Upstream commit 2bbf9dda81f21c08be51a1c61c0d2eb701c7af94
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
Upstream commit 8d10f3b2021e8644ee00cbc030290f45c4d176d9
Using openSUSE 12.3 with x86_64 architecture, the 'make menuconfig'
command results in the following:
finger@larrylap:~/backports-3.10-rc1-1> make menuconfig
cc -Wl,--no-as-needed -lncurses mconf.o zconf.tab.o lxdialog/checklist.o lxdialog/inputbox.o lxdialog/menubox.o lxdialog/textbox.o lxdialog/util.o lxdialog/yesno.o -o mconf
/usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../x86_64-suse-linux/bin/ld: /lib64/libncurses.so.5: undefined reference to symbol 'acs_map'
/usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../x86_64-suse-linux/bin/ld: note: 'acs_map' is defined in DSO /usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../lib64/libtinfo.so so try adding it to the linker command line
/usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../lib64/libtinfo.so: could not read symbols: Invalid operation
collect2: error: ld returned 1 exit status
make[2]: *** [mconf] Error 1
make[1]: *** [menuconfig] Error 2
make: *** [menuconfig] Error 2
When "-ltinfo" is added to the LDFLAGS symbol as suggested by the linker,
it builds and runs correctly.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 17m9.368s
user 403m46.554s
sys 95m42.811s
[mcgrof: tested with ckmake]
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m50.520s
user 815m12.233s
sys 127m49.075s
Directory copying is recursive, so there's no need
to list subdirectories. All atheros ethernet drivers
are copied, so don't list them one by one. The same
is true for the Bluetooth include files.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m46.042s
user 816m2.488s
sys 126m33.079s
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m45.327s
user 814m25.678s
sys 128m22.341s
Samuel folded code under net/nfc/llcp/ onto
the parent net/nfc/ directory with llcp_ prefixes
for the files. Address this change introduced
as of next-20130430.
commit 30cc4587659e1c9b1bfade8b2a757d91e04758ab
Author: Samuel Ortiz <sameo@linux.intel.com>
Date: Fri Apr 26 11:49:40 2013 +0200
NFC: Move LLCP code to the NFC top level diirectory
And stop making it optional. LLCP is a fundamental part of the NFC
specifications and making it optional does not make much sense.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m48.875s
user 815m54.307s
sys 127m12.229s
The recent file shuffling on nouveau requires some
changes not upstream to get it to compile to ensure
some objects do get interpreted as requiring the
new search path.
mcgrof@frijol ~/linux-stable (git::master)$ git describe --contains 271a15ea
v3.10-rc1~129^2~24
commit 271a15eabe094538d958dc68ccfc9c36b699247a
Author: David Howells <dhowells@redhat.com>
Date: Fri Apr 12 00:38:51 2013 +0100
proc: Supply PDE attribute setting accessor functions
Supply accessor functions to set attributes in proc_dir_entry structs.
The following are supplied: proc_set_size() and proc_set_user().
Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com>
cc: linuxppc-dev@lists.ozlabs.org
cc: linux-media@vger.kernel.org
cc: netdev@vger.kernel.org
cc: linux-wireless@vger.kernel.org
cc: linux-pci@vger.kernel.org
cc: netfilter-devel@vger.kernel.org
cc: alsa-devel@alsa-project.org
This was missing.
Intorduced in next-20130429 and Linus has merged it
onto v3.10-rc1. We cannot backport remove_proc_subtree()
modularly [0] so just go ahead and revert this change.
The alternative is to go and review each procfs usage
for each driver we have issues and see if it makes
sense to replace procs with debugfs upstream.
commit 8ce584c7416d8a85a6f3edc17d1cddefe331e87e
Author: Al Viro <viro@zeniv.linux.org.uk>
Date: Sat Mar 30 20:13:46 2013 -0400
procfs: add proc_remove_subtree()
just what it sounds like; do that only to procfs subtrees you've
created - doing that to something shared with another driver is
not only antisocial, but might cause interesting races with
proc_create() and its ilk.
[0] http://marc.info/?t=136841961600002&r=1&w=2
This doesn't make sense since we'd have no way of knowing
when such a patch should be applied. Right now the patch
would be ignored, but make it extra obvious and error out
on such patches.
The new backport rfkill approach caused a sparse warning:
linux/rfkill.h:70:43: warning: mixing different enum types
linux/rfkill.h:70:43: int enum rfkill_type versus
linux/rfkill.h:70:43: int enum old_rfkill_type
Fix it by adding a cast.
== ckmake-report.log ==
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m52.106s
user 816m17.749s
sys 127m27.702s
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m48.012s
user 814m18.301s
sys 127m38.575s
This is required by some drivers as of next-20130424.
commit fcf371ee5624cc87abac205cd0dad2432d7f0346
Author: Axel Lin <axel.lin@ingics.com>
Date: Thu Apr 18 10:34:49 2013 +0800
regulator: core: Add regulator_map_voltage_ascend() API
A lot of regulator hardware has ascendant voltage list.
This patch adds regulator_map_voltage_ascend() and export it.
Drivers that have ascendant voltage list can use this as their map_voltage()
operation, this is more efficient than default regulator_map_voltage_iterate()
function.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m53.044s
user 815m38.362s
sys 127m50.187s
This addresses the last remaining components to
backport the ethernet vlan changes introduced by
9356b8fc d314774c and f646968f8f on next-20130423.
This backports 9356b8fc d314774c and f646968f8f
all added in next-20130423. Soome driver changes are
still required and will be addressed separately.
commit 9356b8fc07dc126cd91d2b12f314d760ab48996e
Author: Eric Dumazet <dada1@cosmosbay.com>
Date: Tue Sep 27 15:23:16 2005 -0700
[NET]: Reorder some hot fields of struct net_device
Place them on separate cache lines in SMP to lower memory bouncing
between multiple CPU accessing the device.
- One part is mostly used on receive path (including
eth_type_trans()) (poll_list, poll, quota, weight, last_rx,
dev_addr, broadcast)
- One part is mostly used on queue transmit path (qdisc)
(queue_lock, qdisc, qdisc_sleeping, qdisc_list, tx_queue_len)
- One part is mostly used on xmit path (device)
(xmit_lock, xmit_lock_owner, priv, hard_start_xmit, trans_start)
'features' is placed outside of these hot points, in a location that
may be shared by all cpus (because mostly read)
name_hlist is moved close to name[IFNAMSIZ] to speedup __dev_get_by_name()
Signed-off-by: Eric Dumazet <dada1@cosmosbay.com>
commit d314774cf2cd5dfeb39a00d37deee65d4c627927
Author: Stephen Hemminger <shemminger@vyatta.com>
Date: Wed Nov 19 21:32:24 2008 -0800
netdev: network device operations infrastructure
This patch changes the network device internal API to move adminstrative
operations out of the network device structure and into a separate structure.
This patch involves some hackery to maintain compatablity between the
new and old model, so all 300+ drivers don't have to be changed at once.
For drivers that aren't converted yet, the netdevice_ops virt function list
still resides in the net_device structure. For old protocols, the new
net_device_ops are copied out to the old net_device pointers.
After the transistion is completed the nag message can be changed to
an WARN_ON, and the compatiablity code can be made configurable.
Some function pointers aren't moved:
* destructor can't be in net_device_ops because
it may need to be referenced after the module is unloaded.
* neighbor setup is manipulated in a couple of places that need special
consideration
* hard_start_xmit is in the fast path for transmit.
commit f646968f8f7c624587de729115d802372b9063dd
Author: Patrick McHardy <kaber@trash.net>
Date: Fri Apr 19 02:04:27 2013 +0000
net: vlan: rename NETIF_F_HW_VLAN_* feature flags to NETIF_F_HW_VLAN_CTAG_*
Rename the hardware VLAN acceleration features to include "CTAG" to indicate
that they only support CTAGs. Follow up patches will introduce 802.1ad
server provider tagging (STAGs) and require the distinction for hardware not
supporting acclerating both.
The new code for the "critical protocol indication" uses
snd_portid and must be adjusted in the backport patches.
This is required as of next-20130423.
commit 5de17984898c5758fc6ebe08eccea9f4b6548914
Author: Arend van Spriel <arend@broadcom.com>
Date: Thu Apr 18 15:49:00 2013 +0200
cfg80211: introduce critical protocol indication from user-space
Some protocols need a more reliable connection to complete
successful in reasonable time. This patch adds a user-space
API to indicate the wireless driver that a critical protocol
is about to commence and when it is done, using nl80211 primitives
NL80211_CMD_CRIT_PROTOCOL_START and NL80211_CRIT_PROTOCOL_STOP.
There can be only on critical protocol session started per
registered cfg80211 device.
The driver can support this by implementing the cfg80211 callbacks
.crit_proto_start() and .crit_proto_stop(). Examples of protocols
that can benefit from this are DHCP, EAPOL, APIPA. Exactly how the
link can/should be made more reliable is up to the driver. Things
to consider are avoid scanning, no multi-channel operations, and
alter coexistence schemes.
Reviewed-by: Pieter-Paul Giesberts <pieterpg@broadcom.com>
Reviewed-by: Franky (Zhenhui) Lin <frankyl@broadcom.com>
Signed-off-by: Arend van Spriel <arend@broadcom.com>
[mcgrof@do-not-panic.com]: Required as of next-20130423
and provided commit log message that introduced this
change.
There's only a single user of vb2_mmap_pfn_range() and
at least on 3.2 having the function in compat-3.9.c is
problematic if CPTCFG_BACKPORT_BUILD_DMA_SHARED_BUFFER
isn't set, because on that kernel there's no dma-buf.h
and then compilation can fail.
There's not much point in backporting rfkill, if the base kernel
doesn't have it then providing the it as /dev/rfkill_backport
won't be picked up by any apps, and if the base kernel has it
then it would cause odd behaviour as the base kernel's platform
drivers using the rfkill API would not talk to the backported
modules rfkill.
An unusable backported rfkill isn't much better than not having
it at all, so change the way we backport rfkill and don't carry
the code but simply provide the API as wrappers.
If the base kernel is 3.10 or higher (the current version) then
don't change anything at all.
If the base kernel is 2.6.33 or higher (with the new rfkill API)
then just wrap the API and disable rfkill registrations for any
types that the base kernel doesn't know about.
For all other kernels, provide only static inlines that behave
like the rfkill API when rfkill isn't compiled in.
The downside is that we need to copy the rfkill API. This is,
however, very very stable (it essentially hasn't changed since
2.6.33), so that's not a problem.
Just as an alias for 'install'.
Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
This is a no-op for the modular use case of the
backports project but by enabling this it allows
for developers a way to embed the backports releases
onto a target source Linux directory, with obvious
pending modifications, by adding our backport_init()
onto the target kernel's init/main.c start_kernel().
Enable this theoretical use case. Hackers welcome to
go play on this theoretical integration strategy now.
Cc: pstew@chromium.org
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m44.234s
user 813m54.992s
sys 126m44.115s
Commit b4f34d8d9 on next-20130419 added new bluetooth hidp
session-management helper, then commit 520518 also on
next-20130419 replaced the old management code with
the new one. Thanks to David Herrmann for his review and
his changes for this backport.
commit b4f34d8d9d26b2428fa7cf7c8f97690a297978e6
Author: David Herrmann <dh.herrmann@gmail.com>
Date: Sat Apr 6 20:28:46 2013 +0200
Bluetooth: hidp: add new session-management helpers
This is a rewrite of the HIDP session management. It implements HIDP as an
l2cap_user sub-module so we get proper notification when the underlying
connection goes away.
The helpers are not yet used but only added in this commit. The old
session management is still used and will be removed in a following patch.
The old session-management was flawed. Hotplugging is horribly broken and
we have no way of getting notified when the underlying connection goes
down. The whole idea of removing the HID/input sub-devices from within the
session itself is broken and suffers from major dead-locks. We never can
guarantee that the session can unregister itself as long as we use
synchronous shutdowns. This can only work with asynchronous shutdowns.
However, in this case we _must_ be able to unregister the session from the
outside as otherwise the l2cap_conn object might be unlinked before we
are.
The new session-management is based on l2cap_user. There is only one
way how to add a session and how to delete a session: "probe" and "remove"
callbacks from l2cap_user.
This guarantees that the session can be registered and unregistered at
_any_ time without any synchronous shutdown.
On the other hand, much work has been put into proper session-refcounting.
We can unregister/unlink the session only if we can guarantee that it will
stay alive. But for asynchronous shutdowns we never know when the last
user goes away so we must use proper ref-counting.
The old ->conn field has been renamed to ->hconn so we can reuse ->conn in
the new session management. No other existing HIDP code is modified.
Signed-off-by: David Herrmann <dh.herrmann@gmail.com>
Acked-by: Marcel Holtmann <marcel@holtmann.org>
Signed-off-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk>
commit 5205185d461d5902325e457ca80bd421127b7308
Date: Sat Apr 6 20:28:47 2013 +0200
Bluetooth: hidp: remove old session-management
We have the full new session-management now available so lets switch over
and remove all the old code. Few semantics changed, so we need to adjust
the sock.c callers a bit. But this mostly simplifies the logic.
As of next-20130419 the atl1.c driver uses
atl1_pm_ops directly instead of the ATL1_PM_OPS
macro. This fixes that hunk.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m38.595s
user 808m49.549s
sys 127m31.602s
Compilation is failing and we need to move forward,
I can't look at this right now.
This provides a requirement of the new qxl DRM driver to
be available only on kernels >= 3.3. The requirement
comes from the usage of radix_tree_for_each_slot() that
this uses the new radix bit-optimized iterator added
via 78c1d7848 on 3.4. We backport this via the compat
module but only for v3.3 given that addressing this
backport for v3.2 requires addressing e2bdb933 which
changes the radix_tree_node.
qxl was added on next-20130415.
mcgrof@frijol ~/linux-stable (git::master)$ git describe --contains 78c1d7848
v3.4-rc2~15^2~26
mcgrof@frijol ~/linux-stable (git::master)$ git describe --contains e2bdb933
v3.3-rc1~81^2~8
Someone wishing to #ifdef this to enable qxl support on
v3.2 by using the old radix_tree_gang_lookup_slot()
can look at 0fc9d1040313047edf6a39fd4d7c7defdca97c62
as an example collateral evolution change.
commit f64122c1f6ade301585569863b4b3b18f6e4e332
Author: Dave Airlie <airlied@gmail.com>
Date: Mon Feb 25 14:47:55 2013 +1000
drm: add new QXL driver. (v1.4)
QXL is a paravirtual graphics device used by the Spice virtual desktop
interface.
The drivers uses GEM and TTM to manage memory, the qxl hw fencing however
is quite different than normal TTM expects, we have to keep track of a number
of non-linear fence ids per bo that we need to have released by the hardware.
The releases are freed from a workqueue that wakes up and processes the
release ring.
releases are suballocated from a BO, there are 3 release categories, drawables,
surfaces and cursor cmds. The hw also has 3 rings for commands, cursor and release handling.
The hardware also have a surface id tracking mechnaism and the driver
encapsulates it completely inside the kernel, userspace never sees the actual hw sur
ids.
This requires a newer version of the QXL userspace driver, so shouldn't be
enabled until that has been placed into your distro of choice.
Authors: Dave Airlie, Alon Levy
v1.1: fixup some issues in the ioctl interface with padding
v1.2: add module device table
v1.3: fix nomodeset, fbcon leak, dumb bo create, release ring irq,
don't try flush release ring (broken hw), fix -modesetting.
v1.4: fbcon cpu usage reduction + suitable accel flags.
Signed-off-by: Alon Levy <alevy@redhat.com>
This is no longer required thanks to commit cc5569f6
present on next-20130415.
commit cc5569f63ecb82965f3fe2fde5e60bf1689d107a
Author: Johannes Berg <johannes.berg@intel.com>
Date: Thu Apr 11 16:22:08 2013 +0200
ath5k: use more idiomatic tracing include style
Pretty much everywhere that uses a trace definition
header that's not in include/trace/events/ uses the
make system for the include path rather than putting
it into the sources, so do that in ath5k as well.
This came up during backporting work (where this is
required), but since all other drivers do it this
way upstream it seemed applicable.
These are now upstream thanks to commit 8e8d4ff0 on
next-20130415.
commit 8e8d4ff051672d4a2939e7d6925c4acd234b0220
Date: Thu Apr 11 16:15:28 2013 +0200
brcm80211: simplify makefiles
This came up during my backporting work but it seems
perfectly appropriate for the kernel as well.
Acked-by: Arend van Spriel <arend@broadcom.com>
On next-20130415 commit 668761ac0 added platform
specific data for brcmfmac for SDIO. Copy that
over. This is the first in a series of changes
required for next-20130415.
commit 668761ac01d6f5a36b8e5a24d4e154550e2c4c3b
Author: Hante Meuleman <meuleman@broadcom.com>
Date: Fri Apr 12 10:55:55 2013 +0200
brcmfmac: define and use platform specific data for SDIO.
This patch adds support for platform specific data for SDIO
fullmac devices. Currently OOB interrupts are configured by Kconfig
BRCMFMAC_SDIO_OOB but that is now determined dynamically by checking
availibility of platform data.
Cc: Hauke Mehrtens <hauke@hauke-m.de>
Reviewed-by: Arend Van Spriel <arend@broadcom.com>
Reviewed-by: Piotr Haber <phaber@broadcom.com>
Signed-off-by: Hante Meuleman <meuleman@broadcom.com>
This backport's Konstantin's radix-tree bit optimized
iterator, 78c1d7848, added on v3.4. This is used by a new
drivers in the future. The new bit optimized iterator relies
on the stack optimization introduced via e2bdb933 added as of
v3.3. Backporting the bit optimized iterator requires
adjusting it to the old v3.2 radix_tree_node which is not
implemented here. For kernels v3.3 - v3.3 we can backport
the bit optimized iterator given that the radix_tree_node
did not changed between v3.3 - v3.4, in fact it hasn't
changed even up to v3.10. The backport relies on the same
helpers and inlines present on v3.3-v3.10 to implement
radix_tree_next_chunk().
This was tested as of next-20130410.
Throw the helper into compat config build option
CPTCFG_BACKPORT_BUILD_RADIX_HELPERS only to be built
on v3.3 right now unless someone really wants to
backport 78c1d7848 support onto v3.2.
v3.4-rc2~15^2~26
v3.3-rc1~81^2~8
ckmake below, and then the commit log references above.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m37.773s
user 809m37.644s
sys 126m30.806s
commit 78c1d78488a3c45685d993130c9f17102dc79a54
Author: Konstantin Khlebnikov <khlebnikov@openvz.org>
Date: Wed Mar 28 14:42:53 2012 -0700
radix-tree: introduce bit-optimized iterator
A series of radix tree cleanups, and usage of them in the core pagecache
code.
Micro-benchmark:
lookup 14 slots (typical page-vector size)
in radix-tree there earch <step> slot filled and tagged
before/after - nsec per full scan through tree
* Intel Sandy Bridge i7-2620M 4Mb L3
New code always faster
* AMD Athlon 6000+ 2x1Mb L2, without L3
New code generally faster,
Minor degradation (marked with "*") for huge sparse trees
* i386 on Sandy Bridge
New code faster for common cases: tagged and dense trees.
Some degradations for non-tagged lookup on sparse trees.
Ideally, there might help __ffs() analog for searching first non-zero
long element in array, gcc sometimes cannot optimize this loop corretly.
Numbers:
CPU: Intel Sandy Bridge i7-2620M 4Mb L3
radix-tree with 1024 slots:
tagged lookup
step 1 before 7156 after 3613
step 2 before 5399 after 2696
step 3 before 4779 after 1928
step 4 before 4456 after 1429
step 5 before 4292 after 1213
step 6 before 4183 after 1052
step 7 before 4157 after 951
step 8 before 4016 after 812
step 9 before 3952 after 851
step 10 before 3937 after 732
step 11 before 4023 after 709
step 12 before 3872 after 657
step 13 before 3892 after 633
step 14 before 3720 after 591
step 15 before 3879 after 578
step 16 before 3561 after 513
normal lookup
step 1 before 4266 after 3301
step 2 before 2695 after 2129
step 3 before 2083 after 1712
step 4 before 1801 after 1534
step 5 before 1628 after 1313
step 6 before 1551 after 1263
step 7 before 1475 after 1185
step 8 before 1432 after 1167
step 9 before 1373 after 1092
step 10 before 1339 after 1134
step 11 before 1292 after 1056
step 12 before 1319 after 1030
step 13 before 1276 after 1004
step 14 before 1256 after 987
step 15 before 1228 after 992
step 16 before 1247 after 999
radix-tree with 1024*1024*128 slots:
tagged lookup
commit e2bdb933ab8b7db71c318a4ddcf78a9fffd61ecb
Author: Hugh Dickins <hughd@google.com>
Date: Thu Jan 12 17:20:41 2012 -0800
radix_tree: take radix_tree_path off stack
Down, down in the deepest depths of GFP_NOIO page reclaim, we have
shrink_page_list() calling __remove_mapping() calling __delete_from_
swap_cache() or __delete_from_page_cache().
You would not expect those to need much stack, but in fact they call
radix_tree_delete(): which declares a 192-byte radix_tree_path array on
its stack (to record the node,offsets it visits when descending, in case
it needs to ascend to update them). And if any tag is still set [1],
that calls radix_tree_tag_clear(), which declares a further such
192-byte radix_tree_path array on the stack. (At least we have
interrupts disabled here, so won't then be pushing registers too.)
That was probably a good choice when most users were 32-bit (array of
half the size), and adding fields to radix_tree_node would have bloated
it unnecessarily. But nowadays many are 64-bit, and each
radix_tree_node contains a struct rcu_head, which is only used when
freeing; whereas the radix_tree_path info is only used for updating the
tree (deleting, clearing tags or setting tags if tagged) when a lock
must be held, of no interest when accessing the tree locklessly.
So add a parent pointer to the radix_tree_node, in union with the
rcu_head, and remove all uses of the radix_tree_path. There would be
space in that union to save the offset when descending as before (we can
argue that a lock must already be held to exclude other users), but
recalculating it when ascending is both easy (a constant shift and a
constant mask) and uncommon, so it seems better just to do that.
Two little optimizations: no need to decrement height when descending,
adjusting shift is enough; and once radix_tree_tag_if_tagged() has set
tag on a node and its ancestors, it need not ascend from that node
again.
perf on the radix tree test harness reports radix_tree_insert() as 2%
slower (now having to set parent), but radix_tree_delete() 24% faster.
Surely that's an exaggeration from rtth's artificially low map shift 3,
but forcing it back to 6 still rates radix_tree_delete() 8% faster.
Commit 5a753a4 on next-20130410 extended the
dma-buf implementation to add debugfs support.
We backport support for this by adding its own
subsys_init() call as a helper to the backport
module (still called compat) respective subsys_init()
call, backport_init(). For kernels where this is
already supported this is a no-op.
This didn't make it to v3.9 but I see Linus has
already merged this as part of the merge window
what will be v3.10.
This also refreshes patches for next-20130410 and
I supply the refresh as part of this same patch
given that the only patch refreshed was the one
modifyin the drivers/base/dma-buf.c.
commit 5a753a49fb7e17fa83ea9cf39c7b1a902363d828
Author: Sumit Semwal <sumit.semwal@linaro.org>
Date: Thu Apr 4 11:44:37 2013 +0530
dma-buf: Add debugfs support
Add debugfs support to make it easier to print debug information
about the dma-buf buffers.
Cc: Dave Airlie <airlied@redhat.com>
[minor fixes on init and warning fix]
Signed-off-by: Sumit Semwal <sumit.semwal@linaro.org>
$ ckmake --allyesconfig
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m10.328s
user 797m1.841s
sys 125m15.978s
Without this change we were removing patch headers
when refreshing patches.
Cc: techtonik@gmail.com
Add a top_header for cases where a patchset might have a
full header that we may want users to keep around.
This updates the backports project up to synch with the
latest patch.py from svn trunk.
[remove HG/GIT patch path detection as we used to]
If the git library is available (on many distros, just
install python-git or similar) then use it to read the
git blobs from disk if --git-revision is used.
On my system (with an SSD) this speeds up the entire
backport generation process significantly (when using
--git-revision):
before:
real 0m39.280s
user 0m13.464s
sys 0m16.644s
after:
real 0m22.554s
user 0m16.404s
sys 0m5.724s
There's a python git library, and our name conflicts
with it since it's also just called "git". I want to
use the python library (optionally) to speed up the
git accesses so this is now relevant.
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m38.751s
user 810m14.462s
sys 126m48.932s
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m33.717s
user 809m9.794s
sys 125m18.510s
Some day we will use SmPL for this...
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ FAIL ]
16 2.6.39 [ OK ]
17 3.0.76 [ OK ]
18 3.1.10 [ OK ]
19 3.2.44 [ OK ]
20 3.3.8 [ OK ]
21 3.4.43 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.10 [ OK ]
25 3.8.11 [ OK ]
26 3.9.0 [ OK ]
real 30m33.959s
user 809m11.262s
sys 126m15.477s
[Luis says the "FAIL" was due to a test setup issue only]
Update to the latest available set. You'll need 3.9 updated
if you want to test against next-20130403 due to fffe01f7.
At times you may only want to test with ckmake a specific
kernel range or target kernels. You can do that now. ckmake
will use this list against what it finds on your system.
Examples:
* ckmake --revs 3.3..3.4
* ckmake --revs 2.6.24,2.6.30,2.6.32..3.2,3.4
The base kernels revisions is what is expected. The base kernel
revision of say 3.4.5 is 3.4, the base revision of say 2.6.24.2
is 2.6.24.
Vanilla Linux kernels are being used but the directory
file naming for for the kernels are Ubuntu specific,
clarify that.
Remove --check-exports as an option and now just enable it by default.
[fix typo]
We enabled regulator subsystem support as of 3.4 but given that
the regulator subsystem has advanced quite a bit on 3.5 and 3.6
and that we cannot backport the regulator as its part of the
core kernel we have no option but to only enable drivers on their
kernels if they don't depend on the new regulator features.
$ time ckmake --check-exports --allyesconfig
1 2.6.24 [ OK ]
2 2.6.25 [ OK ]
3 2.6.26 [ OK ]
4 2.6.27 [ OK ]
5 2.6.28 [ OK ]
6 2.6.29 [ OK ]
7 2.6.30 [ OK ]
8 2.6.31 [ OK ]
9 2.6.32 [ OK ]
10 2.6.33 [ OK ]
11 2.6.34 [ OK ]
12 2.6.35 [ OK ]
13 2.6.36 [ OK ]
14 2.6.37 [ OK ]
15 2.6.38 [ OK ]
16 2.6.39 [ OK ]
17 3.0.65 [ OK ]
18 3.1.10 [ OK ]
19 3.2.38 [ OK ]
20 3.3.8 [ OK ]
21 3.4.32 [ OK ]
22 3.5.7 [ OK ]
23 3.6.11 [ OK ]
24 3.7.9 [ OK ]
25 3.8.0 [ OK ]
26 3.9-rc1 [ OK ]
real 30m12.875s
user 797m38.663s
sys 126m56.572s
