1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.62 [ OK ]
4 3.3.8 [ OK ]
5 3.4.102 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.52 [ OK ]
12 3.11.10 [ OK ]
13 3.12.26 [ OK ]
14 3.13.11 [ OK ]
15 3.14.16 [ OK ]
16 3.15.7 [ OK ]
17 3.16.0 [ FAIL ]
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.60 [ OK ]
4 3.3.8 [ OK ]
5 3.4.93 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.43 [ OK ]
12 3.11.10 [ OK ]
13 3.12.22 [ OK ]
14 3.13.11 [ OK ]
15 3.14.7 [ OK ]
16 3.15.0 [ OK ]
Upstream commit: d787b3dd3b4fcb5f40eb6532163dc3abdca4fd45
net_get_random_once() was added unconditionally also when the kernel we
are compiling against already provided this function, this patch checks
that first.
Upstream commit: 4d1a1850cfb8918fbf190071d1f1f1383814538e
These flags are now defined in linux/netdevice.h and not in linux/if.h
any more. This patch also removed some defined in all kernel versions
since 3.0.
Upstream commit: 495b6d7968e4ce08fb1371197bce7a8c8a482069
The spatch conversion (commit 05d44557c6a83b4ecb935cb6306f62,
"backports: transform group attribute backport to SmPL form")
added an #ifdef that shouldn't be there - remove it.
Upstream commit: d260afa8c4aecde4abdecfa299713bc473c0dba4
The patch changing the callback function signature was backported to
kernel 3.14, this was already fixed in backports for mac80211, but that
commit missed mwifiex.
Upstream commit: 1b62085572206ee0ad9a89dcc5528d63b432d7fe
In this version the correct linux string.h is included.
Include string.h to avoid compile issues if warnings are treated as errors:
backports-3.14-1/compat/backport-3.15.c: In function 'backport_devm_kstrdup':
backports-3.14-1/compat/backport-3.15.c:33:2: error: implicit declaration of function 'strlen' [-Werror=implicit-function-declaration]
size = strlen(s) + 1;
backports-3.14-1/compat/backport-3.15.c:33:9: warning: incompatible implicit declaration of built-in function 'strlen' [enabled by default]
backports-3.14-1/compat/backport-3.15.c:36:3: error: implicit declaration of function 'memcpy' [-Werror=implicit-function-declaration]
memcpy(buf, s, size);
backports-3.14-1/compat/backport-3.15.c:36:3: warning: incompatible implicit declaration of built-in function 'memcpy' [enabled by default]
Signed-off-by: Richard Röjfors <richard@puffinpack.se>
[refreshed patch on current master]
Upstream commit: dc2c1472a9b05ff5e574d0d14e6251e8af0a025a
This definition may exists on non-vanilla kernels.
Signed-off-by: Jonathan DE CESCO <jonathan.de.cesco@intel.com>
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
Upstream commit: 816cbc860692cb60bf6e5e16ec2b4532992c7e0a
If these aren't actually compiled in, then the mac80211
code will fail at runtime. Add these dependencies so we
at least get a warning at compile time about this.
Upstream commit: 44554cd57d0016c52aeed2ce4f27081b9d9c915f
The callback argument has been passed since kernel 3.14, not
only 3.15 - fix that.
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
Upstream commit: 6dfa96a892c962cda981cda1b2c88e6b1df5c886
Avoid conflicts with RHEL7.0 as DEVICE_ATTR_* defines,
enum pkt_hash_types, skb_set_hash(), dma_common_get_sgtable()
are already present.
Signed-off-by: Stefan Assmann <sassmann@kpanic.de>
Upstream commit: 3443187edd32767c838e5d4f654df474e77fb7ce
To avoid conflicts with any distribution kernel wrap
dma_set_mask_and_coherent with LINUX_BACKPORT().
Signed-off-by: Christian Ratzenhofer <christian.ratzenhofer@cdnm.at>
This update required one collateral evolution to be addressed,
the rest was just a patch refresh.
mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean
--refresh /home/mcgrof/linux-next /home/mcgrof/build/next-20140415
Copy original source files ...
Apply patches ...
Modify Kconfig tree ...
Rewrite Makefiles and Kconfig files ...
Done!
real 1m16.527s
user 10m47.068s
sys 0m37.412s
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.54 [ OK ]
4 3.3.8 [ OK ]
5 3.4.79 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.29 [ OK ]
12 3.11.10 [ OK ]
13 3.12.10 [ OK ]
14 3.13.2 [ OK ]
15 3.14-rc1 [ OK ]
real 18m42.577s
user 498m48.572s
sys 64m0.560s
Commit 676d2369 by David removed the skb->len arguments passed onto
the struct sock sk_data_ready() callback. This was done as its racy,
a few drivers were passing 0 to it, and it was not really used.
By removing it the raciness is addresed but to backport this we are
going to have to deal with the races as-is on older kernels. This was
merged as of v3.15:
mcgrof@ergon ~/linux-next (git::master)$ git describe --contains 676d2369
v3.15-rc1~8^2~10
Since this is not a define or static inline we can't easily replace this with
the backports module or header files, instead we use SmPL grammar to generalize
the backport for all use cases. Note that in order to backport this we won't
know what older kernel drivers were using before this change, it could have
been 0 or skb->len for the length parameter, since we have to infer something
we choose skb->len *iff* skb_queue_tail() was used right before it, otherwise
we infer to throw 0.
Adding this SmPL patch to our series only incurs an additional ~9 seconds
on run time code generation.
/home/mcgrof/linux-next /home/mcgrof/build/next-20140415-clean
Apply patches ...
Done!
real 1m25.128s
user 12m49.380s
sys 0m44.892s
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.54 [ OK ]
4 3.3.8 [ OK ]
5 3.4.79 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.29 [ OK ]
12 3.11.10 [ OK ]
13 3.12.10 [ OK ]
14 3.13.2 [ OK ]
15 3.14-rc1 [ OK ]
real 18m42.577s
user 498m48.572s
sys 64m0.560s
commit 676d23690fb62b5d51ba5d659935e9f7d9da9f8e
Author: David S. Miller <davem@davemloft.net>
Date: Fri Apr 11 16:15:36 2014 -0400
net: Fix use after free by removing length arg from sk_data_ready callbacks.
Several spots in the kernel perform a sequence like:
skb_queue_tail(&sk->s_receive_queue, skb);
sk->sk_data_ready(sk, skb->len);
But at the moment we place the SKB onto the socket receive queue it
can be consumed and freed up. So this skb->len access is potentially
to freed up memory.
Furthermore, the skb->len can be modified by the consumer so it is
possible that the value isn't accurate.
And finally, no actual implementation of this callback actually uses
the length argument. And since nobody actually cared about it's
value, lots of call sites pass arbitrary values in such as '0' and
even '1'.
So just remove the length argument from the callback, that way there
is no confusion whatsoever and all of these use-after-free cases get
fixed as a side effect.
Based upon a patch by Eric Dumazet and his suggestion to audit this
issue tree-wide.
Cc: Peter Senna <peter.senna@gmail.com>
Cc: Julia Lawall <julia.lawall@lip6.fr>
Cc: Gilles Muller <Gilles.Muller@lip6.fr>
This lets us share it for general use as a generic tool, we'll upkeep
it here for now and if Coccinelle picks it up we can drop it and just
require folks to install it.
This lets us use the same solution for standard testing / regular
development and also for backports without any discrepencies.
Our current overall run time is less than 120 seconds so lets
add a trigger to fail if we have a rule taking longer. Adding
this has no extra incurred overhead cost.
/home/mcgrof/linux-next /home/mcgrof/build/next-20140411
Apply patches ...
Done!
real 1m15.463s
user 10m49.100s
sys 0m37.100s
This will provide wider coverage on include paths for our Coccinelle
rule interpretation, at a very lower cost incurred, about 1 second,
for code generation. Coccinelle makes an effort to infer types but
with a wider coverage of header files it can do a better job at that.
You want to use both --recursive-includes (which we already enable) and
--relax-include-path to get the most possible type information.
You will want at least Coccinelle 1.0.0-rc20 which had an increase
of performance of over 30% when using both --recursive-includes and
--relax-include path.
Apply patches ...
Done!
real 1m15.370s
user 10m47.232s
sys 0m36.980s
This uses --use-coccigrep on our Cocccinelle library and removes
the CPU adjustments depending on whether we are testing or not.
The flag --use-coccigrep will tell Coccinelle to only kick off a
worker on a file until it has determined that a rule being
evaluated applies to a file. This does however mean that all files
on its bucket list will be evaluated first, but this yields better
CPU usage without having us to ramp up on the number of threads
depending on the situation. Without this patch we were kicking off
more threads to account for the fact that a Coccinelle thread will
stop working on a file if it had little or nothing to do on a file.
Possible work improvement: see how we can do away with tmp files
for Coccinelle output and just use memory to for the ouput, or
perhaps even disregard the stdout and only care for it if
--debug-cocci is provided.
Apply patches ...
Done!
real 1m14.880s
user 10m47.824s
sys 0m36.796s
The struct attribute_group collateral evolution by Greg and Oliver
was introduced as of v3.11:
mcgrof@ergon ~/linux (git::master)$ git describe --contains f2f37f58b
v3.11-rc2~18^2~9
mcgrof@ergon ~/linux (git::master)$ git describe --contains 3493f69f4
v3.11-rc2~18^2~2
We backport them with our own respective set of helpers. Each new data
structure that gets an attribute group needs a respective SmPL set of
rules for the transformation, specially if they were introduced in
different kernel versions, which in this case we have two which were.
By using SmPL we can automatically backport the collateral evolutions
moving forward for *any* driver that makes use of these group
attributes on both data structure we are addressing in these SmPL
patches. This is a great example of the level of atomicity that we
want to ideally strive to reach for backporting, as it lets us
automatically backport a collateral evolution through grammer for
*any* device driver we backport, and lets us be lazier.
We provided backports of introduction of the group attribute onto
two data structures:
* struct class: added via commit d05a6f96c
* struct bus_type: added via commit fa6fdb33b
mcgrof@ergon ~/linux (git::master)$ git describe --contains d05a6f96c
v3.11-rc2~18^2~3
mcgrof@ergon ~/linux (git::master)$ git describe --contains fa6fdb33b
v3.12-rc1~184^2~89
This patch generalizes the backport the introduction of the group
attribute to each data structure into separate SmPL patch files.
One change the SmPL patches pick up on was #ifdef'ing over the
init_foogroup_attrs() calls which would only have been introduced when
ATTRIBUTE_GROUPS_BACKPORT() was used, which *is* #idefd's.
The changes that added the new APIs are below, the respective commits
for each data structure change are documented on each SmPL patch.
commit f2f37f58b1b933b06d6d84e80a31a1b500fb0db2
Author: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
Date: Sun Jul 14 16:05:52 2013 -0700
sysfs.h: add ATTRIBUTE_GROUPS() macro
To make it easier for driver subsystems to work with attribute groups,
create the ATTRIBUTE_GROUPS macro to remove some of the repetitive
typing for the most common use for attribute groups.
Reviewed-by: Guenter Roeck <linux@roeck-us.net>
Tested-by: Guenter Roeck <linux@roeck-us.net>
commit 3493f69f4c4e8703961919a9a56c2d2e6a25b46f
Author: Oliver Schinagl <oliver@schinagl.nl>
Date: Sun Jul 14 16:05:59 2013 -0700
sysfs: add more helper macro's for (bin_)attribute(_groups)
With the recent changes to sysfs there's various helper macro's.
However there's no RW, RO BIN_ helper macro's. This patch adds them.
Signed-off-by: Oliver Schinagl <oliver@schinagl.nl>
mcgrof@drvbp1 ~/backports (git::master)$ time \
./gentree.py --clean /home/mcgrof/linux-next /home/mcgrof/build/next-20140411
Apply patches ...
Done!
real 1m14.635s
user 5m17.308s
sys 0m39.216s
== ckmake-report.log ==
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.54 [ OK ]
4 3.3.8 [ OK ]
5 3.4.79 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.29 [ OK ]
12 3.11.10 [ OK ]
13 3.12.10 [ OK ]
14 3.13.2 [ OK ]
15 3.14-rc1 [ OK ]
real 28m18.533s
user 785m28.844s
sys 86m25.548s
Cc: Oliver Schinagl <oliver@schinagl.nl>
This optimization was introduced by Johannes to help with
performance before we had parallelism. With parallelism
we get better results by splitting rules up. Also some
feedback from Julia on this:
I don't think this is a good idea. You would have to be careful about
naming. And You may lose on some performance benefits of the prefiltering.
Suppose you have an easy semantic patch that references function A and a
hard semantic patch that references function B. The hard semantic patch
specifically contains one rule that is very complicated but that does not
use B. That very complicated rule will now be applied to the 5000 files
that use A as well as to the 3 files that use B. So you get a big
performance slowdown.
The performance before this change:
--refresh \
/home/mcgrof/linux-next /home/mcgrof/build/next-20140409
Apply patches ...
Done!
real 1m30.186s
user 9m25.180s
sys 0m24.428s
After:
Apply patches ...
Done!
real 1m3.071s
user 3m39.388s
sys 0m21.812s
commit 3c71184d3a2843c9a1d5a289c71bfbbc126d71fd
Author: Johannes Berg <johannes.berg@intel.com>
Date: Wed Jan 1 20:37:13 2014 +0100
gentree: combine spatches (unless using --gitdebug)
Since spatch is rather slow, but can handle multiple spatches
concatenated in a single file, just do that and run it only
once rather than for each spatch. That shaves off some of the
runtime (startup etc. and finding affected files.)
On my system, I go from
real 9m42.616s
user 8m48.352s
sys 0m22.884s
to
real 9m1.948s
user 8m40.108s
sys 0m12.088s
We were required to refresh patches for next-20140409 but for next-20140411
no changes were required. Since no actual commit is necessary next time
this happens (which can often, hence -- automatic backports --) I'll
just peg the results on the PGP signed tag for the release. I'll peg
this commit with both next tags because of this. Just run git describe
to find out the respective linux-next tag you should be using as that is
the latest validated one.
mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean --refresh \
Apply patches ...
Done!
real 1m30.186s
user 9m25.180s
sys 0m24.428s
mcgrof@drvbp1 ~/build/next-20140409 $ time ckmake --allyesconfig
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.54 [ OK ]
4 3.3.8 [ OK ]
5 3.4.79 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.29 [ OK ]
12 3.11.10 [ OK ]
13 3.12.10 [ OK ]
14 3.13.2 [ OK ]
15 3.14-rc1 [ OK ]
real 26m54.859s
user 744m15.764s
sys 83m47.440s
--refresh /home/mcgrof/linux-next /home/mcgrof/build/next-20140411
Apply patches ...
Done!
real 1m30.437s
user 9m22.812s
sys 0m24.484s
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.54 [ OK ]
4 3.3.8 [ OK ]
5 3.4.79 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.29 [ OK ]
12 3.11.10 [ OK ]
13 3.12.10 [ OK ]
14 3.13.2 [ OK ]
15 3.14-rc1 [ OK ]
real 28m21.215s
user 786m8.468s
sys 86m46.564s
Apply patches ...
Done!
real 1m30.186s
user 9m25.180s
sys 0m24.428s
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.54 [ OK ]
4 3.3.8 [ OK ]
5 3.4.79 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.29 [ OK ]
12 3.11.10 [ OK ]
13 3.12.10 [ OK ]
14 3.13.2 [ OK ]
15 3.14-rc1 [ OK ]
real 26m54.859s
user 744m15.764s
sys 83m47.440s
Ben added ioctl support for the unprivileged SIOCGHWTSTAMP
which is designed to just get the configuration, unlike
SIOCSHWTSTAMP which requires you to set it and only after
it returns the configuration.
Since we are carrying over a small addition to a UAPI header
without carrying it over completely (we use copy-list to
carry over full UAPI headers) its worth making a design note
about this.
We carry UAPI headers for backports to enable compilation
of kernel / driver code to compile without any changes. If
it so happens that a feature is backported it can be added
here but notice that if full subsystems are backported you
should just include the respective full header onto the
copy-list file so that its copied intact. The strategy on this
patch can be used to either backport a specific feature or
to just avoid having to do ifdef changes to compile kernel
or driver carried over by backports.
Userspace is *not expected* to copy over backports headers
to compile userspace programs, userspace programs can
and should consider carrying over a respective copy-list
of the latest UAPI kernel headers they need in their
upstream sources, the kernel the user uses, whether with
backports or not should be able to return -EOPNOTSUPP if
the feature is not available and let it through if its
supported and meats the expected form.
In this particular case if userspace tries to send the
SIOCGHWTSTAMP they'd end up with -ENOTTY.
mcgrof@ergon ~/linux (git::master)$ git describe --contains fd468c74
v3.14-rc1~94^2~622^2~12
commit fd468c74bd4d6949736810a80d6ca05eb20fba84
Author: Ben Hutchings <bhutchings@solarflare.com>
Date: Thu Nov 14 01:19:29 2013 +0000
net_tstamp: Add SIOCGHWTSTAMP ioctl to match SIOCSHWTSTAMP
SIOCSHWTSTAMP returns the real configuration to the application
using it, but there is currently no way for any other
application to find out the configuration non-destructively.
Add a new ioctl for this, making it unprivileged.
Signed-off-by: Ben Hutchings <bhutchings@solarflare.com>
dev_consume_skb_any() was added by Eric via commit e6247027e
added as of v3.14 to help do analysis on the different reasons
why an skbs are free'd in particular to let us know how many get
dropped or consumed. The new dev_consume_skb_any() spawned the
inception of an optimization for dev_kfree_skb_irq() which was
implemented through __dev_kfree_skb_irq() which dev_kfree_skb_irq()
now uses. We could have taken advantage of both if kernels had
exported raise_softirq_irqoff() but they don't and as such we
can't reimplement that on backports as it stands right now.
If we'd be building backports in-kernel we could just take the
new implementation of __dev_kfree_skb_irq() as raise_softirq_irqoff()
would be available and we could reap the benefits of the change.
That implemention can be seen as a reference - for now - here:
http://drvbp1.linux-foundation.org/~mcgrof/patches/2014/04/11/pend-2014-04-07.patch
For older kernels for now we just use the singular old version of
dev_kfree_skb_irq() and dev_kfree_skb_any().
mcgrof@ergon ~/linux (git::master)$ git describe --contains e6247027e
v3.14-rc1~94^2~585
commit e6247027e5173c00efb2084d688d06ff835bc3b0
Author: Eric Dumazet <edumazet@google.com>
Date: Thu Dec 5 04:45:08 2013 -0800
net: introduce dev_consume_skb_any()
Some network drivers use dev_kfree_skb_any() and dev_kfree_skb_irq()
helpers to free skbs, both for dropped packets and TX completed ones.
We need to separate the two causes to get better diagnostics
given by dropwatch or "perf record -e skb:kfree_skb"
This patch provides two new helpers, dev_consume_skb_any() and
dev_consume_skb_irq() to be used for consumed skbs.
__dev_kfree_skb_irq() is slightly optimized to remove one
atomic_dec_and_test() in fast path, and use this_cpu_{r|w} accessors.
Cc: Eric Dumazet <edumazet@google.com>
Cc: Felix Fietkau <nbd@openwrt.org>
We copy over the net/core/flow_dissector.c code from
the kernel through the backports Kconfig magic for
our backport of NET_SCH_FQ_CODE:
config BACKPORT_USERSEL_NET_SCH_FQ_CODEL
tristate "Fair Queue Controlled Delay AQM (FQ_CODEL)"
depends on m
depends on !BACKPORT_KERNEL_2_6_25
default m if NET_SCH_FQ_CODEL=n
default m if BACKPORT_USERSEL_BUILD_ALL
#module-name sch_fq_codel
#c-file net/sched/sch_fq_codel.c
#c-file net/core/flow_dissector.c
This pulls net/core/flow_dissector.c into the backports
module as compat/net-core-flow_dissector.c. We don't need
all the code there. Patches under patches/backport-adjustments/
can be used to adjust that type of code. Some changes have
been made to code we delete which means we need to manually
adjust the patch we carry. This is a hint as one area we could
look to enhance better to do more automatic backport work.
Jean nuked display output class support so we won't
be needing the respective headers for compilation on
backports now. This is as seen on next-20140409.
commit f167a64e9d67ebd03d304e369c12011cf2bffaf5
Author: Jean Delvare <jdelvare@suse.de>
Date: Mon Mar 17 15:49:10 2014 +0100
video / output: Drop display output class support
It was only ever used by the ACPI video driver, and that only use case
vanished over 3 years ago (see commit 677bd810, "ACPI video: remove
output switching control".) So this is dead code and I guess we can
remove it now.
Signed-off-by: Jean Delvare <jdelvare@suse.de>
Some old custom kernels have it defined.
Signed-off-by: Arik Nemtsov <arikx.nemtsov@intel.com>
napi_gro_flush() got a second argument in kernel 3.7, but it
can be ignored for prior kernel versions.
This can be useful for pure testing scenarios.
The wil6210 driver gets NETIF_F_GRO but not that we haven't
been backporting this feature, which was added as of v2.6.29
via commit d565b0a1a. The driver is only enabled on the
dependencies file down to 2.6.31 though so we simply reuse the
check against kernels >= 2.6.39 to use the netdev->hw_features.
mcgrof@ergon ~/linux-next (git::master)$ git describe --contains d565b0a1a
v2.6.29-rc1~581^2~181
--refresh /home/mcgrof/linux-next /home/mcgrof/build/next-20140320
Apply patches ...
Done!
real 1m59.391s
user 19m26.468s
sys 0m45.128s
mcgrof@drvbp1 ~/build/next-20140320 $ time ckmake --allyesconfig
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.54 [ OK ]
19 3.3.8 [ OK ]
20 3.4.79 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.29 [ OK ]
27 3.11.10 [ OK ]
28 3.12.10 [ OK ]
29 3.13.2 [ OK ]
30 3.14-rc1 [ OK ]
real 36m11.856s
user 994m29.360s
sys 124m49.936s
Commit 93abe8e4 by Viresh added non CONFIG_COMMON_CLK static inlines
that should have gone in for 3.5 as 3.5 assumed some declared routines
would be exproted by the architecture, which was not true. We backport
only the non CONFIG_COMMON_CLK case as CONFIG_COMMON_CLK requires
core kernel architecture specific backport support which we currently do
not support (and perhaps shouldn't). Since 3.5 is not a supported kernel
there is no need to fix this there upstream but this then does require
a paper wrap work around for those kernels of providing an export symbol
for clk_enable() and clk_disable() for the !CONFIG_COMMON_CLK case which
older kernels failed to address.
mcgrof@ergon ~/linux-next (git::master)$ git describe --contains 93abe8e4
v3.6-rc1~41^2~117
Cc: Viresh Kumar <viresh.kumar@st.com>
Cc: Wolfram Sang <w.sang@pengutronix.de>
Cc: Sergei Shtylyov <sshtylyov@ru.mvista.com>
IR_IMG is a new driver added by James via 160a8f8a and letter
integrated into the build via commit 54b29120 as of linux-next
tag next-20140320 which may make it to Linux through v3.15. This
new driver makes use of devm_clk_get() but this was added via
a8a97db9 and that get merged as of v3.5. It seems we can easily
backport a8a97db9 but these days I'm starting to leave this up to the
folks interested in the drivers to choose / participate and only
they would know if this is worth it. Is 3.5 a good starting point
kernel to require for drivers which depend on the new clock APIs?
mcgrof@ergon ~/linux-next (git::master)$ git describe --contains a8a97db9
v3.5-rc1~183^2~2
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Mauro Carvalho Chehab <m.chehab@samsung.com>
Cc: Mark Brown <broonie@linaro.org>
IEEE802154_AT86RF230 has gotten some gpio changes lately
and since we are not backporting all those gpio changes in
practice this driver only compiles down to 3.3 so add that
requirement.
Cc: Alexander Aring <alex.aring@gmail.com>
NFC_TRF7970A requires devm_gpio_request_one() but since
gpio infrastructure has been strongly shuffled around
we require drivers to use the in-kernel gpio
infrastructure so just bump NFC_TRF7970A to 3.5.
CC: Erick Macias <emacias@ti.com>
CC: Felipe Balbi <balbi@ti.com>
Cc: Mark A. Greer <mgreer@animalcreek.com>
Cc: Samuel Ortiz <sameo@linux.intel.com>
Commit bcf43393 as of linux-next next-20140320 added this Makefile
header extension:
ccflags-y += -I$(srctree)/drivers/staging/media/rtl2832u_sdr
This ends up calling a staging exported symbol rtl2832_sdr_attach().
Let's not pollute driver code with staging code or dependencies.
Folks, can this be cleaned up? This sets a precedent for doing more
of this, and this can get hairy. Its also not fair for folks who
don't want to carry over any staging code. This forces them to, and
its not just a header file, its a full exported symbol. What about
synchronization with differen trees? Was this addressed with Greg?
commit bcf43393579e3d4069e75a9200a87703185bcf11
Author: Antti Palosaari <crope@iki.fi>
Date: Tue Sep 10 00:13:57 2013 -0300
[media] rtl28xxu: attach SDR extension module
With that extension module it supports SDR.
Signed-off-by: Antti Palosaari <crope@iki.fi>
Signed-off-by: Mauro Carvalho Chehab <m.chehab@samsung.com>
Cc: Antti Palosaari <crope@iki.fi>
These depend on include/linux/mfd/samsung/s2mps14.h which
other mfd drivers / platform code can depend on, skip
unless we backport all the dependencies which we don't
right now.
The affected drivers are:
* REGULATOR_S2MPS11
* REGULATOR_S2MPA01
* REGULATOR_TPS65217
The mfd files which we don't backport that uses this are:
* drivers/mfd/sec-core.c
* drivers/mfd/sec-irq.c
This backports commit d1c76af9e added by Herbert which added the first
enums and then commit 5b252f0c2 added by Ben which gave the enums a
label and then pegged a typedef onto these. This backports these commits
in a forward compatible way upkeeping the introduction and then the
typedef. In order to make this work we use make backported code use
enums with the BACKPORT_prefix but upkeep the same values, this lets
us declare the typedef and peg it to a similar set.
Cc: Herbert Xu <herbert@gondor.apana.org.au>
Cc: Ben Hutchings <bhutchings@solarflare.com>
Commit b32607dd was already partially backported, this complets that
backport.
mcgrof@ergon ~/linux-next (git::master)$ git describe --contains b32607dd
v3.7-rc1~145^2~292
These are just helpers so carry them over, this was added via commit
9e903e0852 through v3.2. The skb frag size was in place for a long time but
was changed from __u16 to __u32 via commit a309bb072b through v2.6.23 and
since we backport for >= 2.6.25 just leave this as is. This was already
only partly backported, this adds the missing helpers.
mcgrof@ergon ~/linux-next (git::master)$ git describe --contains 9e903e0852
v3.2-rc1~182^2~85
mcgrof@ergon ~/linux-next (git::master)$ git describe --contains a309bb072b
v2.6.23-rc2~35^2~11
commit 9e903e085262ffbf1fc44a17ac06058aca03524a
Author: Eric Dumazet <eric.dumazet@gmail.com>
Date: Tue Oct 18 21:00:24 2011 +0000
net: add skb frag size accessors
To ease skb->truesize sanitization, its better to be able to localize
all references to skb frags size.
Define accessors : skb_frag_size() to fetch frag size, and
skb_frag_size_{set|add|sub}() to manipulate it.
This backports skb_set_hash(). Two skb data structures are used
introduced at different points in time, so ifdef around that as well.
For older kernels this is a nop.
mcgrof@ergon ~/linux (git::master)$ git describe --contains bdeab99191
v3.2-rc1~129^2~458
mcgrof@ergon ~/linux (git::master)$ git describe --contains 4031ae6edb
v3.4-rc1~177^2~333^2
mcgrof@ergon ~/linux (git::master)$ git describe --contains 09323cc479
v3.14-rc1~94^2~474^2~1
Cc: Tom Herbert <therbert@google.com>
This backports the APIs for manipulating skb page fragments
introduced by Ian via commit 131ea6675c on v3.2. Use the
LINUX_BACKPORT() namespace to avoid clashes with similar ports.
We skip skb_frag_dma_map() as that was already backported.
We also don't backport skb_frag_page() as that was already
backported before.
Since the skb fragment page was moved into its own struct as
part of the fragment our backport ends up using the old access
mechanisms for the framgement page. For details see a8605c6063.
mcgrof@ergon ~/linux-next (git::master)$ git describe --contains 131ea6675c
v3.2-rc1~129^2~421
mcgrof@ergon ~/linux-next (git::master)$ git describe --contains a8605c6063
v3.2-rc1~182^2~29
commit 131ea6675c761f655d43b808dd0fe83d15d5cdd3
Author: Ian Campbell <Ian.Campbell@citrix.com>
Date: Fri Aug 19 06:25:00 2011 +0000
net: add APIs for manipulating skb page fragments.
The primary aim is to add skb_frag_(ref|unref) in order to remove the use of
bare get/put_page on SKB pages fragments and to isolate users from subsequent
changes to the skb_frag_t data structure.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: "Michał Mirosław" <mirq-linux@rere.qmqm.pl>
Cc: netdev@vger.kernel.org
Cc: Ian Campbell <ian.campbell@citrix.com>
The bh version u64_stats_fetch_begin_bh() and u64_stats_fetch_retry_bh()
got dropped in favor for an IRQ safe variant. We can now remove
u64_stats_fetch_begin_bh() and u64_stats_fetch_retry_bh() as we work
carrying over what is upstream and no drivers upstream use this anymore.
Cc: Eric W. Biederman <ebiederm@xmission.com>
The 0001-netdev_ops.cocci is fine but is uses Expression which
makes the interpretation loose. We can reduce the namespace of
the change by using struct. We have to keep expression on the
right hand side as that can even be macros.
For a full example test coverage of this change see the test netdev-ops
github tree and run:
make test1
git checkout -f
make test2
The benefits should be clear, we are *not* modifying data structures
that have similar names. This increases accuracy and security of our
changes. The added run time penalty however is 50 seconds since we had
to use --recursive-includes. The time penatly is worth it for the
accuracy provided and since we'll likley need this flag elsewhere for
other rules.
/home/mcgrof/linux-next \
/home/mcgrof/build/next-20140311
Apply patches ...
Done!
real 1m56.339s
user 19m31.428s
sys 0m50.100s
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.54 [ OK ]
19 3.3.8 [ OK ]
20 3.4.79 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.29 [ OK ]
27 3.11.10 [ OK ]
28 3.12.10 [ OK ]
29 3.13.2 [ OK ]
30 3.14-rc1 [ OK ]
[0] https://github.com/mcgrof/netdev-ops
We leave two patches under the 09-threaded-irq series, but there
are six things worth mentioning on this commit that are important.
I'll clarify that this SmPL port is simply done as a proof of
concept on testing the complexity of a backport for with Coccinelle,
this backport is only relevant for kernels older than 2.6.31 which
at this point is ancient and we should probably stop caring for soon.
1) patches/collateral-evolutions/network/0015-threaded-irq.cocci
We rename the collateral evolution backport from the 09-threaded-irq as
this backport is now formalized and properly atomically split up. We
use 4 digit prefixes for formalized and atomically split up collateral
evolutions. The rest of the patch series that do not have 4 digits
imply that those series could use some love to be formally split up
atomically.
2) 0015-threaded-irq/
We keep a directory for backported collateral evolutions for either
legacy backports without SmPL Coccinelle patches *or* for series that
are addressed with SmPL but that had some shortcomings with Coccinelle
that we are looking to address. Legacy backports also had an INFO file
in its directory, we keep it around for now for this series as we have
one legacy patch lingering around still but since Coccinelle lets us
put comments on top and the series is for all drivers we can just rely
on the comment section of an SmPL patch for this as patches get
translated.
3) Rename of 09-threaded-irq/drivers_net_wireless_ti_wlcore_main_extra.patch
to
0016-threaded-irq-one-shot.patch
This patch is kept as it deals with driver specific IRQ changes
which are completely unrelated to the 09-threaded-irq series but that
we had tucked under in the older legacy backport. Because of this
we make emphasis by moving out out under the series. This can be
generalized as another backport series if other drivers wish to
backport.
This new seires backports commit b25c340c1 added by Thomas through kernel
v2.6.32 which added support for IRQF_ONESHOT. This lets drivers that use
threaded IRQ support to request that the IRQ is not masked after the
hard interrupt handler as this requires device access in hard IRQ
context and for buses such as i2c and spi this at times is not
possible.
Note that the TI driver uses this when a platform quirk with
WL12XX_PLATFORM_QUIRK_EDGE_IRQ is detected. In retrospect this quirk
does not seem backportable unless IRQF_ONESHOT is really not a requirement,
but desired. If WL12XX_PLATFORM_QUIRK_EDGE_IRQ is indeed a requirement
for IRQF_ONESHOT then we should not probe complete. Its unclear
if this is a universal thing or not.
mcgrof@ergon ~/linux-next (git::master)$ git describe --contains b25c340c1
v2.6.32-rc1~722^2~3
4) 0015-threaded-irq/drivers_net_wireless_iwlwifi_iwl-trans.patch
A data structure change to struct iwl_trans is not being done
by Coccinelle given that the driver's Makefile for iwlwifi uses
this for its includes:
ccflags-y += -D__CHECK_ENDIAN__ -I$(src)
Coccinelle doesn't pick up on this even if we use --recursive-includes.
This issue has been reported. An interesting thing about this is that
struct iwl_trans was *not* used before this patch which is why you see
the removal of the file drivers_net_wireless_iwlwifi_pcie_internal.patch
and as a replacement have added drivers_net_wireless_iwlwifi_iwl-trans.patch.
What happened is Coccinelle is consistent and the change, as expressed
in grammar, which reveleas that we were *not* consistent with our manual
backport! The older backport still worked though as it did not really
matter what data structure got changed so long as its an internal data
structure. This also means this backport could be modified to use
a generic backport data structure, which we don't yet have but could
be a good idea to stuff in general backport data structure extensions,
which we typically have not been able to address through backports
unless we use #ifdef's. This would however require some sort of driver
specific backport_device_alloc(), backport_device_init() and a respective
backport_device_free(). The overhead would need to be considered unless
some fancy trickery is introduced. Since 09-threaded-irq is a backport
for kernels >= 2.6.31 I don't recommend we consider this now. The effort
for using SmPL for this series was done simply as a way to demonstrate
the power of Coccinelle.
5) Space fixes for extra code on Coccinelle modified branches:
This SmPL patch does some space modifications on the wil6210 [0], the reason
could be that Coccinelle is introducing some code on a branch and when it
detects this it puts the code it is adding with braces. This is another
great feature of Coccinelle but the space fixes that Julia has completed
may not be treated in that situation yet.
6) This requires at least spatch 1.0.0-rc20.
[0] hunk in question shown below:
@@ -499,11 +518,21 @@ int wil6210_init_irq(struct wil6210_priv *wil, int irq)
int rc;
if (wil->n_msi == 3)
rc = wil6210_request_3msi(wil, irq);
- else
+ else {
+#if LINUX_VERSION_CODE >= KERNEL_VERSION(2,6,31)
rc = request_threaded_irq(irq, wil6210_hardirq,
- wil6210_thread_irq,
- wil->n_msi ? 0 : IRQF_SHARED,
- WIL_NAME, wil);
+ wil6210_thread_irq,
+ wil->n_msi ? 0 : IRQF_SHARED,
+ WIL_NAME, wil);
+#else
+ rc = compat_request_threaded_irq(&wil->irq_compat, irq,
+ wil6210_hardirq,
+ wil->n_msi ? 0 :
IRQF_SHARED,
+ WIL_NAME,
+ wil);
+#endif
if (rc)
return rc;
Code generation time:
real 1m6.023s
user 10m0.276s
sys 0m26.196s
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.54 [ OK ]
19 3.3.8 [ OK ]
20 3.4.79 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.29 [ OK ]
27 3.11.10 [ OK ]
28 3.12.10 [ OK ]
29 3.13.2 [ OK ]
30 3.14-rc1 [ OK ]
real 41m12.052s
user 1125m30.996s
sys 151m39.096s
This reshufles the patches that deal with backported threaded
IRQ support. The purpose of this reshufle is to try get them
into a consistent style. Only the b43 driver takes a major
change in that the the workqueue used for threading work
is now also destroyed upon its b43_wireless_core_stop() call.
This change was tested by pkgadd from #linux-wireless on b43 on
an older kernel. The b43 driver just fails to unload but that
issue was present before this change.
The non-general changes to the b43 driver are also moved
out to a helper patch to help separate the general
collateral evolution changes from driver specific required
changes.
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.54 [ OK ]
19 3.3.8 [ OK ]
20 3.4.79 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.29 [ OK ]
27 3.11.10 [ OK ]
28 3.12.10 [ OK ]
29 3.13.2 [ OK ]
30 3.14-rc1 [ OK ]
Generation time:
real 1m32.523s
user 23m51.796s
sys 0m28.872s
Commit 633fc86ff62 added the ieee802154_6lowpan namespace
and 7240cdec60b extended it (as on linux-next next-20140311).
Its important to note though that 633fc86ff62 also extends the
global net namespace. Since we cannot extend the global net
namespace we define our own backport namespace for 6lowpan
that can be used only be used by our backported subsystems,
nothing more. Since ieee802154_6lowpan requires support for
net_get_random_once() which uses static keys and a slew of
new skb fragment support we simply require at least 3.5 to
use 6lowpan. I did my best effort to backport this to kernels
older than 3.5 but quickly ran into a slew of hairy issues.
The last thing we needed to address was usage of the helper
inet_frag_evictor() added by Alexander via commit 6b102865e7
through v3.7. Since we can't backport that with macros or
inline helpers we add a patch to carry the changes there. If
that grows we can consider using Coccinelle.
If you are going to try to backport 6lowpan to kernels older
than 3.5 be warned that the litmus test for patches will be
to pass ckmake --allyesconfig for all supported kernels for
every patch you provide.
Cc: Alexander Smirnov <alex.bluesman.smirnov@gmail.com>
Cc: Dmitry Eremin-Solenikov <dbaryshkov@gmail.com>
Cc: Amerigo Wang <amwang@redhat.com>
Cc: linux-zigbee-devel@lists.sourceforge.net
We can't generalize a backport of inet_frag_lru_move() as
it requires modifying an internal struct netns_frags struct.
We work around this by extending the parent struct used within
6lowpan. We have two changes, one data structure change
and then a domain specific defines. Other subsystems which
require similar work can backport usage through similar
techniques.
The respective change upstream that put the lock on
struct netns_frags is commit 3ef0eb0db4 added by
through v3.9.
mcgrof@ergon ~/linux-next (git::master)$ git describe --contains 3ef0eb0db4
v3.9-rc1~139^2~232^2
commit 3ef0eb0db4bf92c6d2510fe5c4dc51852746f206
Author: Jesper Dangaard Brouer <brouer@redhat.com>
Date: Mon Jan 28 23:45:51 2013 +0000
net: frag, move LRU list maintenance outside of rwlock
Updating the fragmentation queues LRU (Least-Recently-Used) list,
required taking the hash writer lock. However, the LRU list isn't
tied to the hash at all, so we can use a separate lock for it.
Original-idea-by: Florian Westphal <fw@strlen.de>
Signed-off-by: Jesper Dangaard Brouer <brouer@redhat.com>
Cc: Jesper Dangaard Brouer <brouer@redhat.com>
Commit a48e4292 introduced as of v3.13 is used by 6lowpan which
we backport. We carry this over for older kernels that don't
define it -- but we remain sane by requiring at least 3.5 which is
where tons of the jump label / static key stuff seems to have last
settled. Backporting this to any older kernel than 3.5 has a huge
string of dependencies which although I was able to resovle the
other depdendencies on 6lowpan on new net core re-architecture on
skb fragment reassembly makes it pointless to carry. Mark my words:
!! do not try to backport this to kernels older than 3.5 !!
mcgrof@ergon ~/linux (git::master)$ git describe --contains a48e4292
v3.13-rc1~105^2~157^2~4
commit a48e42920ff38bc90bbf75143fff4555723d4540
Author: Hannes Frederic Sowa <hannes@stressinduktion.org>
Date: Sat Oct 19 21:48:55 2013 +0200
net: introduce new macro net_get_random_once
Cc: Hannes Frederic Sowa <hannes@stressinduktion.org>
The ieee802154 subsystem, which we backport, makes use of
net_get_random_once() through net/ieee802154/reassembly.c
and this in turn makes use of the static keys. Static keys
were split out from the jump label support via commit c5905afb
by Ingo through kernel v3.3 -- note that git describe --contains
will disagree and say its v3.5. Jump label support was added by
Jason via commit bf5438fc through kernel v2.6.37 but later
Jason provided static branch optimizations via commit d430d3d7e
added through v3.0. static_key_initialized and STATIC_KEY_CHECK_USE()
were last added by Hannes through kernel v3.13 throughy c4b2c0c5f.
In order to backport static keys and jump label we need to
provide name mapping for kernels that only had jump label support,
but due to the static branch optimizations and since these are
architecture specific we cannot backport them unless we start carrying
around architecture replacement code -- or do some other trickery.
For kernels that lacked jump label support and that don't have the
static branch optimizations we simply carry in the kernel implmentation
that assumes you have no architecture support for jump label which
treats the labels as simply atomic drivers for branches. For older
kernels then we don't backport usage of static_key_initialized and
usage of STATIC_KEY_CHECK_USE().
This does leave a gap of kernels without static key / jump label
support, I tried backporting it but ran into issues quickly. Those
daring to continue to embark on this journey can pick up where
I left off:
[0] drvbp1.linux-foundation.org/~mcgrof/examples/2014/04/01/backport-static-keys.patch
I will note that properly backporting this can have implications on how
we backport tracing support as that is the main usage for jump labels.
Real enthusiasts can go ahead an extend this with architecture / kernel
revision specific changes -- but be warned -- we will have hard litmus
test for compilation on backports using ckmake --allyesconfig on all
supported kernels we carry.
This is a long way of saying -- we require at least 3.5 for static
key support, we also support kernels older than 2.6.37 but this goes
untested.
mcgrof@ergon ~/linux (git::master)$ git describe --contains bf5438fc
v2.6.37-rc1~214^2~33^2~8
mcgrof@ergon ~/linux (git::master)$ git describe --contains d430d3d7e
v3.0-rc1~404^2~18^2~2
mcgrof@ergon ~/linux (git::master)$ git describe --contains c5905afb
v3.5-rc1~120^3~76^2 -- wrong! Its actually v3.3 try:
git checkout -b static-changes c5905afb; git describe
mcgrof@ergon ~/linux (git::master)$ git describe --contains c4b2c0c5f
v3.13-rc1~105^2~157^2~6
Cc: Jason Baron <jbaron@redhat.com>
CC: Jason Baron <jbaron@redhat.com>
