Kernel 3.9 ships with a version of rt6_nexthop() with two parameters.
We want to replace this version with our current version which only
takes one parameter. include/net/ip6_route.h includes include/net
/ip6_fib.h so we can not place our code behind the code in include/net
/ip6_route.h. If we include ip6_fib.h before ip6_route.h we can place
our code at the position we need it.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
When unloading mac80211 on the default kernel which is currently
shipped in Ubuntu 14.04 this commit causes a kernel error message. Now
we check if the list was deleted before and only do so if it was not
done before. Ubuntu probably backported this patch in their kernel.
commit 97666f936e0656a1b28c40cc33981a8db65e1a11
Author: Hauke Mehrtens <hauke@hauke-m.de>
Date: Sun Nov 16 14:23:24 2014 +0100
headers: delete the list in unregister_netdevice_many()
This file is now copied from the kernel and we do not have to ship an
own version. Coping this from the kernel is safe because it only
contains constants.
commit bda1096b3dfe00f19b30fc85f282b2a9ad2f67f0
Author: Felix Fietkau <nbd@openwrt.org>
Date: Sun Nov 16 14:39:58 2014 +0100
backports: add include/uapi/linux/pci_regs.h to copy-list
The qdisc_tx_busylock member in struct net_device is not available in
kernel < 3.7.
The member pfmemalloc was added to struct page in kernel 3.6, it should
be same to just ignore it in most situation, so do so on older kernel
versions.
This is needed by bluetooth and ieee802154.
This is needed by mac80211_hwsim.
The code was copied from kernel 3.4.
This is needed by bluetooth.
It looks hard to backport IEEE802154 to older kernels, because it now
uses the new member ieee802154_ptr in struct net_device. This code was
added in upstream commit 98a18b6ffc7 "netdevice: add ieee802154_ptr to
net_device"
If someone knows how to backport this stuff please do so and revert
this patch.
MEDIA_TUNER_M88RS6000T now uses devm_regmap_init_i2c()
One of the tuners DVB_SMIPCIE selects uses regmap_bulk_write()
These files were moved in the mainline kernel, we have to adapt that.
this is needed by bluetooth.
unregister_netdevice_many() now deletes the list after running, in the
earlier days mac80211 and so on, did this on their own. We extended the
old unregister_netdevice_many() function for all kernel versions that
do not have a fixed unregister_netdevice_many().
This is used by the saa7134-alsa.c driver.
This is used in some places.
This is used by the igb driver.
This removes some used stuff from linux/skbuff.h.
The backported (<3.9) version of hlist_for_each_entry_rcu and
hlist_for_each_entry_safe uses the new macro hlist_entry_safe. It is called
with an ACCESS_ONCE parameter for the first parameter ptr. This disallows
merging of the two loads which the current version of the macro uses.
This is problematic because this macro must only generate one load. Otherwise
with two contexts (or CPUs) following could happen:
1. context 1 fetches the ptr to the last entry in hlist_entry_safe() and
accepts this non-NULL ptr
2. context 2 deletes the last entry and terminates the list with NULL
3. context 1 re-fetches the pointer, doesn't check for zero, calculates the
entry based on a NULL pointer
4. context 1 crashes because it tries to load/write data from/to the invalid
address
Instead use a single load to a temporary variable and do the NULL-check and
calculation based on that one. This is also the approach used in the current
Linux versions and was introduced by Paul E. McKenney.
Signed-off-by: Sven Eckelmann <sven@narfation.org>
Signed-off-by: Felix Fietkau <nbd@openwrt.org>
Fixes a recent iwlwifi build error
I intend to use this for a new driver
This fix was originally provided by Johannes. This replaces
the linker adhoc fix to match more with what we do upstream
without requiring the use of HOSTLOADLIBES.
Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
This enables support for using the backports project
to integrate device drivers from a future version of Linux
into an older version of Linux. What you end up seeing is
a backports submenu when configuring your kernel and the
ability to select specific device drivers from subsystems
supported through the Linux backports project.
At this time enabling one device driver from a future version
of Linux will require using only the latest version of the
subsystem modules and other subsystem drivers. For example
enabling cfg80211 and mac80211 from a future version of Linux
will require you to only use future version of the respective
device drivers. In order to enable the backported version of
802.11 drivers for example, you will have to enable first:
Networking support -->
Wireless -->
But under that menu disable all options, then jump to the backports
submenu to now enable:
Backports -->
cfg80211
mac80211
Wireless LAN --->
etc
You build these device drivers modular or built-in to the kernel.
Integration support requires only slight modifications to the original
kernel sources, one to the top level Kconfig to add our entry, and also
the top level Makefile to enable backports code to be part of the
built-in vmlinux.
Support for integration takes advantage over the existing infrastructure
added by Johannes to keep track of each indvidual change done by the
backports infrastructure if --gitdebug is used.
mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean \
/home/mcgrof/linux-next /home/mcgrof/build/backports-20141023
Copy original source files ...
Applying patches from patches to /home/mcgrof/build/backports-20141023
Modify Kconfig tree ...
Rewrite Makefiles and Kconfig files ...
Done!
real 1m27.942s
user 13m23.752s
sys 0m47.608s
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.62 [ OK ]
4 3.3.8 [ OK ]
5 3.4.104 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.58 [ OK ]
12 3.11.10 [ OK ]
13 3.12.31 [ OK ]
14 3.13.11 [ OK ]
15 3.14.22 [ OK ]
16 3.15.10 [ OK ]
17 3.16.6 [ OK ]
18 3.17.1 [ OK ]
19 3.18-rc1 [ OK ]
real 42m44.838s
user 1190m5.092s
sys 140m37.208s
The CPTCFG_ prefix already implies backport, when integration
is used we'd end up with a double BACKPORT_ prefix, so just
remove the existing one as its not needed.
Things we backport are now prefixed with BACKPORT_, when we copy
over libraries with the c-files / h-files trick on the compat/Kconfig
trick we prefix these with BACKPORT_ already so in order to help
distinguish them use BACKPORT_BPAUTO_ for them and prevent a double
BACKPORT_ prefix.
The way we'll define backports versioning information for
kernel integration is slightly different, we'll rely completely
on Kconfig for the job, but in the end share the same C code
defines.
In order to help unify the naming scheme for shared
backports versioning information rely on the CPTCFG_
prefix, when integration support gets added that will
translate to the respective CONFIG_BACKPORT_ prefix.
Kconfig opt env entries don't get propagated out, so
we need to define these ourselves. This leaves all
other names in place for packaging and just focuses
on sharing on the C / header code.
The version file contains:
* BACKPORTS_VERSION
* BACKPORTED_KERNEL_VERSION
* BACKPORTED_KERNEL_NAME
This file is used by the Makefile to export variable
definitions used to identify the backport. For kernel
integration we'll be using a generated Kconfig file
instead and since these are needed when processing
kconfig logic this will need to be defined earlier.
Just move the generation of the version file for packaging
up early to match where we will generate the Kconfig with
the backports versioning identification.
This change has no real functional change other than the
move of some code running earlier.
This splits up the Kconfig from things which are needed due to
our copy of code from the kernel and things which we need
specifically only for packaging backports. We will later then
share the Kconfig.souce for instance for kernel integration.
While at it, split up the list of files that we need to copy
into what we know could be shared for integration. The the
case of backport packaging Kconfig.package will be copied to
the package's Kconfig when building the package with gentree.py.
During development of kernel integration support using CONFIG_BACKPORT
was evaluated as a prefix over CPTCFG even for packaging backports,
for some reason this change lifted some restrictions one some device
drivers which was present before and as such requires some changes to
the dependencies map file to ensure correct compilation for respective
kernel versions.
This will allow us to do less work for built-in integration support.
When packaging we only use BACKPORT_DIR for Kconfig sources we control,
to avoid a large change we avoid doing this for other Kconfig files.
For integration we'll always have to use BACKPORT_DIR on kconfig sources.
Suporting requires a bit of self evaluation of the variable within our
kconfig library, ideally we'd have support for groking all variables
defined within the Kconfig setup but that requires quite a lot more
work as it means also parsing Makefiles and inheriting these definitions
within config symbols when used. Since we only define one right now and
its used for built-in support we deal with it ourselves for now.
Please consider the complexity of adding others, it doesn't seem like
there would be much need for others though. If others wanted to use a
different BACKPORT_DIR path other than 'backports' that would require
tweaking here, but we'll start by assuming no one will want to do that.
$ time /home/mcgrof/backports/devel/ckmake --allyesconfig
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.62 [ OK ]
4 3.3.8 [ OK ]
5 3.4.104 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.58 [ OK ]
12 3.11.10 [ OK ]
13 3.12.31 [ OK ]
14 3.13.11 [ OK ]
15 3.14.22 [ OK ]
16 3.15.10 [ OK ]
17 3.16.6 [ OK ]
18 3.17.1 [ OK ]
19 3.18-rc1 [ OK ]
real 42m41.825s
user 1187m38.880s
sys 141m11.760s
The kconfig source line used on a backport project is very
project specific. For backport packaging the source line simply
should follow the full path of the project but for integration
this will vary depending on the backport prefix directory used.
We'll add support for that next.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.62 [ OK ]
4 3.3.8 [ OK ]
5 3.4.104 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.58 [ OK ]
12 3.11.10 [ OK ]
13 3.12.31 [ OK ]
14 3.13.11 [ OK ]
15 3.14.22 [ OK ]
16 3.15.10 [ OK ]
17 3.16.6 [ OK ]
18 3.17.1 [ OK ]
19 3.18-rc1 [ OK ]
real 43m56.439s
user 1187m4.516s
sys 138m53.328s
The kconfig parser sets a base directory using the directory
in which the Kconfig file passed lives in. This strategy assumes the
kernel uses relative paths, while this is truly supported in
practice though upstream only deals with full paths based on
the actual root directory of the kernel. Its safer, cleaner and
much simpler to support full paths, and since the kernel uses
full paths anyway lets stick to that and complain when relative
paths are found. This also modifies our own provided Kconfig to
use full paths as well, we'll need this later to adjust our
Kconfigs for kernel integration.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.62 [ OK ]
4 3.3.8 [ OK ]
5 3.4.104 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.58 [ OK ]
12 3.11.10 [ OK ]
13 3.12.31 [ OK ]
14 3.13.11 [ OK ]
15 3.14.22 [ OK ]
16 3.15.10 [ OK ]
17 3.16.6 [ OK ]
18 3.17.1 [ OK ]
19 3.18-rc1 [ OK ]
real 44m3.002s
user 1188m20.708s
sys 140m25.540s
When using backports against for packaging with --gitdebug you either
have to use --clean or assume the directory is empty already. In either
case you start fresh. With integration this will be a bit different, you
could end up with a project directory where the git tree was present but
only the target directory was empty.
Calling git init on an already existing git directory will reinitialize
your git tree, that can reset some config stuff, let's avoid that.
The output directory is always the same as the project directory
for packaging backports but for integration these will differ,
to make introduction of integration easier to follow use the
outdir as both project directory and target directory and fold
the existing args.outdir under the backport identity object as
both "project_dir" and "target_dir".
This commit has no functional changes.
This will also be used for built-in kernel integration, by
using this we can share more code with the built-in kernel
approach.
Reviewed-by: Johannes Berg <johannes@sipsolutions.net>
When integrating we need the BACKPORT prefix added to
dependency symbols.
The way we backport when packaging is to minimize the amount of
changes required by taking advantage of the fact that Kconfig
can treat CONFIG_ as an environment variable with getenv()
when parsing menu entries. When doing integration we don't want
to do this so instead we'll rely on the CONFIG_BACKPORT prefix.
This requires a bit of work on our current parsers, so to do that
identify the backport and provide that to helpers.
This also provides initial basic support for integration where no
additional code was required other than prefixes or ensuring certain
things are not done for integration. Before we expose integration
support we'll need to add quite a bit more things so this just assumes
integration is never desired.
We'll later want to do some modifications of symbols we backport
when integrating, but before we do any modification on kconfig
files we should keep track of the original source symbols.
This commit introduces no functional changes right now, it will
become more useful after we start adjusting kconfig entries
for integration.
Allow parsers to query the type of option used, either config
or menuconfig. This will be used later.
Move packaging kconfig hacks to its own file, we'll be ignoring
this file later for postprocessing. Keeping this in a separate
file will make parsing much simpler.
We only need this for modules.
This allows us to extend how backports uses patches for
different types of applications. This will later be used
for kernel integration support, for example.
This should have no functional change.
1 3.0.101 [ OK ]
2 3.1.10 [ OK ]
3 3.2.62 [ OK ]
4 3.3.8 [ OK ]
5 3.4.104 [ OK ]
6 3.5.7 [ OK ]
7 3.6.11 [ OK ]
8 3.7.10 [ OK ]
9 3.8.13 [ OK ]
10 3.9.11 [ OK ]
11 3.10.58 [ OK ]
12 3.11.10 [ OK ]
13 3.12.31 [ OK ]
14 3.13.11 [ OK ]
15 3.14.22 [ OK ]
16 3.15.10 [ OK ]
17 3.16.6 [ OK ]
18 3.17.1 [ OK ]
19 3.18-rc1 [ OK ]
As drivers will start requiring the new framework and it has
been merged to linux/master during the 3.18 merge window, we
can include it into backports to compile if needed.
On kernels that do already have it but didn't want it built
honor that, but if building otherwise don't. This may need
to be revisited in the future.
