Upstream commit: cc0d8fe44ec0a46d939398feb8bc38d0db8eb341
sign_extend32() is also backported by the RHEL kernel, this fixes a
compile problem.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Upstream commit: ad1332154c6018ed9783bf2d46ae338e6eca8542
allyesconfig was mentioned in the help dialog twice.
Upstream commit: 351423240e69e385b7433adb555b739e05af3def
Sometimes these functions are backported in the kernel, add the
backports_ prefix to prevent the names from colliding.
Upstream commit: 153c22dd7d65ac8e607e682c834316a164dba5b6
In some places backports checked for the kernel version on weather to
add a own define for module_driver or not. This patch makes it check if
there is already one or not.
Upstream commit: 74571a07a608daf241433172ee398c0b71188af8
These files are now copied from the kernel like normal files we take
from the kernel.
Upstream commit: f79d7b9a86bbce15db9344b69770b37b122f6872
This file is now copied from the kernel like a normal file we take from
the kernel.
Upstream commit: 44a6205a3afbbab76ec292a4b4edad16b1ac9d15
This file was never included.
Upstream commit: 78005c5b2e5682cec16aeb5f94f478e115dde4f5
kref_get_unless_zero() was never called by any code.
Upstream commit: 7e5e6782399fbd41f6d7f323d3c5b8d0c72190b3
Upstream commit: 46ea32e1ded36972b1793688a24848c4d5015ddb
hex_byte_pack() was never called by any code.
Upstream commit: 323f250dcef7ca2e360710058b8c802fc6ee673d
vlan_hw_offload_capable() was never called by any code.
Upstream commit: da80ee946168180cbf5a3f0455283acc71fdf295
fb_enable_skip_vt_switch() was never called by any code.
Upstream commit: 7ef2a4cd90a1492213a1d2d6bdb227af2931bb43
ethtool_rxfh_indir_default() was never called by any code.
Upstream commit: a064620db7bd276dd9160757c3ddb4e8a07f5c48
Non of these defines or functions where used by any code.
Upstream commit: 84453052c585d2dd101e74c43663615013afa64d
irq_set_affinity_hint() was never called by any code. This makes it
possible to remove struct cpumask.
Upstream commit: 97147b1ee4f249d03a0efb2833779db7ffc02bee
atomic_inc_not_zero_hint() was never called by any code.
Upstream commit: d2ef02764096bb69f4edb721084bf373d956084a
acpi_video_register_with_quirks() was never called by any code.
Upstream commit: 6b7c0a75c11776b3a07df11c2132f4ea34bec0e7
The driver is not included in backports and we should use the in kernel
headers.
Upstream commit: 162a33256456453b305b0de9df19d07a4091981d
There is some code for the mdio driver in backports, but it does not
get build on any kernel, just remove it till someone wants to make it
work.
== ckmake-report.log ==
1 2.6.24 [ FAIL ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.101 [ OK ]
18 3.1.10 [ OK ]
19 3.10.20 [ OK ]
20 3.11.9 [ OK ]
21 3.12.1 [ OK ]
22 3.13-rc1 [ OK ]
23 3.2.52 [ OK ]
24 3.3.8 [ OK ]
25 3.4.70 [ OK ]
26 3.5.7 [ OK ]
27 3.6.11 [ OK ]
28 3.7.10 [ OK ]
29 3.8.13 [ OK ]
30 3.9.11 [ OK ]
1 2.6.24 [ FAIL ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.101 [ OK ]
18 3.1.10 [ OK ]
19 3.10.20 [ OK ]
20 3.11.9 [ OK ]
21 3.12.1 [ OK ]
22 3.13-rc1 [ OK ]
23 3.2.52 [ OK ]
24 3.3.8 [ OK ]
25 3.4.70 [ OK ]
26 3.5.7 [ OK ]
27 3.6.11 [ OK ]
28 3.7.10 [ OK ]
29 3.8.13 [ OK ]
30 3.9.11 [ OK ]
current_user_ns() is used by seq_user_ns() if CONFIG_USER_NS is set and
kernel version <= 2.6.38.
This was added to the kernel in version 2.6.29.
Add kernel 3.13-rc1 and update the other kernel versions.
On kernels that already have pre_doit/post_doit, we don't
fake them by re-assigning all ops and their doit, but then
we clearly need to copy the pointers. Fix that oversight.
1 2.6.24 [ FAIL ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.101 [ OK ]
18 3.1.10 [ OK ]
19 3.10.17 [ OK ]
20 3.11.6 [ OK ]
21 3.12-rc7 [ OK ]
22 3.2.52 [ OK ]
23 3.3.8 [ OK ]
24 3.4.67 [ OK ]
25 3.5.7 [ OK ]
26 3.6.11 [ OK ]
27 3.7.10 [ OK ]
28 3.8.13 [ OK ]
29 3.9.11 [ OK ]
ARIZONA needs struct regulator_linear_range which was added in kernel 3.12.
This is not used anywhere.
The Debian Wheezy kernel also includes this function and it conflicted
with backports version.
I recently changed the generic netlink registration and multicast
group APIs to be safer. Backport these changes by implementing all
the new APIs in terms of what was in the kernel before.
There's no need to carry a small netdev ops patch for
each driver any more now, we can just write a small
semantic patch. Only the ndo_ioctl() part is easier
to keep as a separate patch.
As some stupid drivers seem to set their ops to NULL
just before freeing the netdev anyway, the attach
function must gracefully handle that (but not doesn't
really need to do anything.)
The netdev_for_each_mc_addr() handling can be done with a
semantic patch and a simple macro encapsulating the addr
dereferencing for the two cases.
In fact, this already fixed a bug in dvb_net.c, although
I think that depends on a newer kernel anyway.
Thanks Julia for the help with iterator name!
Acked-by: Julia Lawall <julia.lawall@lip6.fr>
Signed-off-by: Jason Mobarak <jam@cozybit.com>
Instead of copying bitops.h from upstream just add what's missing in
older kernel.
Signed-off-by: Stefan Assmann <sassmann@kpanic.de>
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.10.17 [ OK ]
19 3.11.6 [ OK ]
20 3.12-rc7 [ OK ]
21 3.2.52 [ OK ]
22 3.3.8 [ OK ]
23 3.4.67 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
This is needed by drivers/media/dvb-core/dvbdev.c and was added in:
commit e84f9e57b90ca89664d733a7cef19aa7ccd832f3
Author: Al Viro <viro@zeniv.linux.org.uk>
Date: Sun Sep 22 14:17:15 2013 -0400
consolidate the reassignments of ->f_op in ->open() instances
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.10.17 [ OK ]
19 3.11.6 [ OK ]
20 3.12-rc7 [ OK ]
21 3.2.52 [ OK ]
22 3.3.8 [ OK ]
23 3.4.67 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
backports already exports these functions in
drivers/media/platform/soc_camera/soc_camera.c
We can not easily backport ipv6_stub which provides some IPv6 function
callbacks. These patches are removing usage of ipv6_stub which was
introduces in this commit:
commit 5f81bd2e5d804ca93f3ec8873451b22d2f454721
Author: Cong Wang <amwang@redhat.com>
Date: Sat Aug 31 13:44:30 2013 +0800
ipv6: export a stub for IPv6 symbols used by vxlan
kfifo_put() now gets the second parameter by value and not by reference
any more. This replaces the in kernel implementation of kfifo_put()
with a version which is compatible to the in kernel structures but
takes the value and not a reference to the value. We wanted to do this:
#define kfifo_put(fifo, val) kfifo_put(fifo, &val)
This brings kfifo to the state of next-20131106.
__vlan_find_dev_deep() got an extra parameter in recent kernel versions.
This is needed by drivers/net/usb/cdc_mbim.c
This is needed by drivers/bluetooth/btmrvl_main.c
This removes the KERNEL_HAS_OF_SUPPORT option from backports.
We can not include linux/of.h on kernel < 2.6.34, because this depends
on some sparc and powerpc only headers. The backport code should still
be included in this header file for such kernel versions, because some
recent drivers are using these functions now on all platforms, but they
will use the empty implementations then.
The backported parts of tty are depending on tty being build into the
kernel, deactivate them if tty was not activated in the kernel config.
The backported parts of the regulator subsystem are depending on the
regulator subsystem being build into the kernel, deactivate them if the
regulator subsystem was not activated in the kernel config.
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.10.17 [ OK ]
19 3.11.6 [ OK ]
20 3.12-rc7 [ OK ]
21 3.2.52 [ OK ]
22 3.3.8 [ OK ]
23 3.4.67 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
debugfs_create_x64() is provided by the RHEL 6.4 kernel and should not
be added to the build on such a kernel.
Introduce the infrastructure to apply semantic patches
and make use of it for the (frequently breaking) portid
patch for netlink.
Unfortunately this is significantly slower:
before:
real 0m14.312s
user 0m12.144s
sys 0m1.784s
after:
real 0m25.932s
user 0m21.768s
sys 0m2.932s
This brings the kernels test test against to the latest versions.
