1d ("treewide: Switch DEFINE_TIMER callbacks to struct
timer_list *")
DEFINE_TIMER only has 2 parameters since kernel commit 1d27e3e2252ba
("timer: Remove expires and data arguments from DEFINE_TIMER") which was
added with kernel 4.15. Add a version which translates between the new
and the old API.
No manual changes needed.
Mistakenly, the percpu.h file was added to a new backport-include
directory at the root. It should be in the proper location at
backport/backport-include instead. Fix that.
Fixes: a4c44dbee35d ("backport: implement alloc_percpu_gfp() for < 3.18.")
Signed-off-by: Luca Coelho <luciano.coelho@intel.com>
mac80211 now uses the alloc_percpu_gfp() function, which doesn't exist
in kernels older than 3.18. Backport it accordingly.
Signed-off-by: Sara Sharon <sara.sharon@intel.com>
The verification code has some large data variables that are allocated
in the stack. Increase the maximum stack frame size in the compiler
check slightly (from 1024 to 1280) to prevent harmless warnings.
The verification code was copied from userspace code which includes
stddef.h. In the kernel, this header should not be included, so
remove those cases.
Fixes: 988e2af4b7a0 ("backports: add signature verification code")
There is a typo in the timekeeping.h backport, fix that.
Additionally, fix the gfp.h file tha has a copy/paste issue where
__BACKPORT_TIMKEEPING_H is used instead of __BACKPORT_LINUX_GFP_H.
Some of the code in bug.h was moved into a new build_bug.h file. Add
a backport that includes bug.h in the case of older kernels.
The change that used to be patched into the pkcs7_verify.c file is now
part of newer kernels, so we don't need to patch it anymore. Remove
this hunk from verify.patch accordingly.
The genl_dump_check_consistent() function was changed in v4.15 to use
only two arguments. The family is not needed anymore, because we were
erroneously subtracting the header size and that was fixed in v4.15.
Since the family was only used to check the header size, we can create
a dummy with hdrsize = 0, which will allow us to call the old version
of the function. There is a good side-effect to doing this: the bug
is going to be fixed, because with hdrsize = 0 we will not subtract
anything and it will have the same effect as the fix.
The alloc/free_bucket_spinlocks() functions were moved to a new lib
file, namely bucket_locks.c. Add an auto-backport for the
bucket_locks.c file and move the patching of the code that moved from
rhashtable to bucket_locks.c.
This function was introduced in v4.9 and added to 3.12.69, 4.4.37 and
4.8.13.
If CONFIG_THERMAL is not enabled, we don't have to add all backports
for the thermal framework. Actually this doesn't even work because we
try to use thermal_zone_device_register/unregister and they are not
present in the outer kernel, causing undefined symbols warnings:
WARNING: "thermal_zone_device_register" [/home/luca/iwlwifi/stack-dev/compat/compat.ko] undefined!
WARNING: "thermal_zone_device_unregister" [/home/luca/iwlwifi/stack-dev/compat/compat.ko] undefined!
Function IS_ERR, PTR_ERR and ERR_PTR are not found. Need to include
linux/err.h to fix compiling errors.
Signed-off-by: Chi-hsien Lin <chi-hsien.lin@cypress.com>
kconf/ is built during "make defconfig-*" but not cleaned up during
"make mrproper" or "make clean". Add the clean up work to "make clean".
This is filled with family->id, which needs to be set after registering
the copy.
The stats64_fn_wrap() function was changed to be not-static so it can
be used by usbnet. This causes problems in files that don't export
it. Work around that byt just pre-declaring it before the actual
definition.
Fixes: 5a00d8489c7 ("patches: adapt the stat64 usage for usbnet")
The multicast group offset needs to be synced after registering the
family, otherwise multicast messages will use the wrong id
Adds support for the imply keyword
Backport upstream
commit 4f6265d485ea0a2507692ded8ed47b323f49587c
Author: David Ahern <dsahern@gmail.com>
Date: Fri Oct 27 17:37:12 2017 -0700
netlink: Allow ext_ack to carry non-error messages
I also never seem to have really tested unload after dumps,
and using the family->attrbuf was causing memory corruption
in the copied family.
Fix this by keeping track of the family copies separately
and actually copying the attrbuf over so the family can use
it from there.
I neglected to take into account that the spatch will also
be applied to the backport-4.12.c file itself, fix that.
The previous backport just made the code compatible, but removed
the extack functionality entirely.
By ignoring the setsockopt() and just assuming that userspace does
in fact support extack (which is true for all of wifi and in fact
all users of libnl), we can support full extack functionality even
on kernels that don't support it.
Blue on black is really hard to read, use white on black.
We used to patch this, before with the genregdb and now with
the shipped-certs.c generation - just fix it in code instead
so we don't have to deal with different patches.
