2013-10-23backports: refresh on next-20130830backports-20130830Hauke Mehrtens
== ckmake-report.log == 1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.98 [ OK ] 17 3.1.10 [ OK ] 18 3.10.14 [ OK ] 19 3.11.3 [ OK ] 20 3.12-rc3 [ FAIL ] 21 3.2.51 [ OK ] 22 3.3.8 [ OK ] 23 3.4.64 [ OK ] 24 3.5.7 [ OK ] 25 3.6.11 [ OK ] 26 3.7.10 [ OK ] 27 3.8.13 [ OK ] 28 3.9.11 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-23backports: do not use uapi in includeHauke Mehrtens
2013-10-23backports: add platform driver for media driversHauke Mehrtens
2013-10-23backports: VIDEO_RENESAS_VSP1 depends on kernel >= 3.6Hauke Mehrtens
2013-10-23backports: fix kernel dependencies for regulator driversHauke Mehrtens
These drivers are depending on changes of the regulator core driver which are not in the specific kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-23backports: remove vga_switcheroo.hHauke Mehrtens
This only used by the DRM drivers Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-23backports: remove linux/pagemap.hHauke Mehrtens
This was just used by some GPU drivers Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-23backports: remove pci_platform_rom()Hauke Mehrtens
This was only used by the DRM drivers Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-23backports: remove shmem_read_mapping_page_gfp()Hauke Mehrtens
This was only needed for some of the DRM drivers, remove it. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-23backports: remove cpufreq_quick_get_max()Hauke Mehrtens
2013-10-23backports: remove i2c_bit_algo()Hauke Mehrtens
2013-10-23backports: remove compat_wake_up_locked()Hauke Mehrtens
2013-10-23backports: remove devm_regmap_init_spi()Hauke Mehrtens
This is not used by any code in backports, not even a DRM driver. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-23backports: remove ktime_get_monotonic_offset()Hauke Mehrtens
2013-10-23backports: remove scatterlistHauke Mehrtens
2013-10-23backports: remove some stuff related to MTRRHauke Mehrtens
2013-10-23backports: remove more hdmi stuffHauke Mehrtens
2013-10-23backports: remove BACKPORT_BUILD_HDMIHauke Mehrtens
2013-10-23backports: remove BACKPORT_BUILD_RADIX_HELPERSHauke Mehrtens
2013-10-23backports: remove CPTCFG_BACKPORT_BUILD_WW_MUTEXHauke Mehrtens
2013-10-23backports: remove BACKPORT_BUILD_CROSS_RESERVATIONHauke Mehrtens
2013-10-23backports: remove platform driversHauke Mehrtens
The platform drivers were only needed by some DRM drivers and are not needed any more with the DRM driver being removed. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-23backports: remove DRM driverHauke Mehrtens
Maintaining the DRM driver takes a lot of recourses as there they are depending on many API changes done to the core kernel code and currently we do not have that many recourses to follow them. On the other side one needs also new userspace drivers to make use of the new features added to the DRM kernel drivers and it is not easy to update the X drivers. Therefore we came to the conclusion to remove the drm drivers for now. There were also some problems with some DRM drivers, like the Intel i915 driver caused kernel panic on some systems and was probably only usable on some very recent kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: update test kernel versionsbackports-20130822Hauke Mehrtens
2013-10-21backports: refresh patches on next-20130822Hauke Mehrtens
2013-10-21backports: remove reading of consumed energy from sysfsHauke Mehrtens
MSR_RAPL_POWER_UNIT is not available on older kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: add tty_port_tty_hangup()Hauke Mehrtens
This is needed by ./net/bluetooth/rfcomm/tty.c Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: add tty_port_tty_wakeup()Hauke Mehrtens
2013-10-21backports: copy include/drm/drm_flip_work.hHauke Mehrtens
This file was newly added to drm. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: backport new sysfs api in mediaHauke Mehrtens
2013-10-21backports: add DEVICE_ATTR_RWHauke Mehrtens
This is used by drivers/media/v4l2-core/v4l2-dev.c. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: refresh patches for next-20130816backports-20130816Hauke Mehrtens
1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.89 [ OK ] 17 3.1.10 [ OK ] 18 3.10.5 [ OK ] 19 3.11-rc4 [ OK ] 20 3.2.50 [ OK ] 21 3.3.8 [ OK ] 22 3.4.56 [ OK ] 23 3.5.7 [ OK ] 24 3.6.11 [ OK ] 25 3.7.10 [ OK ] 26 3.8.13 [ OK ] 27 3.9.11 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: do not build REGULATOR_PALMAS on older kernel versions.Hauke Mehrtens
REGULATOR_PALMASi now needs some symbols form headers of very recent kernel versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: add debugfs_create_x64()Hauke Mehrtens
This adds debugfs_create_x64() by calling debugfs_create_u64() instead. The 64 bit number is then not hex, but dec formated in debug fs. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: do not use DMA SG on old kernel versionsHauke Mehrtens
the usb net driver now uses the dma sg api which is not available on old kernels, this patch removed the usage of the dma sg api for old kernel versions. This backports the following upstream commit: commit 638c5115a794981441246fa8fa5d95c1875af5ba Author: Ming Lei <ming.lei@canonical.com> Date: Thu Aug 8 21:48:24 2013 +0800 USBNET: support DMA SG Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: use old led api on old kernel versions.Hauke Mehrtens
Usage of a new led api was introduced in mac80211, this patch make backports use the old api on older kernel versions. This could cause a problem with the led, the transmit led could stay on if nothing is transfered. This backports the following upstream commit: commit e47f2509e5f182f4df144406de6f2bc78179d57e Author: Fabio Baltieri <fabio.baltieri@gmail.com> Date: Thu Jul 25 12:00:26 2013 +0200 mac80211: use oneshot blink API for LED triggers Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: replace new portid usageHauke Mehrtens
In this upstream commit a new usage of portid was introduced: commit ac22ac466a659f1b2e02a2e2ee23fc5c42da2c95 Author: Samuel Ortiz <sameo@linux.intel.com> Date: Wed Jul 24 18:10:50 2013 +0200 NFC: Add a GET_SE netlink API Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: refresh patches for next-20130809backports-20130809Hauke Mehrtens
== ckmake-report.log == 1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.89 [ OK ] 17 3.1.10 [ OK ] 18 3.10.5 [ OK ] 19 3.11-rc4 [ OK ] 20 3.2.50 [ OK ] 21 3.3.8 [ OK ] 22 3.4.56 [ OK ] 23 3.5.7 [ OK ] 24 3.6.11 [ OK ] 25 3.7.10 [ OK ] 26 3.8.13 [ OK ] 27 3.9.11 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: REGULATOR_DA9210 needs at least kernel 3.5Hauke Mehrtens
This drivers needs some new members in the regulator structure. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: add HDMI_INFOFRAME_SIZEHauke Mehrtens
Add the missing define. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: add hdmi_infoframe_pack()Hauke Mehrtens
This adds the missing function hdmi_infoframe_pack() for kernels where the HDMI subsystem is not backported, like all kernel >= 3.9. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: add include/drm/drm_agpsupport.hHauke Mehrtens
This adds the missing file include/drm/drm_agpsupport.h Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: fix intel i915 drm driverHauke Mehrtens
The intel i915 drm driver uses the declarations from intel-gtt.h to interact with drivers/char/agp/intel-gtt.c which is not backported by backports project. To prevent some strange problems when using i915, use the headers from the kernel and do not use our own. This causes some compile problems which where runtime problems before and bumps the minimal kernel version to 3.7. This i915 still crash on my device with kernel 3.7. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21gentree.py: add ending slash to upload pathHauke Mehrtens
the filename in kup put should end with a slash otherwise it tried to overwrite this file. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21gentree.py: log kup command before executingHauke Mehrtens
Add a logging of the next command to be executed. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21gentree.py: fix directory creatingHauke Mehrtens
The full path has to be provided not just the new directory to create. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21gentree.py: do not add full path into tarHauke Mehrtens
dir_to_tar could be the absolute path to the directory to to tar, but we do not want the full patch in the tar, just the basename. In addition the second close is not necessary. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21gentree.py: add kernel upload supportLuis R. Rodriguez
This streamlines our release process making it easier for transitioning releases onto other backport developers. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-10-21lib/bpkup.py: add or own kernel uploader helper libLuis R. Rodriguez
kup is written in perl, add some basic python interfaces for it to allow us to upload to kernel.org backport releases. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-10-21lib/bpgpg.py: add simple gpg helper for gpg signingLuis R. Rodriguez
Note that kup expects --armor --detach-sign, we'll pass that as part of our extra_args. The python gpg lib doesn't provide support for random arguments as this one, so just add our own little helper and carry it over. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
