2013-10-21backports: refresh patches for next-20130809backports-20130809Hauke Mehrtens
== ckmake-report.log == 1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.89 [ OK ] 17 3.1.10 [ OK ] 18 3.10.5 [ OK ] 19 3.11-rc4 [ OK ] 20 3.2.50 [ OK ] 21 3.3.8 [ OK ] 22 3.4.56 [ OK ] 23 3.5.7 [ OK ] 24 3.6.11 [ OK ] 25 3.7.10 [ OK ] 26 3.8.13 [ OK ] 27 3.9.11 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: REGULATOR_DA9210 needs at least kernel 3.5Hauke Mehrtens
This drivers needs some new members in the regulator structure. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: add HDMI_INFOFRAME_SIZEHauke Mehrtens
Add the missing define. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: add hdmi_infoframe_pack()Hauke Mehrtens
This adds the missing function hdmi_infoframe_pack() for kernels where the HDMI subsystem is not backported, like all kernel >= 3.9. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: add include/drm/drm_agpsupport.hHauke Mehrtens
This adds the missing file include/drm/drm_agpsupport.h Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21backports: fix intel i915 drm driverHauke Mehrtens
The intel i915 drm driver uses the declarations from intel-gtt.h to interact with drivers/char/agp/intel-gtt.c which is not backported by backports project. To prevent some strange problems when using i915, use the headers from the kernel and do not use our own. This causes some compile problems which where runtime problems before and bumps the minimal kernel version to 3.7. This i915 still crash on my device with kernel 3.7. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21gentree.py: add ending slash to upload pathHauke Mehrtens
the filename in kup put should end with a slash otherwise it tried to overwrite this file. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21gentree.py: log kup command before executingHauke Mehrtens
Add a logging of the next command to be executed. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21gentree.py: fix directory creatingHauke Mehrtens
The full path has to be provided not just the new directory to create. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21gentree.py: do not add full path into tarHauke Mehrtens
dir_to_tar could be the absolute path to the directory to to tar, but we do not want the full patch in the tar, just the basename. In addition the second close is not necessary. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-10-21gentree.py: add kernel upload supportLuis R. Rodriguez
This streamlines our release process making it easier for transitioning releases onto other backport developers. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-10-21lib/bpkup.py: add or own kernel uploader helper libLuis R. Rodriguez
kup is written in perl, add some basic python interfaces for it to allow us to upload to kernel.org backport releases. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-10-21lib/bpgpg.py: add simple gpg helper for gpg signingLuis R. Rodriguez
Note that kup expects --armor --detach-sign, we'll pass that as part of our extra_args. The python gpg lib doesn't provide support for random arguments as this one, so just add our own little helper and carry it over. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-10-21lib/bpgit.py: add support for git paranoiaLuis R. Rodriguez
This cleans sanitizes a source tree and ensures no content is present from what was intended. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-10-21lib/bpgit.py: add git tree verification supportLuis R. Rodriguez
This verifies that the tree provided has its last commit both tagged and also digitally signed. In short it does: git tag -v $(git describe --dirty) This will be used later. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-10-21lib/bpgit.py: add git clean supportLuis R. Rodriguez
We'll use this later. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-10-21lib/bpgit.py: add git status supportLuis R. Rodriguez
We use --porcelain given that this spits out the results in an easy-to-parse format for scripts and will remain stable across git versions and regardless of user configuration. We will use this later. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-10-21lib/bpgit.py: enable extra arguments on git describeLuis R. Rodriguez
This lets us throw at it whatever extra stuff we want. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: add missing returns on ww_mutex backpotsbackports-20130802Luis R. Rodriguez
Two returns were missing on the ww_mutex backport, add these. The enhancements are not supported on older kernels so just bail out early. Tested against next-20130802 1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.79 [ OK ] 17 3.1.10 [ OK ] 18 3.10-rc1 [ OK ] 19 3.2.45 [ OK ] 20 3.3.8 [ OK ] 21 3.4.46 [ OK ] 22 3.5.7 [ OK ] 23 3.6.11 [ OK ] 24 3.7.10 [ OK ] 25 3.8.13 [ OK ] 26 3.9.3 [ OK ] real 34m47.935s user 938m15.592s sys 130m11.724s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: refresh patches for next-20130802 againLuis R. Rodriguez
For some reason some other changes were picked up again now. == ckmake-report.log == 1 2.6.25 [ OK ] 2 2.6.26 [ OK ] 3 2.6.27 [ OK ] 4 2.6.28 [ OK ] 5 2.6.29 [ OK ] 6 2.6.30 [ OK ] 7 2.6.31 [ OK ] 8 2.6.32 [ OK ] 9 2.6.33 [ OK ] 10 2.6.34 [ OK ] 11 2.6.35 [ OK ] 12 2.6.36 [ OK ] 13 2.6.37 [ OK ] 14 2.6.38 [ OK ] 15 2.6.39 [ OK ] 16 3.0.79 [ OK ] 17 3.1.10 [ OK ] 18 3.10-rc1 [ OK ] 19 3.2.45 [ OK ] 20 3.3.8 [ OK ] 21 3.4.46 [ OK ] 22 3.5.7 [ OK ] 23 3.6.11 [ OK ] 24 3.7.10 [ OK ] 25 3.8.13 [ OK ] 26 3.9.3 [ OK ] real 34m47.737s user 937m23.708s sys 129m50.928s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backport: simplify #ifdefs in pci-aspm.hJohannes Berg
Just use #else instead of two conditionals. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: add generic semaphore.hLuis R. Rodriguez
Matthew generalized the semaphore implementation and part of that collateral evolution consisted of changing the header used for the expected routines from asm/semaphore.h to linux/semaphore.h. mcgrof@garbanzo ~/linux-next (git::master)$ git describe --contains \ 64ac24e738823161693bf791f87adc802cf529ff v2.6.26-rc1~1155^2~5 commit 64ac24e738823161693bf791f87adc802cf529ff Author: Matthew Wilcox <matthew@wil.cx> Date: Fri Mar 7 21:55:58 2008 -0500 Generic semaphore implementation Semaphores are no longer performance-critical, so a generic C implementation is better for maintainability, debuggability and extensibility. Thanks to Peter Zijlstra for fixing the lockdep warning. Thanks to Harvey Harrison for pointing out that the unlikely() was unnecessary. Signed-off-by: Matthew Wilcox <willy@linux.intel.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: fix compilation for 2.6.25 for math64 headerLuis R. Rodriguez
We need to ifdef correctly before assuming we can include that header. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: do not depend on PCI functions when PCI is disabled in the kernelHauke Mehrtens
This should prevent some compile errors when backports is used with a kernel without PCI support. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: fix typo in defineHauke Mehrtens
This fixes a build error one some non x86 systems. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: remove alx patch for < 2.6.24Johannes Berg
Since we don't support kernels before 2.6.24 anymore there's no need to carry this patch. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27remove support for kernel 2.6.24Johannes Berg
By requiring 2.6.25 we can get rid of quite a lot of backport work. 2.6.25 was released more than five years ago (April 2011) and wasn't a long-term kernel either, so there's little point in supporting it now. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backport: backport device_move() properlyJohannes Berg
This was causing conflicts again when updating against wireless-next, so instead of adjusting the patches just provide a proper static inline backport. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: Actually export the 2.6.34 sdio compat symbolsSolomon Peachy
sdio_get_host_pm_caps() and sdio_set_host_pm_flags() were defined in compat-2.6.34 but not actually exported for other modules to use. The cw1200 driver needs sdio_set_host_pm_flags() properly exported. Signed-off-by: Solomon Peachy <pizza@shaftnet.org> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: fix conflict in swiotlb_nr_tbl() on RHEL 6.4Hauke Mehrtens
The RedHat kernel also provides a implementation for swiotlb_nr_tbl(), us that one on these kernels. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: refresh patches on next-20130802Hauke Mehrtens
== ckmake-report.log == 1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.89 [ OK ] 18 3.1.10 [ OK ] 19 3.10.5 [ OK ] 20 3.11-rc4 [ OK ] 21 3.2.50 [ OK ] 22 3.3.8 [ OK ] 23 3.4.56 [ OK ] 24 3.5.7 [ OK ] 25 3.6.11 [ OK ] 26 3.7.10 [ OK ] 27 3.8.13 [ OK ] 28 3.9.11 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: Atheros atl1c needs build_skb(), do not build on < 3.5Hauke Mehrtens
The Atheros atl1c driver now uses build_skb() which was added in 3.5. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: USB_SPEED_SUPER was added in 2.6.31Hauke Mehrtens
Now usbnet.c uses it and fails on kernel 2.6.30 without this patch. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: use genl_info_snd_portid() at an other place.Hauke Mehrtens
2013-08-27backports: add sysfs api backport for ieee802154Hauke Mehrtens
2013-08-27backports: REGULATOR_DA903X does not build on kernel < 3.12Hauke Mehrtens
REGULATOR_DA903X now uses a new struct member added with kernel 3.12 Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: add defconfig for cw1200Hauke Mehrtens
2013-08-27backports: refresh on next-20130726Hauke Mehrtens
2013-08-27backports: backport pci power save for mwifiexHauke Mehrtens
This patch makes mwifiex use the old suspend resume functions on older kernels. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: do not access hw_features in wil6210Hauke Mehrtens
wil6210 now uses netdev->hw_features which is not available in all kernel versions, do not set it then. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: add some new regulator drivers to default configHauke Mehrtens
2013-08-27backports: backport sysfs api in wirelessHauke Mehrtens
Older kernel versions do not support the new sysfs api with dev_groups. This makes net/wireless/sysfs.c use the old api on older kernels. This is a backport of this commit: commit f0bc99c84349ce87af5b35839d19bfb17bb9b27f Author: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Date: Wed Jul 24 15:05:35 2013 -0700 net: wireless: convert class code to use dev_groups This was mostly done by Johannes Berg <johannes@sipsolutions.net>. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Cc: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: add include/linux/regulator/pfuze100.hHauke Mehrtens
This is a new driver which needs a new header file. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: add hid_alloc_report_buf()Hauke Mehrtens
2013-08-27backports: do not copy wrong header files for regulatorsHauke Mehrtens
Some of the header files for the regulators framework where used by regulator core, which does not get backported or some of them are also used by mfd drivers. Now only the headers which are only used by the regulator driver are copied, it could still be that these headers are also used in some platform specific code where the driver gets registered. This patch then fixed some dependencies which where wrong because of using the wrong header files. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: add missing include for is_valid_ether_addr()Hauke Mehrtens
is_valid_ether_addr() is used, but the header here it is declared was not included. This fixes a problem introduced in commit: commit 521acfd92f168fc9b8b6a1cefe9a165243f3d872 Author: Patrick Ziegler <patrick.ziegler@fh-kl.de> Date: Thu Aug 15 14:40:09 2013 +0200 backports: add eth_prepare_mac_addr_change() and eth_commit_mac_addr_change() Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Cc: Patrick Ziegler <patrick.ziegler@fh-kl.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: usb_translate_errors() is needed for < 3.2Hauke Mehrtens
usb_translate_errors() is needed for every kernel < 3.2 and not < 2.6.39. This fixes a problem introduced in this commit: commit aee2dc1d7fd03d3900e06e88793b519e21049de0 Author: Patrick Ziegler <patrick.ziegler@fh-kl.de> Date: Thu Aug 15 14:40:20 2013 +0200 backports: add usb_translate_errors() Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Cc: Patrick Ziegler <patrick.ziegler@fh-kl.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: fix conditional include of arch_phys_wc_add()Hauke Mehrtens
This fixes a problem introduced in this commit: commit c871780b5afa182878884bf5ccd8df4817a2660f Author: Arik Nemtsov <arik@wizery.com> Date: Wed Aug 14 10:48:05 2013 +0300 backports: rename some mem functions to not break custom kernels Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Cc: Arik Nemtsov <arik@wizery.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: cw1200 needs the multicast API changes to support <=2.6.35Solomon Peachy
Also, update the dependencies: cw1200_wlan_sdio needs >=2.6.34 due to missing sdio_set_host_pm_flags() cw1200_wlan_spi needs >=2.6.35 due to missing request_any_context_irq() Signed-off-by: Solomon Peachy <pizza@shaftnet.org> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-08-27backports: cw1200 utilizes kthreads for <= 2.6.35Solomon Peachy
The new workqueue APIs in 2.6.36 allowed us to scrap the old kthread worker that had been used; unfortunately the backported API isn't complete so in order to support older kernels, resurrect this patch. Signed-off-by: Solomon Peachy <pizza@shaftnet.org> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
