2013-06-13backports: refersh patches on next-20130606backports-20130606Hauke Mehrtens
There was a manual adjustment needed in patches/collateral-evolutions/network/11-dev-pm-ops/drivers_net_wireless_iwlegacy_common.patch 1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.79 [ OK ] 18 3.1.10 [ OK ] 19 3.10-rc1 [ OK ] 20 3.2.45 [ OK ] 21 3.3.8 [ OK ] 22 3.4.46 [ OK ] 23 3.5.7 [ OK ] 24 3.6.11 [ OK ] 25 3.7.10 [ OK ] 26 3.8.13 [ OK ] 27 3.9.3 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-13backports: use old shrinkers API on old kernelsHauke Mehrtens
The shrinkers API was changed in new kernel versions. This patch makes the drm drivers use the old version on older kernel versions. This backports the following commit from mainline kernel: commit 1c1df1f6646854cca15fede54ec475b0e9f6a162 Author: Dave Chinner <dchinner@redhat.com> Date: Thu Jun 6 10:40:41 2013 +1000 drivers: convert shrinkers to new count/scan API Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-12backports: backport some memory functionsHauke Mehrtens
This includes the following functions needed by some drm drivers: arch_phys_wc_add() arch_phys_wc_del() phys_wc_to_mtrr_index() This backports the following commit form mainline kernel: commit d0d98eedee2178c803dd824bb09f52b0e2ac1811 Author: Andy Lutomirski <luto@amacapital.net> Date: Mon May 13 23:58:40 2013 +0000 Add arch_phys_wc_{add, del} to manipulate WC MTRRs if needed Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-05gentree/git-tracker: make python 3 compatibleJohannes Berg
Make the python scripting compatible with python 3 (as tested with python 3.3). The patch library was a bit tricky. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-05backports: use check-lxdialog.shJohannes Berg
We ship it, so we should use it. This should fix issues like one distro needing "-lncurses -ltinfo" and others requiring just "-lncurses" and not having "tinfo". Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-05backports: do not backport struct watchdog_device in RHEL 6.4Hauke Mehrtens
This is already included in the RHEL 6.4 kernel. 1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.79 [ OK ] 18 3.1.10 [ OK ] 19 3.10-rc1 [ OK ] 20 3.2.45 [ OK ] 21 3.3.8 [ OK ] 22 3.4.46 [ OK ] 23 3.5.7 [ OK ] 24 3.6.11 [ OK ] 25 3.7.10 [ OK ] 26 3.8.13 [ OK ] 27 3.9.3 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-05backports: protect pcmcia_enable_deviceHauke Mehrtens
This is already defined in RHEL 6.4 Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-05backports: protect irq_set_irq_type()Hauke Mehrtens
irq_set_irq_type is defined to set_irq_type in RHEL 6.4. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-05backports: to not backport skb_add_rx_fragi() on RHEL 6.4Hauke Mehrtens
The kernel in RHEL 6.4 already ships with skb_add_rx_frag() with 6 arguments. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-05backports: do not backport skb_tx_timestamp() on RHEL 6.4Hauke Mehrtens
The skb_tx_timestamp() implementation in RHEL 6.4 actually does something. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-05backports: do not backport shmem_read_mapping_page_gfp() on RHEL 6.4Hauke Mehrtens
shmem_read_mapping_page_gfp() looks different in the RHEL 6.4 source code and we should use that version instead. This also adds a missing include to prefix this function with backport_. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-05backports: do not backport netif_set_real_num_rx_queues() on RHEL 6.4Hauke Mehrtens
The in kernel version of netif_set_real_num_rx_queues() on RHEL 6.4 accesses some other struct members than our backported version. We should use that version instead. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-05backports: no kfifo.h when !CPTCFG_BACKPORT_BUILD_KFIFOHauke Mehrtens
When CPTCFG_BACKPORT_BUILD_KFIFO is not selected the default kernel header file should be used and not the backport code from backports. On RHEL 6.4 the kfido-new.h is included instead of the normal kfifo.h. The kfifo backport code is only build when CPTCFG_BACKPORT_BUILD_KFIFO is set and not depending on some kernel version. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-05backports: fix DEFINE_DYNAMIC_DEBUG_METADATA for RHEL 6.4Hauke Mehrtens
The struct _ddebug does not have a enabled attribute in RHEL 6.4. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-05backports: add missing LINUX_BACKPORTHauke Mehrtens
This adds some missing LINUX_BACKPORT. This was found while compiling against CentOS 6.4. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-05backports: add RedHat versionHauke Mehrtens
We have to deactivate some backports when a RedHat kernel was found, the LINUX_BACKPORT preprocessor statement is not sufficient enough. This is done based on RHEL_RELEASE_CODE. When backports is compiled against a non RedHat kernel the RHEL_RELEASE_CODE is set to 0, so these defines are defined to some value. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-05backports: refresh patches for next-20130531backports-20130531Hauke Mehrtens
2013-06-05backports: add rcu_dereference_rtnlHauke Mehrtens
Add backport for rcu_dereference_rtnl() Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-05backports: add backport for netdev_notifier_info_to_dev()Hauke Mehrtens
This adds a backport for the following commit in mainline: commit 351638e7deeed2ec8ce451b53d33921b3da68f83 Author: Jiri Pirko <jiri@resnulli.us> Date: Tue May 28 01:30:21 2013 +0000 net: pass info struct via netdevice notifier Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-05backports: fix firmware install for old udev on UbuntuAnoop Karollil
Rules for older versions of udev (e.g. version 113-0ubuntu16 on Ubuntu 7.10) are looked for in /etc/udev/rules.d. For later versions, they are looked for in either the default /lib/udev/rules.d location or the custom /etc/udev/rules.d location. For backwards compatibility with older udev, the rules should be installed in /etc/udev/rules.d. Signed-off-by: Anoop Karollil <anoop.karollil@gmail.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-05-29backports: refresh patches for next-20130528backports-20130528Luis R. Rodriguez
1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.79 [ OK ] 18 3.1.10 [ OK ] 19 3.10-rc1 [ OK ] 20 3.2.45 [ OK ] 21 3.3.8 [ OK ] 22 3.4.46 [ OK ] 23 3.5.7 [ OK ] 24 3.6.11 [ OK ] 25 3.7.10 [ OK ] 26 3.8.13 [ OK ] 27 3.9.3 [ OK ] real 33m11.072s user 877m52.824s sys 139m8.874s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-05-28backports: catch make in backport template directorybackports-20130523Johannes Berg
Catch running make in the backport template directory by checking for the .local-symbols file. If it isn't there then we're in the input/template directory rather than in an output tree, give the user a hint about it instead of keeling over. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-05-28backport: move kconfig code to "kconf" directoryJohannes Berg
Having the kconfig code in a directory called "kconfig" and having a file called "Kconfig" causes issues if the code is ever stored on a case-insensitive filesystem. Avoid these by just calling the kconfig directory kconf instead. Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-05-28Revert "backport: move kconfig code to "kconf" directory"Luis R. Rodriguez
I failed to see v2 patch. This reverts commit 7f1b4e0258ade60670cf60f2bd46996005843cea.
2013-05-28backports: BCMA and SSB MIPS drivers are depending on kernel >= 3.3Hauke Mehrtens
The bcma and ssb mips driver are depending on kernel 3.3. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-05-28backports: add missing include to dma-shared-helpers.cHauke Mehrtens
2013-05-28backports: refresh patches on next-20130523Hauke Mehrtens
== ckmake-report.log == 1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.79 [ OK ] 18 3.1.10 [ OK ] 19 3.10-rc1 [ OK ] 20 3.2.45 [ OK ] 21 3.3.8 [ OK ] 22 3.4.46 [ OK ] 23 3.5.7 [ OK ] 24 3.6.11 [ OK ] 25 3.7.10 [ OK ] 26 3.8.13 [ OK ] 27 3.9.3 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-05-28backports: add vm_iomap_memory()Hauke Mehrtens
This adds vm_iomap_memory() from: commit b4cbb197c7e7a68dbad0d491242e3ca67420c13e Author: Linus Torvalds <torvalds@linux-foundation.org> Date: Tue Apr 16 13:45:37 2013 -0700 vm: add vm_iomap_memory() helper function Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-05-28backports: build NFC_MEI_PHY only on >= 3.10Hauke Mehrtens
The MEI NFC driver needs include/linux/mei_cl_bus.h which was added with kernel 3.10. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-05-20backports: add kernel 3.10 and update othersbackports-20130520Hauke Mehrtens
Add kernel 3.10 to the script fetching the kernels for compile testing. This also fixes the header rebuild for kernel versions >= 3.10. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-05-20backports: refresh patches for next-20130520Hauke Mehrtens
2013-05-19backports: add CPTCFG_CFG80211_WEXTbackports-20130513Hauke Mehrtens
Without wext support we will get lots of complains about iwconfig not working. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-05-19backports: add defconfig for broadcom driversHauke Mehrtens
This adds a default config for the broadcom wifi drivers. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-05-19backport: refresh patches on next-20130513Hauke Mehrtens
2013-05-19backport: make patch apply againHauke Mehrtens
2013-05-19backport: do not add the vlan backports for kernel 3.10Hauke Mehrtens
The kernel 3.10 already includes the new versions. Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-05-19backports: defconfig for rtlwifi familyLarry Finger
Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-05-19backports: Fix menuconfig buildLarry Finger
Using openSUSE 12.3 with x86_64 architecture, the 'make menuconfig' command results in the following: finger@larrylap:~/backports-3.10-rc1-1> make menuconfig cc -Wl,--no-as-needed -lncurses mconf.o zconf.tab.o lxdialog/checklist.o lxdialog/inputbox.o lxdialog/menubox.o lxdialog/textbox.o lxdialog/util.o lxdialog/yesno.o -o mconf /usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../x86_64-suse-linux/bin/ld: /lib64/libncurses.so.5: undefined reference to symbol 'acs_map' /usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../x86_64-suse-linux/bin/ld: note: 'acs_map' is defined in DSO /usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../lib64/libtinfo.so so try adding it to the linker command line /usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../lib64/libtinfo.so: could not read symbols: Invalid operation collect2: error: ld returned 1 exit status make[2]: *** [mconf] Error 1 make[1]: *** [menuconfig] Error 2 make: *** [menuconfig] Error 2 finger@larrylap:~/backports-3.10-rc1-1> When "-ltinfo" is added to the LDFLAGS symbol as suggested by the linker, it builds and runs correctly. 1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.76 [ OK ] 18 3.1.10 [ OK ] 19 3.2.44 [ OK ] 20 3.3.8 [ OK ] 21 3.4.43 [ OK ] 22 3.5.7 [ OK ] 23 3.6.11 [ OK ] 24 3.7.10 [ OK ] 25 3.8.11 [ OK ] 26 3.9.0 [ OK ] real 17m9.368s user 403m46.554s sys 95m42.811s Signed-off-by: Larry Finger <Larry.Finger@lwfinger.net> [mcgrof: tested with ckmake] Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-05-17backport: remove redundant copy-list entriesbackports-20130502Johannes Berg
Directory copying is recursive, so there's no need to list subdirectories. All atheros ethernet drivers are copied, so don't list them one by one. The same is true for the Bluetooth include files. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-17backports: refresh patches for next-20130501Luis R. Rodriguez
1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.76 [ OK ] 18 3.1.10 [ OK ] 19 3.2.44 [ OK ] 20 3.3.8 [ OK ] 21 3.4.43 [ OK ] 22 3.5.7 [ OK ] 23 3.6.11 [ OK ] 24 3.7.10 [ OK ] 25 3.8.11 [ OK ] 26 3.9.0 [ OK ] real 30m46.042s user 816m2.488s sys 126m33.079s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-17backports: refresh patches for next-20130430Luis R. Rodriguez
1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.76 [ OK ] 18 3.1.10 [ OK ] 19 3.2.44 [ OK ] 20 3.3.8 [ OK ] 21 3.4.43 [ OK ] 22 3.5.7 [ OK ] 23 3.6.11 [ OK ] 24 3.7.10 [ OK ] 25 3.8.11 [ OK ] 26 3.9.0 [ OK ] real 30m45.327s user 814m25.678s sys 128m22.341s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-17backports: address NFC LLCP code shiftLuis R. Rodriguez
Samuel folded code under net/nfc/llcp/ onto the parent net/nfc/ directory with llcp_ prefixes for the files. Address this change introduced as of next-20130430. commit 30cc4587659e1c9b1bfade8b2a757d91e04758ab Author: Samuel Ortiz <sameo@linux.intel.com> Date: Fri Apr 26 11:49:40 2013 +0200 NFC: Move LLCP code to the NFC top level diirectory And stop making it optional. LLCP is a fundamental part of the NFC specifications and making it optional does not make much sense. Signed-off-by: Samuel Ortiz <sameo@linux.intel.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-17backports: refresh patches for next-20130429Luis R. Rodriguez
1 2.6.24 [ OK ] 2 2.6.25 [ OK ] 3 2.6.26 [ OK ] 4 2.6.27 [ OK ] 5 2.6.28 [ OK ] 6 2.6.29 [ OK ] 7 2.6.30 [ OK ] 8 2.6.31 [ OK ] 9 2.6.32 [ OK ] 10 2.6.33 [ OK ] 11 2.6.34 [ OK ] 12 2.6.35 [ OK ] 13 2.6.36 [ OK ] 14 2.6.37 [ OK ] 15 2.6.38 [ OK ] 16 2.6.39 [ OK ] 17 3.0.76 [ OK ] 18 3.1.10 [ OK ] 19 3.2.44 [ OK ] 20 3.3.8 [ OK ] 21 3.4.43 [ OK ] 22 3.5.7 [ OK ] 23 3.6.11 [ OK ] 24 3.7.10 [ OK ] 25 3.8.11 [ OK ] 26 3.9.0 [ OK ] real 30m48.875s user 815m54.307s sys 127m12.229s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-17backports: address nouveau file shufflingLuis R. Rodriguez
The recent file shuffling on nouveau requires some changes not upstream to get it to compile to ensure some objects do get interpreted as requiring the new search path. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-17backports: add proc_set_size() and proc_set_user()Luis R. Rodriguez
mcgrof@frijol ~/linux-stable (git::master)$ git describe --contains 271a15ea v3.10-rc1~129^2~24 commit 271a15eabe094538d958dc68ccfc9c36b699247a Author: David Howells <dhowells@redhat.com> Date: Fri Apr 12 00:38:51 2013 +0100 proc: Supply PDE attribute setting accessor functions Supply accessor functions to set attributes in proc_dir_entry structs. The following are supplied: proc_set_size() and proc_set_user(). Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> cc: linuxppc-dev@lists.ozlabs.org cc: linux-media@vger.kernel.org cc: netdev@vger.kernel.org cc: linux-wireless@vger.kernel.org cc: linux-pci@vger.kernel.org cc: netfilter-devel@vger.kernel.org cc: alsa-devel@alsa-project.org Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-17backports: add PDE_DATA() case when CONFIG_PROC_FS is disabledLuis R. Rodriguez
This was missing. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-17backports: revert remove_proc_subtree() for backportLuis R. Rodriguez
Intorduced in next-20130429 and Linus has merged it onto v3.10-rc1. We cannot backport remove_proc_subtree() modularly [0] so just go ahead and revert this change. The alternative is to go and review each procfs usage for each driver we have issues and see if it makes sense to replace procs with debugfs upstream. commit 8ce584c7416d8a85a6f3edc17d1cddefe331e87e Author: Al Viro <viro@zeniv.linux.org.uk> Date: Sat Mar 30 20:13:46 2013 -0400 procfs: add proc_remove_subtree() just what it sounds like; do that only to procfs subtrees you've created - doing that to something shared with another driver is not only antisocial, but might cause interesting races with proc_create() and its ilk. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> [0] http://marc.info/?t=136841961600002&r=1&w=2 Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-17gentree: refuse patches creating filesJohannes Berg
This doesn't make sense since we'd have no way of knowing when such a patch should be applied. Right now the patch would be ignored, but make it extra obvious and error out on such patches. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-05-16backports: fix rfkill sparse warningJohannes Berg
The new backport rfkill approach caused a sparse warning: linux/rfkill.h:70:43: warning: mixing different enum types linux/rfkill.h:70:43: int enum rfkill_type versus linux/rfkill.h:70:43: int enum old_rfkill_type Fix it by adding a cast. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
