== ckmake-report.log ==
1 2.6.24 [ FAIL ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.101 [ OK ]
18 3.1.10 [ OK ]
19 3.10.20 [ OK ]
20 3.11.9 [ OK ]
21 3.12.1 [ OK ]
22 3.13-rc1 [ OK ]
23 3.2.52 [ OK ]
24 3.3.8 [ OK ]
25 3.4.70 [ OK ]
26 3.5.7 [ OK ]
27 3.6.11 [ OK ]
28 3.7.10 [ OK ]
29 3.8.13 [ OK ]
30 3.9.11 [ OK ]
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
1 2.6.24 [ FAIL ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.101 [ OK ]
18 3.1.10 [ OK ]
19 3.10.20 [ OK ]
20 3.11.9 [ OK ]
21 3.12.1 [ OK ]
22 3.13-rc1 [ OK ]
23 3.2.52 [ OK ]
24 3.3.8 [ OK ]
25 3.4.70 [ OK ]
26 3.5.7 [ OK ]
27 3.6.11 [ OK ]
28 3.7.10 [ OK ]
29 3.8.13 [ OK ]
30 3.9.11 [ OK ]
current_user_ns() is used by seq_user_ns() if CONFIG_USER_NS is set and
kernel version <= 2.6.38.
This was added to the kernel in version 2.6.29.
Add kernel 3.13-rc1 and update the other kernel versions.
On kernels that already have pre_doit/post_doit, we don't
fake them by re-assigning all ops and their doit, but then
we clearly need to copy the pointers. Fix that oversight.
1 2.6.24 [ FAIL ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.101 [ OK ]
18 3.1.10 [ OK ]
19 3.10.17 [ OK ]
20 3.11.6 [ OK ]
21 3.12-rc7 [ OK ]
22 3.2.52 [ OK ]
23 3.3.8 [ OK ]
24 3.4.67 [ OK ]
25 3.5.7 [ OK ]
26 3.6.11 [ OK ]
27 3.7.10 [ OK ]
28 3.8.13 [ OK ]
29 3.9.11 [ OK ]
ARIZONA needs struct regulator_linear_range which was added in kernel 3.12.
This is not used anywhere.
The Debian Wheezy kernel also includes this function and it conflicted
with backports version.
I recently changed the generic netlink registration and multicast
group APIs to be safer. Backport these changes by implementing all
the new APIs in terms of what was in the kernel before.
There's no need to carry a small netdev ops patch for
each driver any more now, we can just write a small
semantic patch. Only the ndo_ioctl() part is easier
to keep as a separate patch.
As some stupid drivers seem to set their ops to NULL
just before freeing the netdev anyway, the attach
function must gracefully handle that (but not doesn't
really need to do anything.)
The netdev_for_each_mc_addr() handling can be done with a
semantic patch and a simple macro encapsulating the addr
dereferencing for the two cases.
In fact, this already fixed a bug in dvb_net.c, although
I think that depends on a newer kernel anyway.
Thanks Julia for the help with iterator name!
Acked-by: Julia Lawall <julia.lawall@lip6.fr>
Signed-off-by: Jason Mobarak <jam@cozybit.com>
Instead of copying bitops.h from upstream just add what's missing in
older kernel.
Signed-off-by: Stefan Assmann <sassmann@kpanic.de>
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.10.17 [ OK ]
19 3.11.6 [ OK ]
20 3.12-rc7 [ OK ]
21 3.2.52 [ OK ]
22 3.3.8 [ OK ]
23 3.4.67 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
This is needed by drivers/media/dvb-core/dvbdev.c and was added in:
commit e84f9e57b90ca89664d733a7cef19aa7ccd832f3
Author: Al Viro <viro@zeniv.linux.org.uk>
Date: Sun Sep 22 14:17:15 2013 -0400
consolidate the reassignments of ->f_op in ->open() instances
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.10.17 [ OK ]
19 3.11.6 [ OK ]
20 3.12-rc7 [ OK ]
21 3.2.52 [ OK ]
22 3.3.8 [ OK ]
23 3.4.67 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
backports already exports these functions in
drivers/media/platform/soc_camera/soc_camera.c
We can not easily backport ipv6_stub which provides some IPv6 function
callbacks. These patches are removing usage of ipv6_stub which was
introduces in this commit:
commit 5f81bd2e5d804ca93f3ec8873451b22d2f454721
Author: Cong Wang <amwang@redhat.com>
Date: Sat Aug 31 13:44:30 2013 +0800
ipv6: export a stub for IPv6 symbols used by vxlan
kfifo_put() now gets the second parameter by value and not by reference
any more. This replaces the in kernel implementation of kfifo_put()
with a version which is compatible to the in kernel structures but
takes the value and not a reference to the value. We wanted to do this:
#define kfifo_put(fifo, val) kfifo_put(fifo, &val)
This brings kfifo to the state of next-20131106.
__vlan_find_dev_deep() got an extra parameter in recent kernel versions.
This is needed by drivers/net/usb/cdc_mbim.c
This is needed by drivers/bluetooth/btmrvl_main.c
This removes the KERNEL_HAS_OF_SUPPORT option from backports.
We can not include linux/of.h on kernel < 2.6.34, because this depends
on some sparc and powerpc only headers. The backport code should still
be included in this header file for such kernel versions, because some
recent drivers are using these functions now on all platforms, but they
will use the empty implementations then.
The backported parts of tty are depending on tty being build into the
kernel, deactivate them if tty was not activated in the kernel config.
The backported parts of the regulator subsystem are depending on the
regulator subsystem being build into the kernel, deactivate them if the
regulator subsystem was not activated in the kernel config.
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.10.17 [ OK ]
19 3.11.6 [ OK ]
20 3.12-rc7 [ OK ]
21 3.2.52 [ OK ]
22 3.3.8 [ OK ]
23 3.4.67 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
debugfs_create_x64() is provided by the RHEL 6.4 kernel and should not
be added to the build on such a kernel.
Introduce the infrastructure to apply semantic patches
and make use of it for the (frequently breaking) portid
patch for netlink.
Unfortunately this is significantly slower:
before:
real 0m14.312s
user 0m12.144s
sys 0m1.784s
after:
real 0m25.932s
user 0m21.768s
sys 0m2.932s
This brings the kernels test test against to the latest versions.
The folder name did not started with an v.
Signed-off-by: Sujith Manoharan <c_manoha@qca.qualcomm.com>
Without this slash it wants to use the directory /backportsstable/
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.98 [ OK ]
17 3.1.10 [ OK ]
18 3.10.14 [ OK ]
19 3.11.3 [ OK ]
20 3.12-rc3 [ OK ]
21 3.2.51 [ OK ]
22 3.3.8 [ OK ]
23 3.4.64 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
fw-api-d3.h in the iwlwifi driver uses struct in6_addr and somehow it
does not get included on all kernel versions like 2.6.25. This patch
adds the missing include for linux/in6.h to fix the problem.
This was added in the following upstream commit:
commit d0f1fed29e6e73d9d17f4c91a5896a4ce3938d45
Author: Jonathan Cameron <jic23@cam.ac.uk>
Date: Tue Apr 19 12:43:45 2011 +0100
Add a strtobool function matching semantics of existing in kernel equivalents
commit 6d7581e62f8be462440d7b22c6361f7c9fa4902b
Author: Jiri Pirko <jiri@resnulli.us>
Date: Wed May 29 05:02:56 2013 +0000
list: introduce list_first_entry_or_null
This adds ath10k, wcn36xx and rt3573 to the default wifi config.
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.98 [ OK ]
17 3.1.10 [ OK ]
18 3.10.14 [ OK ]
19 3.11.3 [ OK ]
20 3.12-rc3 [ OK ]
21 3.2.51 [ OK ]
22 3.3.8 [ OK ]
23 3.4.64 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
bcma and ssb are using the new sysfs API starting with kernel 3.12.
In struct class the new sysfs dev_groups member was added with kernel
3.11, but in other structs, like struct bus_type the new member was
added with kernel 3.12. This backport is now needed on different kernel
versions depending on the struct where is was used.
With this patch ATTRIBUTE_GROUPS() will always be used with the new API
and ATTRIBUTE_GROUPS_BACKPORT() will always be used used with the old
API and the patch has to add a KERNEL_VERSION check to add the correct
macro.
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.98 [ OK ]
17 3.1.10 [ OK ]
18 3.10.14 [ OK ]
19 3.11.3 [ OK ]
20 3.12-rc3 [ OK ]
21 3.2.51 [ OK ]
22 3.3.8 [ OK ]
23 3.4.64 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
It should be safe to add them for older kernel versions, there these
values were hard coded in other places.
This was added in linux-2.6.33.
Manual fixes where needed in:
patches/collateral-evolutions/network/09-threaded-irq/drivers_net_wireless_ti_wlcore_main.patch
patches/collateral-evolutions/network/40-netdev-hw-features/drivers_net_ethernet_atheros_atl1e_atl1e_main.patch
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.98 [ OK ]
17 3.1.10 [ OK ]
18 3.10.14 [ OK ]
19 3.11.3 [ OK ]
20 3.12-rc3 [ OK ]
21 3.2.51 [ OK ]
22 3.3.8 [ OK ]
23 3.4.64 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
When these are set to 0 on kernels where they are not supported it
should result in them not being used at all.
This adapts the changes from:
commit 60e453a940ac678565b6641d65f8c18541bb9f28
Author: Ming Lei <ming.lei@canonical.com>
Date: Mon Sep 23 20:59:35 2013 +0800
USBNET: fix handling padding packet
