1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.62 [ OK ]
4 3.3.8 [ OK ]
5 3.4.103 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.54 [ OK ]
12 3.11.10 [ OK ]
13 3.12.27 [ OK ]
14 3.13.11 [ OK ]
15 3.14.18 [ OK ]
16 3.15.10 [ OK ]
17 3.16.2 [ OK ]
18 3.17-rc3 [ OK ]
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
pycocci failure.
While running gentree.py I got error messages such as 'Failed to
process SmPL patch
collateral-evolutions/generic/0001-group-attr/0001-group_attr_class.cocci',
due to incorrect path handling. This patch always makes gentree always
call pycocci with the absolute path to the output directory.
Signed-off-by: Jacob Siverskog <jacob@teenageengineering.com>
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.62 [ OK ]
4 3.3.8 [ OK ]
5 3.4.103 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.54 [ OK ]
12 3.11.10 [ OK ]
13 3.12.27 [ OK ]
14 3.13.11 [ OK ]
15 3.14.18 [ OK ]
16 3.15.10 [ OK ]
17 3.16.2 [ OK ]
18 3.17-rc3 [ OK ]
It looks like no one is using the regulator drivers and maintaining
them costs some time because they often break. When someone needs
a specific driver please send a patch adding this one specific driver,
maintaining a small subset is not a problem, but maintaining all is a
big task.
We only want the UTS_UBUNTU_RELEASE_ABI var when we are on a normal
Ubuntu distribution kernel and not when we are on a Ubuntu mainline
kernel. Some of the Ubuntu mainline kernel do have an invalid octal
number in this field like 031418 and we do not want to evaluate this at
all on the Ubuntu mainline kernels. All Ubuntu distribution kernel
have CONFIG_VERSION_SIGNATURE set so this way we can detect the which
type of kernel we are on.
This change was merge upstream in this commit:
commit 9baa3c34ac4e27f7e062f266f50cc5dbea26a6c1
Author: Benoit Taine <benoit.taine@lip6.fr>
Date: Fri Aug 8 15:56:03 2014 +0200
PCI: Remove DEFINE_PCI_DEVICE_TABLE macro use
This updates the kernel versions to test against to the most recent
versions.
Do not use 3.15.9, but 3.15.7 because there are some problems with the
define UTS_UBUNTU_RELEASE_ABI in the more recent kernel version, see:
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1347879
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.62 [ OK ]
4 3.3.8 [ OK ]
5 3.4.102 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.52 [ OK ]
12 3.11.10 [ OK ]
13 3.12.26 [ OK ]
14 3.13.11 [ OK ]
15 3.14.16 [ OK ]
16 3.15.7 [ OK ]
17 3.16.0 [ OK ]
Manual changes were done to:
patches/collateral-evolutions/network/0006-ieee802154-6lowpan-namespace.patch
This patch was removed:
patches/collateral-evolutions/network/0009-inet_frag_evictor.patch
This is needed by drivers/nfc/st21nfcb/i2c.c
Only backport irq_get_trigger_type on architectures that have
CONFIG_HAVE_GENERIC_HARDIRQS=y. Otherwise we end up with:
In file included from drivers/pci/msi.c:11:0:
backport/backport-include/linux/irq.h: In function 'irq_get_trigger_type':
backport/backport-include/linux/irq.h:9:9: error: implicit declaration
of function 'irq_get_irq_data' [-Werror=implicit-function-declaration]
struct irq_data *d = irq_get_irq_data(irq);
Signed-off-by: Stefan Assmann <sassmann@kpanic.de>
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.60 [ OK ]
4 3.3.8 [ OK ]
5 3.4.93 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.43 [ OK ]
12 3.11.10 [ OK ]
13 3.12.22 [ OK ]
14 3.13.11 [ OK ]
15 3.14.7 [ OK ]
16 3.15.0 [ OK ]
17 3.16-rc1 [ OK ]
Without this patch I get the following error message when compiling
against kernel 3.2, all other kernel versions work:
3.2.60/drivers/media/usb/airspy/airspy.c: In function ‘airspy_queue_setup’:
3.2.60/drivers/media/usb/airspy/airspy.c:506:2: error: implicit declaration of function ‘PAGE_ALIGN’ [-Werror=implicit-function-declaration]
sizes[0] = PAGE_ALIGN(s->buffersize);
The dma function dma_buf_vmap() is not available on kernel < 3.5,
remove the call from the media subsystem code.
Some drivers now also call the other dev_*_ratelimited() functions.
Revert this commit on kernel version < 3.7
mwifiex: card reset: enable rescan of non-removable card
mmc_rescan will scan for non-removable cards only once, hence the card
will not be rediscovered.
Signed-off-by: Andreas Fenkart <afenkart@gmail.com>
Acked-by: Bing Zhao <bzhao@marvell.com>
alloc_netdev_mqs() got a new parameter in kernel 3.17, this patch
removed it from the calls if an older kernel is used. This is safe,
because older kernel versions do not need it.
This driver needs a new header file, which is not in the kernel < 3.17.
In kernel version < 3.17 wait_on_bit() takes an action as a parameter,
which contains a schedule() or io_schedule() call in most cases. For
such calls wait_on_bit() was changed to not take an action but execute
schedule() action. This patch backports the new behavior to old kernel
versions.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.60 [ OK ]
4 3.3.8 [ OK ]
5 3.4.93 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.43 [ OK ]
12 3.11.10 [ OK ]
13 3.12.22 [ OK ]
14 3.13.11 [ OK ]
15 3.14.7 [ OK ]
16 3.15.0 [ OK ]
17 3.16-rc1 [ OK ]
AT86RF230 needs the devm_regmap_init_spi() function.
These driver need clk_prepare_enable(), clk_disable_unprepare(),
devm_regulator_bulk_get() or devm_regmap_init_i2c()
It is now possible to detect a ubuntu kernel see:
https://bugs.launchpad.net/ubuntu/+source/linux/+bug/1327619
This uses the new define and adds some code depending on the ubuntu
trusty kernel.
They are depending in some headers only available in more recent kernel
versions.
The old __QUEUE_STATE_XOFF was divided into __QUEUE_STATE_DRV_XOFF and
__QUEUE_STATE_STACK_XOFF, in this patch we map both to the old version
on old kernel vesions.
This backports this upstream commit:
commit 7346649826382b769cfadf4a2fe8a84d060c55e9
Author: Tom Herbert <therbert@google.com>
Date: Mon Nov 28 16:32:44 2011 +0000
net: Add queue state xoff flag for stack
request_firmware_direct() was newly added and in some places it is
better to use request_firmware_direct(), but request_firmware() will
also work and result in 60 seconds waiting if the file is not there in
some situations.
This adds the cc2520.h and disables the driver on kernel < 3.5.
dma_buf_export() got a new parameter which is not available in older
kernel versions.
This was once removed in this commit and is needed again:
commit 9981d1abf4b52e84a432fc9bdfbdd30d1838819d
Author: Hauke Mehrtens <hauke@hauke-m.de>
Date: Mon Jun 16 21:02:25 2014 +0200
backports: Revert "remove parameter from dma_buf_export()"
While doing a make allmodconfig I noticed the following:
CC [M] /dev/shm/backports-next/drivers/media/i2c/adv7604.o
/dev/shm/backports-next/drivers/media/i2c/adv7604.c:31:33: fatal error: linux/gpio/consumer.h: No such file or directory
linux/gpio/consumer.h cannot be backported currently, as functions rely
on in-kernel functionality (GPIO_DEVRES). Bumping the minimum required
kernel version for ADV7604 to 3.13 where the header got introduced.
[add comment with reason]
This is provides in-kernel functionality, to include
it assuems we have provided a backport for this functionality
and that's not true.
This reverts commit 16472f0c6924f0fa54c68a024a55d89689b413a0.
Including the header fixes the error.
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
The regulator palmas driver makes use of the new struct regulator_desc
enable_val and disable_val added via commit ca5d1b352 on v3.15 to help
overcome an issue on assumptions on how regulator drivers enable /
disable the regulator with only one value / mask. We can't port this
so just require at least v3.15 for it.
mcgrof@ergon ~/linux (git::master)$ git describe --contains ca5d1b352
v3.15-rc1~148^2~4^3
commit ca5d1b3524b4d90a2e2f1f71583c1dca6b96fd92
Author: Carlo Caione <carlo@caione.org>
Date: Wed Mar 5 22:11:29 2014 +0100
regulator: helpers: Modify helpers enabling multi-bit control
This patch extends the regulator helpers to account for device that use
multiple bits for control when using regmap enable/disable/bypass ops.
The actual regulator helpers wrongly assume that the regulator control
is always performed using single bits, using in the regulator_desc
struct only two parameters *_reg and *_mask defining register and mask
for control.
This patch extends this struct and introduces the helpers to take into
account devices where control is performed using multiple bits and
specific multi-bit values are used for enabling/disabling/bypassing the
regulator.
Signed-off-by: Carlo Caione <carlo@caione.org>
Signed-off-by: Mark Brown <broonie@linaro.org>
This adds kernel 3.16 and updates some other kernel versions.
== ckmake-report.log ==
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.60 [ OK ]
4 3.3.8 [ OK ]
5 3.4.93 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.43 [ OK ]
12 3.11.10 [ OK ]
13 3.12.22 [ OK ]
14 3.13.11 [ OK ]
15 3.14.7 [ OK ]
16 3.15.0 [ OK ]
17 3.16-rc1 [ OK ]
In kernel >= 3.16 this backport is not needed at all. When
CPTCFG_IEEE802154_6LOWPAN is not set it should not get build, we do not
have to check if we are kernel > 3.5, because in an other case
ieee802.15.4 will not get build. Kernel version 3.15 needs a different
backport than the older versions.
The linux commit which made backports need this patch was removed from
linux-next.
This reverts commit 6e1b080e83f1537d8d198917180d0a8bdfd7e0c9.
__pskb_copy() was renamed to __pskb_copy_fclone() in most places and
got an extra parameter, it should be safe to just ignore this extra
parameter.
There were manual changes ineeded in the following files:
patches/collateral-evolutions/network/0034-ndo_set_vf_spoofchk/igb_ndo_set_vf_spoofchk.patch
patches/collateral-evolutions/network/0037-ethtool_get_module/igb_get_module.patch
patches/collateral-evolutions/network/0038-ethtool_rxfh_indir/igb_rxfh_indir.patch
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.59 [ OK ]
4 3.3.8 [ OK ]
5 3.4.91 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.40 [ OK ]
12 3.11.10 [ OK ]
13 3.12.20 [ OK ]
14 3.13.11 [ OK ]
15 3.14.4 [ OK ]
16 3.15-rc7 [ OK ]
When exporting a patch from git it adds a header to it, but this header
is not needed by backports, remove it from the patches.
The function devm_gpio_request_one() was backported some time ago.
These drivers got new and not so easy backportable dependencies.
This header file is used by net/mac802154/llsec.h and does not provide
any function prototype so it is save to copy it.
This fixes a warning on these older kernel versions.
The ieee802154 subsystem wants to access user_ns on struct net, but
this member was added in kernel 3.8, check the general capabilities
instead.
