Upstream commit: a00d7b07a89d1bb0b6c9a51bfec4e53a76940bb3
debugfs_create_x64() is provided by the RHEL 6.4 kernel and should not
be added to the build on such a kernel.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.10.17 [ OK ]
19 3.11.6 [ OK ]
20 3.12-rc7 [ OK ]
21 3.2.52 [ OK ]
22 3.3.8 [ OK ]
23 3.4.67 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
Upstream commit: ba0cdc6fb4891c9efc91f627698c8203583f0e52
This adapts the changes from:
commit 60e453a940ac678565b6641d65f8c18541bb9f28
Author: Ming Lei <ming.lei@canonical.com>
Date: Mon Sep 23 20:59:35 2013 +0800
USBNET: fix handling padding packet
Upstream commit: 72657d3ff7c144a85b0b916c81bfeaa54e2d623f
The folder name did not started with an v.
Upstream commit: 4fb89169e8a5969388b16771695452f55ceb43e6
Without this slash it wants to use the directory /backportsstable/
== ckmake-report.log ==
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.98 [ OK ]
17 3.1.10 [ OK ]
18 3.10.14 [ OK ]
19 3.11.3 [ OK ]
20 3.12-rc3 [ OK ]
21 3.2.51 [ OK ]
22 3.3.8 [ OK ]
23 3.4.64 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.98 [ OK ]
17 3.1.10 [ OK ]
18 3.10.14 [ OK ]
19 3.11.3 [ OK ]
20 3.12-rc3 [ OK ]
21 3.2.51 [ OK ]
22 3.3.8 [ OK ]
23 3.4.64 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
This caused a compile warning and probably runtime errors in
sch_fq_codel_core.c
The newly created function ends with _compat. This causes compile
warnings and probably runtime problems on kernel < 2.6.29.
The functions will only build for kernel version < 3.10 and >= 2.6.28,
so the same with the prototype.
This does not compile on kernel < 3.12.
addr_assign_type was added with kernel 2.6.36. This is just used to
inform userspace, so removing it is no problem.
This is needed by drivers/net/wireless/libertas/mesh.c
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.98 [ OK ]
17 3.1.10 [ OK ]
18 3.10.14 [ OK ]
19 3.11.3 [ OK ]
20 3.12-rc3 [ FAIL ]
21 3.2.51 [ OK ]
22 3.3.8 [ OK ]
23 3.4.64 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
These drivers are depending on changes of the regulator core driver
which are not in the specific kernel versions.
This only used by the DRM drivers
This was just used by some GPU drivers
This was only used by the DRM drivers
This was only needed for some of the DRM drivers, remove it.
This is not used by any code in backports, not even a DRM driver.
The platform drivers were only needed by some DRM drivers and are not
needed any more with the DRM driver being removed.
Maintaining the DRM driver takes a lot of recourses as there they are
depending on many API changes done to the core kernel code and
currently we do not have that many recourses to follow them. On the
other side one needs also new userspace drivers to make use of the new
features added to the DRM kernel drivers and it is not easy to update
the X drivers. Therefore we came to the conclusion to remove the drm
drivers for now.
There were also some problems with some DRM drivers, like the Intel
i915 driver caused kernel panic on some systems and was probably only
usable on some very recent kernel versions.
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.98 [ OK ]
17 3.1.10 [ OK ]
18 3.10.14 [ OK ]
19 3.11.3 [ OK ]
21 3.2.51 [ OK ]
22 3.3.8 [ OK ]
23 3.4.64 [ OK ]
24 3.5.7 [ OK ]
25 3.6.11 [ OK ]
26 3.7.10 [ OK ]
27 3.8.13 [ OK ]
28 3.9.11 [ OK ]
MSR_RAPL_POWER_UNIT is not available on older kernel versions.
This is needed by ./net/bluetooth/rfcomm/tty.c
This file was newly added to drm.
This is used by drivers/media/v4l2-core/v4l2-dev.c.
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.89 [ OK ]
17 3.1.10 [ OK ]
18 3.10.5 [ OK ]
19 3.11-rc4 [ OK ]
20 3.2.50 [ OK ]
21 3.3.8 [ OK ]
22 3.4.56 [ OK ]
23 3.5.7 [ OK ]
24 3.6.11 [ OK ]
25 3.7.10 [ OK ]
26 3.8.13 [ OK ]
27 3.9.11 [ OK ]
REGULATOR_PALMASi now needs some symbols form headers of very recent
kernel versions.
This adds debugfs_create_x64() by calling debugfs_create_u64() instead.
The 64 bit number is then not hex, but dec formated in debug fs.
the usb net driver now uses the dma sg api which is not available on
old kernels, this patch removed the usage of the dma sg api for old
kernel versions.
This backports the following upstream commit:
commit 638c5115a794981441246fa8fa5d95c1875af5ba
Date: Thu Aug 8 21:48:24 2013 +0800
USBNET: support DMA SG
Usage of a new led api was introduced in mac80211, this patch make
backports use the old api on older kernel versions. This could cause a
problem with the led, the transmit led could stay on if nothing is
transfered.
commit e47f2509e5f182f4df144406de6f2bc78179d57e
Author: Fabio Baltieri <fabio.baltieri@gmail.com>
Date: Thu Jul 25 12:00:26 2013 +0200
mac80211: use oneshot blink API for LED triggers
In this upstream commit a new usage of portid was introduced:
commit ac22ac466a659f1b2e02a2e2ee23fc5c42da2c95
Author: Samuel Ortiz <sameo@linux.intel.com>
Date: Wed Jul 24 18:10:50 2013 +0200
NFC: Add a GET_SE netlink API
