Instead of using an own version of sch_fq_codel.c make backports copy
that code from the kernel and use that. This ensures that we will
always use the latest version.
This also includes flow_dissector.c which provides a function used by
sch_fq_codel.c.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
Instead of using an own version of sch_codel.c make backports copy that
code from the kernel and use that. This ensures that we will always use
the latest version.
Instead of using an own version of cordic.c make backports copy that
the latest version.
This is needed by net-core-flow_dissector.c.
This is needed by net-core-flow_dissector.c Kernel < 2.6.25 and kernel
> 3.6 have this function.
This driver needs some additional struct members in struct
sec_regulator_data which are not available in a kernel < 3.15
This essentially reverts commit cb6f08d3c38c as that caused
issues with copy-list - the scripting when generating the
backport can't prove that net/ieee802154/ isn't needed and
will try to go into it even if it wasn't copied.
Instead, make net/ieee802154/ be entered whenever it might
be needed - which is for CPTCFG_IEEE802154 and CPTCFG_BT.
This is harmless if the directory ends up listed twice but
will cause this problem to disappear.
Somehow !LEDS_CLASS and LEDS_CLASS=n seem to be different (likely
because LEDS_CLASS is tristate, but BACKPORT_BUILD_LEDS is just a
bool), so use LEDS_CLASS=n to fix build issues in other cases on
certain kernel configurations.
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.54 [ OK ]
19 3.3.8 [ OK ]
20 3.4.79 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.29 [ OK ]
27 3.11.10 [ OK ]
28 3.12.10 [ OK ]
29 3.13.2 [ OK ]
30 3.14-rc1 [ OK ]
Manual changes were needed in
patches/collateral-evolutions/network/16-bluetooth/net_bluetooth_hidp_core.patch
This brings sch_fq_codel_core.c to the version used in kernel 3.14-rc1.
Most of the changes were done many kernel versions before 3.14-rc1, but
in kernel 3.14-rc1 net_random() was removed and not it does not even
compile any more.
This is used by v4l2-compat-ioctl32.c
The function pointer raw_request and output_report in struct
hid_ll_driver will be added with kernel 3.15, remove useage on
older kernel versions.
When led support is deactivated in the kernel and
CPTCFG_BACKPORT_BUILD_LEDS is set mac80211 references
led_trigger_blink_oneshot() but it is not declared anywhere.
This fixes the following build error:
net/mac80211/led.c: In function 'ieee80211_led_rx':
net/mac80211/led.c:25:2: error: implicit declaration of function 'led_trigger_blink_oneshot' [-Werror=implicit-function-declaration]
These only exist starting from 3.11, and wireless code will
start using them soon. Backport them as simple defines using
the corresponding non-power-efficient workqueues.
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.54 [ OK ]
19 3.3.8 [ OK ]
20 3.4.77 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.27 [ OK ]
27 3.11.10 [ OK ]
28 3.12.8 [ OK ]
29 3.13-rc8 [ OK ]
Add defconfig and necessary files to copy-list.
Signed-off-by: Stefan Assmann <sassmann@kpanic.de>
- add IFF_UNICAST_FLT define
- add PCI_DEV_FLAGS_ASSIGNED define
- add skb_frag_size_sub()
- add skb_frag_address()
- add patches/collateral-evolutions/network/84-ethernet/0011-igb_ethtool_ops.patch
- add patches/collateral-evolutions/network/84-ethernet/0012-igb_ndo_set_vf_spoofchk.patch
- add patches/collateral-evolutions/network/84-ethernet/0009-igb_vlan_rx_vid.patch
- add patches/collateral-evolutions/network/84-ethernet/0010-igb_ethtool_ops.patch
- add IFF_SUPP_NOFCS define
- add patches/collateral-evolutions/network/84-ethernet/0008-igb_no_fcs.patch
Is there a better way to handle struct sk_buff changes?
- add struct timestamp_event_queue
- add struct ptp_clock
- add ptp_clock_index()
- add patches/collateral-evolutions/network/84-ethernet/0007-igb_ethtool_ops.patch
- add EEE defines
- backport __skb_alloc_page and __skb_alloc_pages
- add patches/collateral-evolutions/network/84-ethernet/0006-igb_eee.patch
- backport mmd_eee_adv_to_ethtool_adv_t
- add define to map ptp_clock_register() to old version
- add patches/collateral-evolutions/network/84-ethernet/0004-igb_err_handler.patch
- add patches/collateral-evolutions/network/84-ethernet/0005-igb_mdi.patch
- add pci_sriov_set_totalvfs()
- add patches/collateral-evolutions/network/84-ethernet/0002-igb_pci_sriov_configure.patch
Several ifdefs in igb_main.c to avoid compiler warnings.
- add missing NETDEV_FRAG defines
- add struct pci_sriov
- add pci_vfs_assigned()
- add PCI_SRIOV defines
- add patches/collateral-evolutions/network/84-ethernet/0001-igb_net_device_ops.patch
- refactor u64_stats_sync.h a bit
- add u64_stats_init define
- add patches/collateral-evolutions/network/84-ethernet/0013-igb_hwmon.patch
The uninstall script calculated the filename in the wrong way. It added
the current working dir into the file name, this resulted in names like
this:
/lib/modules/2.6.32-431.3.1.el6.x86_64/updates//home/hauke/backports-20140124/drivers/net/wireless/ipw2x00/ipw2100.ko
The correct one would be this
/lib/modules/2.6.32-431.3.1.el6.x86_64/updates/drivers/net/wireless/ipw2x00/ipw2100.ko
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.54 [ OK ]
19 3.3.8 [ OK ]
20 3.4.77 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.27 [ OK ]
27 3.11.10 [ OK ]
28 3.12.8 [ OK ]
29 3.13-rc8 [ OK ]
In the kernel make will always access net/ieee802154/, we should do the
same.
This was changes in the kenrel in this commit:
commit a53d34c3465b8a840f7400932ae1b0a9f9ed6bef
Author: Dmitry Eremin-Solenikov <dmitry_eremin@mentor.com>
Date: Wed Jan 15 02:50:40 2014 +0400
net: move 6lowpan compression code to separate module
This is used by net/bluetooth/l2cap_sock.c
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.54 [ OK ]
19 3.3.8 [ OK ]
20 3.4.77 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.27 [ OK ]
27 3.11.10 [ OK ]
28 3.12.8 [ OK ]
29 3.13-rc8 [ OK ]
This fixes the following warning:
/net/bluetooth/hidp/core.c:271:12: warning: ‘hidp_get_raw_report’ defined but not used [-Wunused-function]
static int hidp_get_raw_report(struct hid_device *hid,
/drivers/net/ethernet/atheros/atl1e/atl1e_main.c:328:13: warning: ‘atl1e_rx_mode’ defined but not used [-Wunused-function]
static void atl1e_rx_mode(struct net_device *netdev,
/drivers/net/wireless/mwifiex/sta_cmd.c: In function ‘mwifiex_cmd_cfg_data’:
/drivers/net/wireless/mwifiex/sta_cmd.c:1196:6: warning: unused variable ‘ret’ [-Wunused-variable]
int ret;
/drivers/net/wireless/mwifiex/sdio.c:124:12: warning: ‘mwifiex_sdio_resume’ defined but not used [-Wunused-function]
static int mwifiex_sdio_resume(struct device *dev)
/drivers/net/wireless/at76c50x-usb.c: In function ‘at76_mod_init’:
/drivers/net/wireless/at76c50x-usb.c:2472:2: warning: passing argument 2 of ‘led_trigger_register_simple’ from incompatible pointer type [enabled by default]
led_trigger_register_simple("at76_usb-tx", &ledtrig_tx);
In file included from /backport-include/linux/leds.h:3:0,
from /drivers/net/wireless/at76c50x-usb.c:45:
include/linux/leds.h:97:13: note: expected ‘struct led_trigger **’ but argument is of type ‘struct backport_led_trigger **’
extern void led_trigger_register_simple(const char *name,
/drivers/net/wireless/at76c50x-usb.c: In function ‘at76_mod_exit’:
/drivers/net/wireless/at76c50x-usb.c:2484:2: warning: passing argument 1 of ‘led_trigger_unregister_simple’ from incompatible pointer type [enabled by default]
led_trigger_unregister_simple(ledtrig_tx);
include/linux/leds.h:99:13: note: expected ‘struct led_trigger *’ but argument is of type ‘struct backport_led_trigger *’
extern void led_trigger_unregister_simple(struct led_trigger *trigger);
RedHat 6.5 already contains ether_addr_equal_64bits() which will
conflict with our declaration.
This is needed by bcma.
alx_get_stats64() was added recently to alx driver, but on kernel <
2.6.30 only get_stats is available, convert the function on such
kernels to use the old api.
On kernel versions < 2.6.36 phy_mii_ioctl() gets struct mii_ioctl_data
as second parameter and on more recent kernel versions it takes struct
ifreq. This patch converts one version to the other.
ssb uses this header file, but does not use any of the functions in
there in the default config, because that is only used when
SSB_DRIVER_GPIO and SSB_EMBEDDED are activated.
net/bluetooth/hci_sysfs.c uses ATTRIBUTE_GROUPS on all kernel versions.
Now it has to be for older kernel versions as well and
__ATTRIBUTE_GROUPS is also needed for these old versions.
This copies the sdio device id list into backprots, this is used by
brcmfmac.
drivers/bcma/driver_gpio.c calls irq_set_chip_and_handler() when
BCMA_HOST_SOC is activated. irq_set_chip_and_handler() gets exported on
kernel >= 3.7, we should not activate this on any older kernel.
This patch reverts the changes done in the following commit for older
kernel versions:
commit f663dd9aaf9ed124f25f0f8452edf238f087ad50
Author: Jason Wang <jasowang@redhat.com>
Date: Fri Jan 10 16:18:26 2014 +0800
net: core: explicitly select a txq before doing l2 forwarding
CC: Emmanuel Grumbach <emmanuel.grumbach@intel.com>
1 2.6.25 [ OK ]
2 2.6.26 [ OK ]
3 2.6.27 [ OK ]
4 2.6.28 [ OK ]
5 2.6.29 [ OK ]
6 2.6.30 [ OK ]
7 2.6.31 [ OK ]
8 2.6.32 [ OK ]
9 2.6.33 [ OK ]
10 2.6.34 [ OK ]
11 2.6.35 [ OK ]
12 2.6.36 [ OK ]
13 2.6.37 [ OK ]
14 2.6.38 [ OK ]
15 2.6.39 [ OK ]
16 3.0.101 [ OK ]
17 3.1.10 [ OK ]
18 3.2.54 [ OK ]
19 3.3.8 [ OK ]
20 3.4.77 [ OK ]
21 3.5.7 [ OK ]
22 3.6.11 [ OK ]
23 3.7.10 [ OK ]
24 3.8.13 [ OK ]
25 3.9.11 [ OK ]
26 3.10.27 [ OK ]
27 3.11.10 [ OK ]
28 3.12.8 [ OK ]
29 3.13-rc8 [ OK ]
