2015-02-22patches: refresh patches on next-20150129backports-20150129Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.67 [ OK ] 4 3.3.8 [ OK ] 5 3.4.106 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.69 [ OK ] 12 3.11.10 [ OK ] 13 3.12.38 [ OK ] 14 3.13.11 [ OK ] 15 3.14.33 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.7 [ OK ] 20 3.19.0 [ OK ] manual changes do to: patches/collateral-evolutions/network/0049-no-pfmemalloc/igb.patch Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-02-22devel: update the test kernelsHauke Mehrtens
2015-02-22header: add of_get_property() for 3.0Hauke Mehrtens
In kernel 3.0 the function prototype is only present when CONFIG_OF is selected, if that is not selected the prototype is not there. This adds an empty implementation for that case. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-02-22patches: igb: remove access to programmable ptp pinsHauke Mehrtens
Programmable pins were introduced in the ptp subsystem in kernel 3.15 and igb makes use of them now. These patches are removing the code accessing these new functions. These patches are needed for every kernel which does not have this commit: commit 6092315dfdec5185881605d15a0e200d6e90eb66 Author: Richard Cochran <richardcochran@gmail.com> Date: Thu Mar 20 22:21:52 2014 +0100 ptp: introduce programmable pins. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> CC: Stefan Assmann <sassmann@kpanic.de>
2015-02-22header: add skb_vlan_tag_{present,get,get_id}Hauke Mehrtens
These macros are used by some Ethernet drivers now. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-02-22header: add get_user_pages_unlocked()Hauke Mehrtens
This function is needed by some media driver. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-02-22backports: add IFF_TX_SKB_SHARINGJohannes Berg
This was introduced on kernel version 3.1, so a kernel (3.0) without it is still just within the support window. Define this constant if it isn't defined. Signed-off-by: Johannes Berg <johannes.berg@intel.com> [Move the code to backport/backport-include/linux/netdevice.h, it is placed there in recent kernel version] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-02-22backports: remove patches for SKBTX_WIFI_STATUSJohannes Berg
The tx_flags haven't been a union since 2.6.37, so since we no longer support that kernel the '&' operation will now be possible on all supported kernels. Use that fact to get rid of the patch by defining SKBTX_WIFI_STATUS to 0 so the code also disappears, but doesn't have to be patched. While at it, clean up a double #if. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-02-22patches: genl-const: fix nl80211.patchArend van Spriel
nl80211.c recently changed using defined strings instead of hard-coded in multi-cast group definitions: commit 71b836eca7f380fbd4c025f8c4371f9a071bc909 Author: Johannes Berg <johannes.berg@intel.com> Date: Tue Dec 23 17:17:38 2014 +0100 nl80211: define multicast group names in header Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-02-22backport: small copy&paste error fixedArend van Spriel
Changed the version number in the file header comment. Signed-off-by: Arend van Spriel <arend@broadcom.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-02-22backport: add hwmon group registration functionsMathieu Olivari
hwmon group registration functions have been added in 3.13 kernel. Latest ath10k patches make use of this mechanism, therefore the need for the backport. Signed-off-by: Mathieu Olivari <mathieu@qca.qualcomm.com> [do not dereference hwdev before giving to dev_set_drvdata] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-01-30patches: refresh on next-20150108backports-20150108Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.65 [ OK ] 4 3.3.8 [ OK ] 5 3.4.105 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.63 [ OK ] 12 3.11.10 [ OK ] 13 3.12.35 [ OK ] 14 3.13.11 [ OK ] 15 3.14.27 [ OK ] 16 3.15.10 [ OK ] 17 3.16.6 [ OK ] 18 3.17.7 [ OK ] 19 3.18.1 [ OK ] 20 3.19-rc1 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-01-30copy: add include/linux/hdmi.hHauke Mehrtens
This header is needed by some media drivers. It is safe to copy this file, because it does not contains any header for an interface to other kernel subsystems or drivers, but only consonants defined in the HDMI standard. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-01-24header: add linux/timecounter.hHauke Mehrtens
This file was newly added to the kernel. It was extracted from linux/clocksource.h. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-01-23backports: explicitely include string.h from device.hMathieu Olivari
string.h is usually included from the asm/ folder in most configuration, but on some older kernels and non-x86 architecture, this inclusion is not necessarily happening. As we're using memcpy() in the code below, we need to be safe and make sure string.h is indeed there. This issue has been observed on a 3.4 vendor kernels, but may be applicable to other configurations. Signed-off-by: Mathieu Olivari <mathieu@qca.qualcomm.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-12-21patches: refresh patches on next-20141221backports-20141221Hauke Mehrtens
2014-12-21patches: remove ath9k-Revert-ath-ath9k-use-debugfs patchHauke Mehrtens
This patches was merged upstream Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-12-21atches: fix ssb compileHauke Mehrtens
The wakeup_path member was added in kernel 3.2, just ignore this on older kernel versions. This will break WoL in b44 with these old kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-12-21patches: revert iov_iter for bluetoothHauke Mehrtens
usage of the new iov_iter api was added in the following patches: commit 17836394e578b8d6475ecdb309ad1356bbcf37a2 Author: Al Viro <viro@zeniv.linux.org.uk> Date: Mon Nov 24 17:07:38 2014 -0500 first fruits - kill l2cap ->memcpy_fromiovec() commit c0371da6047abd261bc483c744dbc7d81a116172 Author: Al Viro <viro@zeniv.linux.org.uk> Date: Mon Nov 24 10:42:55 2014 -0500 put iov_iter into msghdr commit 56c39fb67cdb665ae67fba4975f5e20e6614cda6 Author: Al Viro <viro@zeniv.linux.org.uk> Date: Mon Nov 24 16:44:09 2014 -0500 switch l2cap ->memcpy_fromiovec() to msghdr I haven't found a way to backport this, so this is mostly a revert of these upstream commits to make bluetooth use the old APIs on older kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-12-21header: add dma_rmb()Hauke Mehrtens
dma_rmb() is added twice, because most architectures do not include asm-generic/barrier.h, but only asm/barrier.h. This should work with all architectures. dma_rmb() is used by the igb driver. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-12-21header: add eth_skb_pad()Hauke Mehrtens
eth_skb_pad() is used by the igb driver. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-12-21header: add skb_put_padto()Hauke Mehrtens
skb_put_padto() is used by the igb driver. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-12-21header: add napi_alloc_skb()Hauke Mehrtens
napi_alloc_skb() is now used by some Ethernet drivers instead of netdev_alloc_skb_ip_align(). It can not be placed into backport- include/linux/skbuff.h because it accesses a member of struct napi_struct which is not possible in skbuff.h, placing it into netdevice.h worked in my tests. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-12-21devel: update the test kernelsbackports-20141201Hauke Mehrtens
2014-12-21patches: refresh on next-20141201Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.65 [ OK ] 4 3.3.8 [ OK ] 5 3.4.105 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.63 [ OK ] 12 3.11.10 [ OK ] 13 3.12.35 [ OK ] 14 3.13.11 [ OK ] 15 3.14.27 [ OK ] 16 3.15.10 [ OK ] 17 3.16.6 [ OK ] 18 3.17.7 [ OK ] 19 3.18.1 [ OK ] manual changed were needed for the following patches: backport-adjustments/crypto-ccm.patch backport-adjustments/devcoredump.patch Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-12-21patches: cherry-pick debugfs_create_devm_seqfile() revertHauke Mehrtens
2014-12-21patches: adapt api change of rchan_callbacks->create_buf_file in ath9kHauke Mehrtens
2014-12-21patches: do not use DMA_ATTR_SKIP_CPU_SYNCHauke Mehrtens
DMA_ATTR_SKIP_CPU_SYNC was added to the enum with kernel 3.6. This patch removes all calls to dma_set_attr() with this value on kernel < 3.6. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-12-21patches: fix some v4l2 dma stuffHauke Mehrtens
* The vb2_vmalloc_get_dmabuf() function does not work on kernel < 3.5. * v4l2_m2m_ioctl_expbuf() is disabled on kernel < 3.5, do not call it. * deactivate dmabuf support in videobuf2-dma-sg.c Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-12-21patches: disable tx status support in mwifiexHauke Mehrtens
This feature is not support with older kernels, just deactivate it. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-12-21backport: do not call coredump when it was not buildHauke Mehrtens
When coredump was included in the kernel backports is build against then it could be that the prototype are used, which caused a undefined references linking problem. This patch fixes the problem by only using this when the driver is actually compiled in. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-12-20backport: add of_property_read_u32()Hauke Mehrtens
2014-12-20backport: add pci_device_is_present()Hauke Mehrtens
This is needed by igb driver. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-12-20backport: add debugfs_create_devm_seqfile()Hauke Mehrtens
This new functions is used by ath9k. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-12-20header: backport drain_workqueue() by calling flush_workqueue()Hauke Mehrtens
This backport is only needed for kernel < 3.1. Backporting drain_workqueue() is too hard so we just flush the workqueue which should work in most cases. This could still cause problems in some situation. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-12-20header: include some other dma headers in dma-buf.hHauke Mehrtens
when we do not include the original version of dma-buf.h, some other header files should be included because some media drivers are expecting this now. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-12-20header: add empty of_find_compatible_node()Hauke Mehrtens
of_find_compatible_node() is not defined when CONFIG_OF is not set on kernel < 3.3. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-12-20header: add memcpy_from_msg()Hauke Mehrtens
This was added in kernel 3.19. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-12-20header: add for_each_compatible_node()Hauke Mehrtens
for_each_compatible_node() is defined in a CONFIG_OF condition on older kernel versions. Now some drivers are use it when CONFIG_OF is not set, add it always when it is not already there. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-11-20backports: refresh patches for next-20141117backports-20141117Luis R. Rodriguez
This required no manual changes. mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py \ /home/mcgrof/linux-next /home/mcgrof/build/backports-20141117 Copy original source files ... Applying patches from patches to /home/mcgrof/build/backports-20141117 ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m28.499s user 13m25.112s sys 0m47.804s mcgrof@drvbp1 ~/build/backports-20141117 $ time \ /home/mcgrof/backports/devel/ckmake --allyesconfig 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.62 [ OK ] 4 3.3.8 [ OK ] 5 3.4.104 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.58 [ OK ] 12 3.11.10 [ OK ] 13 3.12.31 [ OK ] 14 3.13.11 [ OK ] 15 3.14.22 [ OK ] 16 3.15.10 [ OK ] 17 3.16.6 [ OK ] 18 3.17.1 [ OK ] 19 3.18-rc1 [ OK ] real 42m18.874s user 1179m40.500s sys 138m54.452s Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-20backports: backport netdev_rss_key_fill()Luis R. Rodriguez
netdev_rss_key_fill() uses net_get_random_once() and since this depends on static keys and we've decided to only backport that only down to 3.5 as that is when static key stuff settled we only backport netdev_rss_key_fill() down to 3.5 as well. For details on the net_get_random_once() / static key stuff refer to backports commit 8cb8816d. Backporting netdev_rss_key_fill requires us to throw in the netdev_rss_key within our own backports module. We don't backport the ability to query this *yet though*, but if we really wanted to we can provide an interface for that: For *packaging* [0] we have no other option but to currently provide our own querying interface, that's silly though, in the future if we extend sysctl interfaces to allow dynamic extensions we could just peg what we need also within the backports module to allow seemless integration. With shiny new *kernel integration* support [1] though we can enable cherry picking the sysctl components, and apply it to the older kernel -- however this would pose a change in compartamentalized backporting strategy as currently used. It would seem a allowing dynamic extensions to an existing sysctl interface would be more efficient and would allow packaging to also take advantage of this effort. [0] https://backports.wiki.kernel.org/index.php/Documentation/packaging [1] https://backports.wiki.kernel.org/index.php/Documentation/integration commit 960fb622f85180f36d3aff82af53e2be3db2f888 Author: Eric Dumazet <edumazet@google.com> Date: Sun Nov 16 06:23:05 2014 -0800 net: provide a per host RSS key generic infrastructure RSS (Receive Side Scaling) typically uses Toeplitz hash and a 40 or 52 bytes RSS key. Some drivers use a constant (and well known key), some drivers use a random key per port, making bonding setups hard to tune. Well known keys increase attack surface, considering that number of queues is usually a power of two. This patch provides infrastructure to help drivers doing the right thing. netdev_rss_key_fill() should be used by drivers to initialize their RSS key, even if they provide ethtool -X support to let user redefine the key later. A new /proc/sys/net/core/netdev_rss_key file can be used to get the host RSS key even for drivers not providing ethtool -x support, in case some applications want to precisely setup flows to match some RX queues. Tested: myhost:~# cat /proc/sys/net/core/netdev_rss_key 11:63:99:bb:79:fb:a5:a7:07:45:b2:20:bf:02:42:2d:08:1a:dd:19:2b:6b:23:ac:56:28:9d:70:c3:ac:e8:16:4b:b7:c1:10:53:a4:78:41:36:40:74:b6:15:ca:27:44:aa:b3:4d:72 myhost:~# ethtool -x eth0 RX flow hash indirection table for eth0 with 8 RX ring(s): 0: 0 1 2 3 4 5 6 7 RSS hash key: 11:63:99:bb:79:fb:a5:a7:07:45:b2:20:bf:02:42:2d:08:1a:dd:19:2b:6b:23:ac:56:28:9d:70:c3:ac:e8:16:4b:b7:c1:10:53:a4:78:41 Signed-off-by: Eric Dumazet <edumazet@google.com> Signed-off-by: David S. Miller <davem@davemloft.net> mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py \ /home/mcgrof/linux-next /home/mcgrof/build/backports-20141117 Copy original source files ... Applying patches from patches to /home/mcgrof/build/backports-20141117 ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m28.499s user 13m25.112s sys 0m47.804s mcgrof@drvbp1 ~/build/backports-20141117 $ time \ /home/mcgrof/backports/devel/ckmake --allyesconfig 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.62 [ OK ] 4 3.3.8 [ OK ] 5 3.4.104 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.58 [ OK ] 12 3.11.10 [ OK ] 13 3.12.31 [ OK ] 14 3.13.11 [ OK ] 15 3.14.22 [ OK ] 16 3.15.10 [ OK ] 17 3.16.6 [ OK ] 18 3.17.1 [ OK ] 19 3.18-rc1 [ OK ] real 42m18.874s user 1179m40.500s sys 138m54.452s Cc: Eric Dumazet <edumazet@google.com> Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-20backports: bump I2C_SI4713 to v3.13Luis R. Rodriguez
This driver depends on gpio consumer.h, that depends on some built-in kernel functionality and while we can now backport built-in stuff we'd need to make that depend on BACKPORT_INTEGRATE and then figure out how to backport that functionality on integration. This doesn't seem like a good candidate to test that with though. Let's wait for something more desirable. Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-20backports: address splitting of v4l2-mediabus.h to two filesLuis R. Rodriguez
The new file media-bus-format.h was derived from contents from v4l2-mediabus.h, this change might be a bit harder to infer exactly what to do but based on some contextual examination of the file, if content integrity has not changed it should be relatively easy to infer what to do with changes like this. commit edcf58bc031e621f519c9dfce3c7e1ea6880c70a Author: Boris BREZILLON <boris.brezillon@free-electrons.com> Date: Mon Nov 10 14:28:26 2014 -0300 [media] Move mediabus format definition to a more standard place Define MEDIA_BUS_FMT macros (re-using the values defined in the v4l2_mbus_pixelcode enum) into a separate header file so that they can be used from the DRM/KMS subsystem without any reference to the V4L2 subsystem. Then set V4L2_MBUS_FMT definitions to the MEDIA_BUS_FMT values using the V4L2_MBUS_FROM_MEDIA_BUS_FMT macro. Signed-off-by: Boris Brezillon <boris.brezillon@free-electrons.com> Acked-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Acked-by: Hans Verkuil <hans.verkuil@cisco.com> Acked-by: Sakari Ailus <sakari.ailus@linux.intel.com> Signed-off-by: Hans Verkuil <hans.verkuil@cisco.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@osg.samsung.com> include/uapi/linux/Kbuild | 1 + include/uapi/linux/media-bus-format.h | 125 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ include/uapi/linux/v4l2-mediabus.h | 184 +++++++++++++++++++++++++++++++++++++++++++++++++++++++++------------------------------------------------------------------------- 3 files changed, 206 insertions(+), 104 deletions(-) Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-20backports: remove wpan-phy.h after rename to cfg802154.hLuis R. Rodriguez
Address the renaming. cfg802154.h was already added but we forgot to remove wpan-phy.h. This is an example type of upstream that we should easily be able to automatically backport through inference. Logic: for f in copy_list: if f in git_delta_renamed: adjust_copy_list(f) We'd first have to build a series of types of changes from the delta between the last linux-next tag we tracked and the currenty evaluated one, the git_delta_renamed would contain a list of renames that happened between the two tags. commit 5ad60d36993596f7b3b958500f9c66c5338cd855 Author: Alexander Aring <alex.aring@gmail.com> Date: Sat Oct 25 09:41:02 2014 +0200 ieee802154: move wpan-phy.h to cfg802154.h The wpan-phy header contains the wpan_phy struct information. Later this header will be have similar function like cfg80211 header. The cfg80211 header contains the wiphy struct which is identically the wpan_phy struct inside 802.15.4 subsystem. Signed-off-by: Alexander Aring <alex.aring@gmail.com> Cc: Alan Ott <alan@signal11.us> Signed-off-by: Marcel Holtmann <marcel@holtmann.org> Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-11-18backports: fix breakage from integration patchsetJohannes Berg
Various small things broken in the integration patchset, fix them to actually make backports useful again. For example, a driver using devcoredump wouldn't have worked without these changes as it would depend on devcoredump, and that wasn't backported due to the bugs, despite being in the backport Kconfig file. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-11-16backports: do not use in kernel version of rt6_nexthop()backports-20141114Hauke Mehrtens
Kernel 3.9 ships with a version of rt6_nexthop() with two parameters. We want to replace this version with our current version which only takes one parameter. include/net/ip6_route.h includes include/net /ip6_fib.h so we can not place our code behind the code in include/net /ip6_route.h. If we include ip6_fib.h before ip6_route.h we can place our code at the position we need it. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-11-16headers: fix problem when unloading mac80211 on Ubuntu 14.04Hauke Mehrtens
When unloading mac80211 on the default kernel which is currently shipped in Ubuntu 14.04 this commit causes a kernel error message. Now we check if the list was deleted before and only do so if it was not done before. Ubuntu probably backported this patch in their kernel. commit 97666f936e0656a1b28c40cc33981a8db65e1a11 Author: Hauke Mehrtens <hauke@hauke-m.de> Date: Sun Nov 16 14:23:24 2014 +0100 headers: delete the list in unregister_netdevice_many() Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-11-16headers: remove pci_regs.hHauke Mehrtens
This file is now copied from the kernel and we do not have to ship an own version. Coping this from the kernel is safe because it only contains constants. commit bda1096b3dfe00f19b30fc85f282b2a9ad2f67f0 Author: Felix Fietkau <nbd@openwrt.org> Date: Sun Nov 16 14:39:58 2014 +0100 backports: add include/uapi/linux/pci_regs.h to copy-list Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2014-11-16backports: refresh patches on next-20141114Hauke Mehrtens
2014-11-16patches: disable qdisc_tx_busylock in bluetoothHauke Mehrtens
The qdisc_tx_busylock member in struct net_device is not available in kernel < 3.7. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
